@sam_nazarko
dmesg:
root@osmc:/home/osmc# dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.13-1-osmc (root@vero) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Sun May 17 18:50:26 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 809abd80, node_mem_map ae213000
[ 0.000000] Normal zone: 1504 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (8640->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 10 pages/cpu @ae1e1000 s12096 r8192 d20672 u40960
[ 0.000000] pcpu-alloc: s12096 r8192 d20672 u40960 alloc=10*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 191008
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa01041 bcm2709.serial=0xbf570082 smsc95xx.macaddr=B8:27:EB:57:00:82 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 744108K/770048K available (7249K kernel code, 401K rwdata, 1864K rodata, 388K init, 763K bss, 25940K reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
vmalloc : 0xaf800000 - 0xff000000 (1272 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x808ee928 (9115 kB)
.init : 0x808ef000 - 0x80950000 ( 388 kB)
.data : 0x80950000 - 0x809b465c ( 402 kB)
.bss : 0x809b465c - 0x80a73594 ( 764 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000013] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000035] Switching to timer-based delay loop, resolution 52ns
[ 0.000325] Console: colour dummy device 80x30
[ 0.000529] console [tty0] enabled
[ 0.000555] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000583] pid_max: default: 32768 minimum: 301
[ 0.000977] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000998] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002224] Initializing cgroup subsys memory
[ 0.002278] Initializing cgroup subsys devices
[ 0.002302] Initializing cgroup subsys freezer
[ 0.002326] Initializing cgroup subsys net_cls
[ 0.002359] Initializing cgroup subsys blkio
[ 0.002442] CPU: Testing write buffer coherency: ok
[ 0.002519] ftrace: allocating 18151 entries in 54 pages
[ 0.046728] CPU0: update cpu_capacity 1024
[ 0.046766] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.046785] [bcm2709_smp_prepare_cpus] enter
[ 0.046928] Setting up static identity map for 0x6aeea8 - 0x6aef00
[ 0.106673] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.106976] CPU1: Booted secondary processor
[ 0.106984] [bcm2709_secondary_init] enter cpu:1
[ 0.107040] CPU1: update cpu_capacity 1024
[ 0.107049] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.126657] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.126909] CPU2: Booted secondary processor
[ 0.126916] [bcm2709_secondary_init] enter cpu:2
[ 0.126949] CPU2: update cpu_capacity 1024
[ 0.126957] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.146688] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.146929] CPU3: Booted secondary processor
[ 0.146935] [bcm2709_secondary_init] enter cpu:3
[ 0.146965] CPU3: update cpu_capacity 1024
[ 0.146974] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.147070] Brought up 4 CPUs
[ 0.147103] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.147114] CPU: All CPU(s) started in SVC mode.
[ 0.148142] devtmpfs: initialized
[ 0.173138] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.175168] pinctrl core: initialized pinctrl subsystem
[ 0.178248] NET: Registered protocol family 16
[ 0.183588] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.206487] cpuidle: using governor ladder
[ 0.236513] cpuidle: using governor menu
[ 0.236646] bcm2709.uart_clock = 3000000
[ 0.239571] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.239592] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.239625] mailbox: Broadcom VideoCore Mailbox driver
[ 0.239751] bcm2708_vcio: mailbox at f300b880
[ 0.240077] bcm_power: Broadcom power driver
[ 0.240095] bcm_power_open() -> 0
[ 0.240106] bcm_power_request(0, 8)
[ 0.740772] bcm_mailbox_read -> 00000080, 0
[ 0.740785] bcm_power_request -> 0
[ 0.740905] Serial: AMBA PL011 UART driver
[ 0.741043] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.809056] SCSI subsystem initialized
[ 0.809293] usbcore: registered new interface driver usbfs
[ 0.809408] usbcore: registered new interface driver hub
[ 0.809549] usbcore: registered new device driver usb
[ 0.811190] Switched to clocksource arch_sys_counter
[ 0.838702] FS-Cache: Loaded
[ 0.839023] CacheFiles: Loaded
[ 0.850702] NET: Registered protocol family 2
[ 0.852093] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.852236] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.852430] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.852540] TCP: reno registered
[ 0.852563] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.852627] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.853098] NET: Registered protocol family 1
[ 0.853521] RPC: Registered named UNIX socket transport module.
[ 0.853537] RPC: Registered udp transport module.
[ 0.853547] RPC: Registered tcp transport module.
