use pactl set-card-profile 2 a2dp_sink without sudo
As written here
As written here
Aaaaah! That was the case! Thanks a lot.
Hi guys
i am currently trying to use my headphones with my Vero 4k+.
At the moment using the osmc GUI, pairing is not working.
I tried to read all the information on this topic but this is a little bit confusing.
So my understanding is:
With vero 4k + I don’t need a dongle, correct ?
If pairing does not work, I need to use command line (using bluetooth command)
If pairing is ok and connected, i need to switch in the audio setting to use bluetooth or Pulse or ?
This new setting comes because there is a new device connected or do I need to perform something ?
Thank you for your help
You need to install the a2dp app as described above. Then you should be able to connect with MyOSMC or bluetoothctl. Then select Pulseaudio sound server.
Did you install the a2dp package?
After that connection should be possible and the new option for audio will show up.
If your headphones register as headset you might need one more step to change the sink (but we can review that after you connect).
As usual your answer are fast. Thank you
Yes. I had to stop and start osmc to be able to pair my headphones. My headphones told me that I am connected
In the OSMC GUI seems to be ok
in system settings audio i switch to something like Pulse audio server
At the moment I have no sound but this is the first test.
Then your problem seems the headset issue. Check this thread
Ok i have the sound.
Question
Now I can switch in the audio settings to use the standard speaker and i want to come back to my headphones i will have to re do these commands ?
Again thank you for your help patience and hope everything is ok at home for you
No, normally when your headset is disconnected sound will go to HDMI. If you switch your headset on it should auto connect and sound should switch to Bluetooth
Hello, osmc community. Really difficult to find in this thread something to create working solution.
I propose to separate topic on two branches:
What do you think?
The solution to both of these still involves installing the same package.
Thanks for reply!
I have been installed sudo apt-get install a2dp-app-osmc
And see ALSA audio as for audio output. (Osmc to BT)
But do not find how to stream from Bluetooth to jack (BT to Osmc)
Updated:
Just paired device. And its worked!!!
Hi @sam_nazarko
I am using a RPi 3 with my Teufel Stereo L speakers connected via Bluetooth. I am streaming a movie from my Plex server over the Plex plugin (but this also happens when streaming straight from OSMC) and the sound is lagging behind a little, just enough so it gets annoying once you catch on. Is there any way how this could be improved? How can I check if it is due to the BT connection? Over 3.5mm jack it works w/o issues but I don’t like cables
You will find better performance using an external Bluetooth dongle.
After poring over multiple posts for the better part of the past 2 days with little progress, I am hoping someone would be able to help me out here
Objective :
To connect my Sony WH-1000XM3 headset with OSMC running on RPi3
Progress :
osmc@osmc:~$ sudo apt install a2dp-app-osmc Reading package lists... Done Building dependency tree Reading state information... Done a2dp-app-osmc is already the newest version (1.1.3). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[WH-1000XM3]# info CC:98:8B:B1:8B:84 Device CC:98:8B:B1:8B:84 Name: LE_WH-1000XM3 Alias: LE_WH-1000XM3 Paired: yes Trusted: yes Blocked: no Connected: yes LegacyPairing: no UUID: Vendor specific (00000000-deca-fade-deca-deafdecacaff) UUID: Headset (00001108-0000-1000-8000-00805f9b34fb) UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb) UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb) UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb) UUID: Handsfree (0000111e-0000-1000-8000-00805f9b34fb) UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb) UUID: Generic Access Profile (00001800-0000-1000-8000-00805f9b34fb) UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb) UUID: Unknown (0000fe03-0000-1000-8000-00805f9b34fb) UUID: Vendor specific (5b833e05-6bc7-4802-8e9a-723ceca4bd8f) UUID: Vendor specific (5b833e06-6bc7-4802-8e9a-723ceca4bd8f) UUID: Vendor specific (69a7f243-e52f-4443-a7f9-cb4d053c74d6) UUID: Vendor specific (7b265b0e-2232-4d45-bef4-bb8ae62f813d) UUID: Vendor specific (81c2e72a-0591-443e-a1ff-05f988593351) UUID: Vendor specific (91c10d9c-aaef-42bd-b6d6-8a648c19213d) UUID: Vendor specific (931c7e8a-540f-4686-b798-e8df0a2ad9f7) UUID: Vendor specific (96cc203e-5068-46ad-b32d-e316f5e069ba) UUID: Vendor specific (b9b213ce-eeab-49e4-8fd9-aa478ed1b26b) UUID: Vendor specific (f8d1fbe4-7966-4334-8024-ff96c9330e15) UUID: Vendor specific (fe59bfa8-7fe3-4a05-9d94-99fadc69faff) Modalias: usb:v054Cp0CD3d0422 ServiceData Key: 0000fe26-0000-1000-8000-00805f9b34fb ServiceData Value: 0x0a ServiceData Value: 0xc9 ServiceData Value: 0x5c ServiceData Key: 0000fe2c-0000-1000-8000-00805f9b34fb ServiceData Value: 0x0a ServiceData Value: 0xc9 ServiceData Value: 0x5c [WH-1000XM3]# quit
The Issue :
After the connection is established there was no sound in the headphones. As suggested in another post, went to change the audio sink to headphone, But…
osmc@osmc:~$ pactl list sources short 0 alsa_output.platform-soc_audio.analog-stereo.monitor module-alsa-card.c s16le 2ch 44100Hz SUSPENDED osmc@osmc:~$ pactl list cards short 0 alsa_card.platform-soc_audio module-alsa-card.c
The bluetooth entry wasn’t showing at all. Did some more digging and as per another post, changed audio output to ALSA:Playback/recording through the PulseAudio sound server. After that the above source status changed from SUSPENDED to IDLE, but still no sound.
0 alsa_output.platform-soc_audio.analog-stereo.monitor module-alsa-card.c s16le 2ch 44100Hz SUSPENDED osmc@osmc:~$ pactl list sources short 0 alsa_output.platform-soc_audio.analog-stereo.monitor module-alsa-card.c s16le 2ch 48000Hz IDLE
I couldn’t find anymore details that could help me troubleshoot this any further. I did find the below from dmesg
[Fri Apr 10 10:14:45 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 10:14:45 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 10:14:45 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 10:14:45 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 10:14:45 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 10:14:45 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 10:32:16 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 10:32:16 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 10:33:53 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 10:33:53 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 10:33:53 2020] Bluetooth: hci0: Frame reassembly failed (-90) [Fri Apr 10 10:33:53 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 10:56:51 2020] NET: Registered protocol family 38 [Fri Apr 10 11:13:34 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 11:38:44 2020] Console: switching to colour frame buffer device 240x67 [Fri Apr 10 11:38:46 2020] Console: switching to colour dummy device 80x30 [Fri Apr 10 11:39:13 2020] input: VNCServer Mouse as /devices/virtual/input/input2 [Fri Apr 10 11:39:13 2020] input: VNCServer Keyboard as /devices/virtual/input/input3 [Fri Apr 10 12:28:53 2020] Bluetooth: hci0: Frame reassembly failed (-90) [Fri Apr 10 12:28:53 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 12:28:53 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 12:28:53 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 12:28:53 2020] Bluetooth: hci0: Frame reassembly failed (-84) [Fri Apr 10 12:28:53 2020] Bluetooth: hci0: Frame reassembly failed (-84) osmc@osmc:~$ hciconfig -a hci0: Type: Primary Bus: UART BD Address: B8:27:EB:DB:69:DE ACL MTU: 1021:8 SCO MTU: 64:1 UP RUNNING PSCAN RX bytes:208692 acl:274 sco:0 events:6224 errors:0 TX bytes:17443 acl:226 sco:0 commands:1264 errors:0 Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87 Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3 Link policy: RSWITCH SNIFF Link mode: SLAVE ACCEPT Name: 'osmc' Class: 0x00041c Service Classes: Unspecified Device Class: Audio/Video, Portable Audio HCI Version: 4.1 (0x7) Revision: 0x168 LMP Version: 4.1 (0x7) Subversion: 0x2209 Manufacturer: Broadcom Corporation (15)
I also tried to connect a JBL Go 2 bluetooth speaker to see if that would connect, but for some reason it disconnected immediately after connecting. My primary goal is to get my headphones working, so I’ll stick to troubleshooting that for now
Edit: kodi.log
There had been indifferent results been achieved with the built-in module, best to use an external dongle.
