I’ve disabled BT on the board so the dongle now is the only BT connection. That seems to have helped greatly.
Power on OSMC
Go to My OSMC
Turn on headphones
Go to Networking-Bluetooth
Reconnect to headphones (even though they show blue and the red light is blinking)
Settings-System-Audio and select ALSA
Sound is now coming thru the headphones! This has reliably worked every time I’ve booted up in the last week.
The initial connection while it seems to be connected, isn’t. I have to re-connect… and that seems to keep the sound coming thru the headphones 100% of the time.
I’ve noticed in the last few weeks that the headphones never truly connect when you first turn them on. At first in the Networking-Bluetooth menu you seem the device turn blue like it’s connected but it drops off within 2 seconds. Back to red disconnected. And of course from the moment you turn them on, the headphones constantly say “no device connected.”
When I Re-Connect, it actually does connect and stays. Then I set the sound to ALSA and all sounds run thru the headphones.
The 6 steps above have reliably made sound work thru the BT headphones consistently for weeks now.
At one point that actually was the case… I left it at HDMI… turn on headphones… sound came thru. Switched off headphones, sound went back thru the monitor.
Never was consistent but it was awesome when it worked!
Is there an update on this bug? I looked on github but the issues section is fairly clean.
I have a Bluetooth headset (Beats Studio 2.0) that pairs, but it doesn’t matter what I select I can’t get any audio to play. I’m assuming it’s related to this bug and eventually we’ll just leave it on HDMI and be done with it?
As it stands I’ve got a horrible grounding issue with my Pi 3 and I haven’t been able to isolate it so really, I have no audio until this is fixed as analogue audio isn’t a solution either.
Is there any news on this item? I have a Sony MDR-1000x but it does not work. Tried the onboard as well as a dongle. Edited the config.txt to disable onboard. In both cases the headphones only respond to “connect with PIN” it never asked for a pin but moves the headphones from discovery table to paired table. Then turns red and never connects.