[ 0.853558] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.854019] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.854241] bcm2708_dma: DMA manager at f3007000
[ 0.854400] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.856027] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.856253] audit: initializing netlink subsys (disabled)
[ 0.856317] audit: type=2000 audit(0.829:1): initialized
[ 0.872200] VFS: Disk quotas dquot_6.5.2
[ 0.872578] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.875558] FS-Cache: Netfs 'nfs' registered for caching
[ 0.876546] NFS: Registering the id_resolver key type
[ 0.876618] Key type id_resolver registered
[ 0.876632] Key type id_legacy registered
[ 0.877675] msgmni has been set to 1469
[ 0.879743] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.879928] io scheduler noop registered
[ 0.880246] io scheduler bfq registered (default)
[ 0.880258] BFQ I/O-scheduler version: v7r7
[ 0.882752] BCM2708FB: allocated DMA memory eec00000
[ 0.882799] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.916592] Console: switching to colour frame buffer device 240x67
[ 0.938789] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 0.939096] uart-pl011 dev:f1: no DMA platform data
[ 0.939595] vc-cma: Videocore CMA driver
[ 0.939610] vc-cma: vc_cma_base = 0x00000000
[ 0.939622] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.939633] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.951270] brd: module loaded
[ 0.957117] loop: module loaded
[ 0.957943] vchiq: vchiq_init_state: slot_zero = 0xaec80000, is_master = 0
[ 0.958796] Loading iSCSI transport class v2.0-870.
[ 0.959753] usbcore: registered new interface driver smsc95xx
[ 0.959829] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.160196] Core Release: 2.80a
[ 1.160218] Setting default values for core params
[ 1.160245] Finished setting default values for core params
[ 1.360655] Using Buffer DMA mode
[ 1.360670] Periodic Transfer Interrupt Enhancement - disabled
[ 1.360681] Multiprocessor Interrupt Enhancement - disabled
[ 1.360692] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.360709] Dedicated Tx FIFOs mode
[ 1.361090] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xaec14000 dma = 0xeec14000 len=9024
[ 1.361132] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 1.361157] dwc_otg: Microframe scheduler enabled
[ 1.361266] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x804f8c30
[ 1.361286] WARN::hcd_init_fiq:413: FIQ ASM at 0x804f8fa0 length 36
[ 1.361306] WARN::hcd_init_fiq:438: MPHI regs_base at 0xaf80a000
[ 1.361336] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.361389] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.361439] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.361495] Init: Port Power? op_state=1
[ 1.361506] Init: Power Port (0)
[ 1.361808] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.361828] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.361844] usb usb1: Product: DWC OTG Controller
[ 1.361860] usb usb1: Manufacturer: Linux 3.18.13-1-osmc dwc_otg_hcd
[ 1.361875] usb usb1: SerialNumber: bcm2708_usb
[ 1.362853] hub 1-0:1.0: USB hub found
[ 1.362916] hub 1-0:1.0: 1 port detected
[ 1.363431] dwc_otg: FIQ enabled
[ 1.363446] dwc_otg: NAK holdoff enabled
[ 1.363456] dwc_otg: FIQ split-transaction FSM enabled
[ 1.363498] Module dwc_common_port init
[ 1.363875] usbcore: registered new interface driver usb-storage
[ 1.364166] mousedev: PS/2 mouse device common for all mice
[ 1.365076] bcm2835-cpufreq: min=600000 max=900000
[ 1.365392] sdhci: Secure Digital Host Controller Interface driver
[ 1.365404] sdhci: Copyright(c) Pierre Ossman
[ 1.365594] DMA channels allocated for the MMC driver
[ 1.401222] Load BCM2835 MMC driver
[ 1.401529] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.405424] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.407774] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.408082] usbcore: registered new interface driver usbhid
[ 1.408095] usbhid: USB HID core driver
[ 1.409476] TCP: cubic registered
[ 1.409497] Initializing XFRM netlink socket
[ 1.409549] NET: Registered protocol family 17
[ 1.410801] Key type dns_resolver registered
[ 1.410980] Registering SWP/SWPB emulation handler
[ 1.413379] registered taskstats version 1
[ 1.415799] vc-sm: Videocore shared memory driver
[ 1.415819] [vc_sm_connected_init]: start
[ 1.416690] [vc_sm_connected_init]: end - returning 0
[ 1.417716] Waiting for root device /dev/mmcblk0p2...