Your pactl list sources short doesn’t look right there are no bluez entries at all.
Try via command line
kodi.log alone doesn’t help, post full logs via grab-logs -A
Yep, am aware of this, but was trying my luck here to see how far I can go.
I did notice that. It was different from other logs in the various posts and I was hoping there is something else amiss here
Yes, it was through command line. Logs below
[bluetooth]# connect 70:99:1C:08:6F:F5 Attempting to connect to 70:99:1C:08:6F:F5 Failed to connect: org.bluez.Error.Failed [bluetooth]# info 70:99:1C:08:6F:F5 Device 70:99:1C:08:6F:F5 Name: JBL GO 2 Alias: JBL GO 2 Class: 0x200414 Icon: audio-card Paired: yes Trusted: yes Blocked: no Connected: no LegacyPairing: no UUID: Headset (00001108-0000-1000-8000-00805f9b34fb) UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb) UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb) UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb) UUID: Handsfree (0000111e-0000-1000-8000-00805f9b34fb) [bluetooth]# connect 70:99:1C:08:6F:F5 Attempting to connect to 70:99:1C:08:6F:F5 Failed to connect: org.bluez.Error.Failed [bluetooth]# quit
I have seen that before, sometimes a reboot helps sometimes I needed to purge the whole bluetooth setup and reinstall it.
I saw Apr 10 10:08:05 osmc bluetoothd[460]: a2dp-sink profile connect failed for CC:98:8B:B1:8B:84: Protocol not available
That could be part of the problem
But seems same for the JBL, a2dp-sink profile connect failed for 70:99:1C:08:6F:F5: Protocol not available
Did you try after a reboot?
If you don’t get it running I could try tomorrow to remove my dongle and try the built-in for my Pi3
I did reboot when trying this earlier, but rebooting again now
osmc@osmc:~$ bluetoothctl [NEW] Controller B8:27:EB:DB:69:DE osmc [default] [bluetooth]# scan on Discovery started [CHG] Controller B8:27:EB:DB:69:DE Discovering: yes [NEW] Device CC:98:8B:B1:8B:84 WH-1000XM3 [NEW] Device C8:84:47:58:6A:A6 YamahaAV [NEW] Device 77:72:78:63:97:61 77-72-78-63-97-61 [CHG] Device CC:98:8B:B1:8B:84 Name: LE_WH-1000XM3 [CHG] Device CC:98:8B:B1:8B:84 Alias: LE_WH-1000XM3 [NEW] Device 7D:8F:D5:8F:16:4A 7D-8F-D5-8F-16-4A [NEW] Device 47:93:18:B5:4E:E0 47-93-18-B5-4E-E0 [NEW] Device 00:7C:2D:EE:24:D7 [TV] JCTV Samsung [NEW] Device 29:90:1D:EF:F3:5B 29-90-1D-EF-F3-5B [NEW] Device 47:16:18:69:9B:01 47-16-18-69-9B-01 [bluetooth]# scan off [CHG] Device 47:16:18:69:9B:01 TxPower is nil [CHG] Device 47:16:18:69:9B:01 RSSI is nil [CHG] Device 29:90:1D:EF:F3:5B RSSI is nil [CHG] Device 00:7C:2D:EE:24:D7 RSSI is nil [CHG] Device 47:93:18:B5:4E:E0 TxPower is nil [CHG] Device 47:93:18:B5:4E:E0 RSSI is nil [CHG] Device 7D:8F:D5:8F:16:4A RSSI is nil [CHG] Device 77:72:78:63:97:61 TxPower is nil [CHG] Device 77:72:78:63:97:61 RSSI is nil [CHG] Device C8:84:47:58:6A:A6 RSSI is nil [CHG] Device CC:98:8B:B1:8B:84 RSSI is nil Discovery stopped [CHG] Controller B8:27:EB:DB:69:DE Discovering: no [bluetooth]# trust 00:7C:2D:EE:24:D7 47:16:18:69:9B:01 77:72:78:63:97:61 C8:84:47:58:6A:A6 29:90:1D:EF:F3:5B 47:93:18:B5:4E:E0 7D:8F:D5:8F:16:4A CC:98:8B:B1:8B:84 [bluetooth]# trust CC:98:8B:B1:8B:84 [CHG] Device CC:98:8B:B1:8B:84 Trusted: yes Changing CC:98:8B:B1:8B:84 trust succeeded [bluetooth]# info 00:7C:2D:EE:24:D7 47:16:18:69:9B:01 77:72:78:63:97:61 C8:84:47:58:6A:A6 29:90:1D:EF:F3:5B 47:93:18:B5:4E:E0 7D:8F:D5:8F:16:4A CC:98:8B:B1:8B:84 [bluetooth]# info CC:98:8B:B1:8B:84 Device CC:98:8B:B1:8B:84 Name: LE_WH-1000XM3 Alias: LE_WH-1000XM3 Paired: no Trusted: yes Blocked: no Connected: no LegacyPairing: no ManufacturerData Key: 0x012d ManufacturerData Value: 0x04 ManufacturerData Value: 0x00 ManufacturerData Value: 0x01 ManufacturerData Value: 0x31 ManufacturerData Value: 0x00 ManufacturerData Value: 