Whats the Youtube ID of an example to test?
Also have you checked mediainfo of the downloaded file?
My android Tv couldn’t play Youtube in HDR. I read that is a android mediatek problem but I was thinking maybe Vero 4k can play VP9 profile 2 codec based files properly with HDR but no:(
Evertything plays ok but TV doesn’t recognize that is HDR source and coluors are washed up.
Mediainfo of Youtube downloaded file:
Ogólne
Complete name : Z:\Philips\The World in HDR in 4K (ULTRA HD)-tO01J-M3g0U.webm
Format : WebM
Format version : Version 4 / Version 2
File size : 339 MiB
Duration : 2 min 34s
Overall bit rate : 18,4 Mb/s
Writing application : google
Writing library : google
Wideo
Format : VP9
Codec ID : V_VP9
Bit rate : 17,7 Mb/s
Width : 3.840 pikseli
Height : 2.160 pikseli
Display aspect ratio : 16:9
Frame rate mode : Stały
Frame rate : 59,940 kl/s
Color space : YUV
Bits/(Pixel*Frame) : 0.036
Stream size : 326 MiB (96%)
Language : Angielski
Default : Tak
Forced : Nie
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
You need vp9.2 not vp9
Yes. I know:)
According to Philips my POS 9002 supports VP9.2
I downloaded version 337 from Youtube - it ist VP9.2 HDR
Best regards
This one is available in HDR VP9.2:
tO01J-M3g0U
It states vp9 and not vp9.2 in the mediainfo though
When you look on youtube there is quite alot stated as HDR with vp9 instead of vp9.2 that’s why…
Can someone look up the metadata for the following video? I can play codec 337 (VP9.2 @ 4K) through chrome.
Just to confirm, the Vero 4K+ supports VP9.2?
> 337 webm 3840x2160 2160p60 HDR 29374k , vp9.2, 60fps, video only, 1.12GiB
> Video
> Format : VP9
> Codec ID : V_VP9
> Duration : 5 min 37 s
> Bit rate : 27.3 Mb/s
> Width : 3 840 pixels
> Height : 2 160 pixels
> Frame rate mode : Constant
> Frame rate : 59.940 FPS
> Color space : YUV
> Bits/(Pixel*Frame) : 0.055
> Stream size : 1.07 GiB (96%)
> Language : English
> Default : Yes
> Forced : No
> 272 webm 7680x4320 4320p60 29957k , vp9, 60fps, video only, 845.95MiB
> Video
> Format : VP9
> Codec ID : V_VP9
> Bit rate : 20.2 Mb/s
> Width : 7 680 pixels
> Height : 4 320 pixels
> Color space : YUV
> Bits/(Pixel*Frame) : 0.010
> Stream size : 812 MiB (96%)
> Language : English
> Default : Yes
> Forced : No
> Color primaries : BT.709
> Transfer characteristics : BT.709
> Matrix coefficients : BT.709
Thanks!
Can the Vero 4K+ play VP9.2 files?