[ 1.439246] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.441464] mmc0: new high speed SD card at address 1234
[ 1.442061] mmcblk0: mmc0:1234 SA02G 1.85 GiB
[ 1.443988] mmcblk0: p1 p2
[ 1.536848] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.536919] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.546811] devtmpfs: mounted
[ 1.547491] Freeing unused kernel memory: 388K (808ef000 - 80950000)
[ 1.561368] Indeed it is in host mode hprt0 = 00021501
[ 1.741341] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.741505] Indeed it is in host mode hprt0 = 00001101
[ 1.941708] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.941756] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.942851] hub 1-1:1.0: USB hub found
[ 1.942990] hub 1-1:1.0: 5 ports detected
[ 2.221494] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.321644] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.321675] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.324802] smsc95xx v1.0.4
[ 2.385329] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:57:00:82
[ 2.461450] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 2.578970] usb 1-1.4: New USB device found, idVendor=148f, idProduct=5370
[ 2.579003] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.579019] usb 1-1.4: Product: 802.11 n WLAN
[ 2.579034] usb 1-1.4: Manufacturer: Ralink
[ 2.579050] usb 1-1.4: SerialNumber: 1.0
[ 2.891567] usb 1-1.2: new low-speed USB device number 5 using dwc_otg
[ 3.009730] usb 1-1.2: New USB device found, idVendor=1a2c, idProduct=0e24
[ 3.009766] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.009782] usb 1-1.2: Product: USB Keyboard
[ 3.009797] usb 1-1.2: Manufacturer: SEM
[ 3.023283] input: SEM USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:1A2C:0E24.0001/input/input0
[ 3.023683] hid-generic 0003:1A2C:0E24.0001: input,hidraw0: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-bcm2708_usb-1.2/input0
[ 3.035406] input: SEM USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:1A2C:0E24.0002/input/input1
[ 3.035809] hid-generic 0003:1A2C:0E24.0002: input,hidraw1: USB HID v1.10 Device [SEM USB Keyboard] on usb-bcm2708_usb-1.2/input1
[ 3.684047] random: systemd urandom read with 84 bits of entropy available
[ 3.749529] NET: Registered protocol family 10
[ 4.188297] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 4.188602] systemd[1]: Found ordering cycle on basic.target/start
[ 4.188632] systemd[1]: Found dependency on sysinit.target/start
[ 4.188660] systemd[1]: Found dependency on rpcbind.service/start
[ 4.188688] systemd[1]: Found dependency on network-online.target/start
[ 4.188713] systemd[1]: Found dependency on connman-wait-for-network.service/start
[ 4.188738] systemd[1]: Found dependency on basic.target/start
[ 4.188764] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 4.188795] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 4.189133] systemd[1]: Found ordering cycle on basic.target/start
[ 4.189165] systemd[1]: Found dependency on sysinit.target/start
[ 4.189193] systemd[1]: Found dependency on kbd.service/start
[ 4.189220] systemd[1]: Found dependency on remote-fs.target/start
[ 4.189244] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 4.189269] systemd[1]: Found dependency on connman.service/start
[ 4.189293] systemd[1]: Found dependency on basic.target/start
[ 4.189318] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 4.189347] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 4.366766] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.389809] fuse init (API version 7.23)
[ 4.756201] systemd-udevd[130]: starting version 215
[ 5.104804] lirc_dev: IR Remote Control driver registered, major 246
[ 5.241803] cfg80211: Calling CRDA to update world regulatory domain
[ 5.304361] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.330368] random: nonblocking pool is initialized
[ 5.541378] usb 1-1.4: reset high-speed USB device number 4 using dwc_otg
[ 5.605094] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 5.652499] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
[ 5.678291] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
[ 5.705799] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 5.708499] usbcore: registered new interface driver rt2800usb
[ 6.261279] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[ 6.261686] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 6.261706] lirc_rpi: driver registered!
[ 6.527366] input: lircd as /devices/virtual/input/input2
[ 6.820115] systemd-journald[99]: Received request to flush runtime journal from PID 1
[ 7.768010] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 7.769202] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.926204] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 7.971673] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
[ 8.246471] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.211712] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.213043] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[ 12.832307] 8021q: 802.1Q VLAN Support v1.8
[ 14.221451] wlan0: authenticate with f4:ec:38:fc:6f:26
[ 14.267545] wlan0: send auth to f4:ec:38:fc:6f:26 (try 1/3)
[ 14.269115] wlan0: authenticated
[ 14.271249] wlan0: associate with f4:ec:38:fc:6f:26 (try 1/3)
[ 14.275146] wlan0: RX AssocResp from f4:ec:38:fc:6f:26 (capab=0x431 status=0 aid=6)
[ 14.281825] wlan0: associated
[ 14.282034] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 17.593517] Console: switching to colour dummy device 80x30
lsusb
root@osmc:/home/osmc# lsusb
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 005: ID 1a2c:0e24 China Resource Semico Co., Ltd
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