0x01 ManufacturerData Value: 0x7d ManufacturerData Value: 0x73 ManufacturerData Value: 0xf3 ManufacturerData Value: 0x38 ManufacturerData Value: 0x00 ManufacturerData Value: 0x60 ManufacturerData Value: 0xd0 ManufacturerData Value: 0x00 ManufacturerData Value: 0x00 ManufacturerData Value: 0x00 ManufacturerData Value: 0x00 ManufacturerData Value: 0x00 ManufacturerData Value: 0x00 [bluetooth]# pair CC:98:8B:B1:8B:84 Attempting to pair with CC:98:8B:B1:8B:84 [CHG] Device CC:98:8B:B1:8B:84 Connected: yes [NEW] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0001 00001801-0000-1000-8000-00805f9b34fb Generic Attribute Profile [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0001/char0002 00002a05-0000-1000-8000-00805f9b34fb Service Changed [NEW] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0001/char0002/desc0004 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [NEW] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service000a 69a7f243-e52f-4443-a7f9-cb4d053c74d6 Vendor specific [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service000a/char000b be8692b1-3b29-410d-94d3-50281940553e Vendor specific [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service000a/char000d 3f92019d-ac1d-48dc-9d94-86a0fb507591 Vendor specific [NEW] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service000a/char000d/desc000f 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service000a/char0010 5bc06a57-f84d-4086-a65a-2a238cb39cdb Vendor specific [NEW] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012 fe59bfa8-7fe3-4a05-9d94-99fadc69faff Vendor specific [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char0013 104c022e-48d6-4dd2-8737-f8ac5489c5d4 Vendor specific [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char0015 69745240-ec29-4899-a2a8-cf78fd214303 Vendor specific [NEW] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char0015/desc0017 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char0018 70efdf00-4375-4a9e-912d-63522566d947 Vendor specific [NEW] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char0018/desc001a 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char001b eea2e8a0-89f0-4985-a1e2-d91dc4a52632 Vendor specific [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char001d a79e2bd1-d6e4-4d1e-8b4f-141d69011cbb Vendor specific [NEW] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f 91c10d9c-aaef-42bd-b6d6-8a648c19213d Vendor specific [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0020 99d1064e-4517-46aa-8fb4-6be64dd1a1f1 Vendor specific [NEW] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0020/desc0022 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0023 fbe87f6c-3f1a-44b6-b577-0bac731f6e85 Vendor specific [NEW] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0023/desc0025 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0026 420791c0-bff5-4bd1-b957-371614031136 Vendor specific [NEW] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0026/desc0028 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0029 e4ef5a46-30f9-4287-a3e7-643066acb768 Vendor specific [NEW] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0029/desc002b 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [NEW] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service002c 0000fe03-0000-1000-8000-00805f9b34fb Unknown [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service002c/char002d f04eb177-3005-43a7-ac61-a390ddf83076 Vendor specific [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service002c/char002f 2beea05b-1879-4bb4-8a2f-72641f82420b Vendor specific [NEW] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service002c/char002f/desc0031 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [NEW] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0032 5b833e05-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0032/char0033 5b833c11-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0032/char0035 5b833c13-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [NEW] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0032/char0035/desc0037 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0032/char0038 5b833c14-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [NEW] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service003a 5b833e06-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service003a/char003b 5b833c10-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [NEW] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service003a/char003d 5b833c12-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [NEW] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service003a/char003d/desc003f 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 00001800-0000-1000-8000-00805f9b34fb [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 00001801-0000-1000-8000-00805f9b34fb [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 0000fe03-0000-1000-8000-00805f9b34fb [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 5b833e05-6bc7-4802-8e9a-723ceca4bd8f [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 5b833e06-6bc7-4802-8e9a-723ceca4bd8f [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 69a7f243-e52f-4443-a7f9-cb4d053c74d6 [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 91c10d9c-aaef-42bd-b6d6-8a648c19213d [CHG] Device CC:98:8B:B1:8B:84 UUIDs: fe59bfa8-7fe3-4a05-9d94-99fadc69faff [CHG] Device CC:98:8B:B1:8B:84 ServicesResolved: yes [CHG] Device CC:98:8B:B1:8B:84 Paired: yes Pairing successful [LE_WH-1000XM3]# connect CC:98:8B:B1:8B:84 Attempting to connect to CC:98:8B:B1:8B:84 [CHG] Device CC:98:8B:B1:8B:84 Name: WH-1000XM3 [CHG] Device CC:98:8B:B1:8B:84 Alias: WH-1000XM3 [CHG] Device CC:98:8B:B1:8B:84 Modalias: usb:v054Cp0CD3d0422 [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 00000000-deca-fade-deca-deafdecacaff [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 00001108-0000-1000-8000-00805f9b34fb [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 0000110b-0000-1000-8000-00805f9b34fb [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 0000110c-0000-1000-8000-00805f9b34fb [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 0000110e-0000-1000-8000-00805f9b34fb [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 0000111e-0000-1000-8000-00805f9b34fb [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 00001200-0000-1000-8000-00805f9b34fb [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 00001800-0000-1000-8000-00805f9b34fb [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 00001801-0000-1000-8000-00805f9b34fb [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 0000fe03-0000-1000-8000-00805f9b34fb [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 5b833e05-6bc7-4802-8e9a-723ceca4bd8f [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 5b833e06-6bc7-4802-8e9a-723ceca4bd8f [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 69a7f243-e52f-4443-a7f9-cb4d053c74d6 [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 7b265b0e-2232-4d45-bef4-bb8ae62f813d [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 81c2e72a-0591-443e-a1ff-05f988593351 [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 91c10d9c-aaef-42bd-b6d6-8a648c19213d [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 931c7e8a-540f-4686-b798-e8df0a2ad9f7 [CHG] Device CC:98:8B:B1:8B:84 UUIDs: 96cc203e-5068-46ad-b32d-e316f5e069ba [CHG] Device CC:98:8B:B1:8B:84 UUIDs: b9b213ce-eeab-49e4-8fd9-aa478ed1b26b [CHG] Device CC:98:8B:B1:8B:84 UUIDs: f8d1fbe4-7966-4334-8024-ff96c9330e15 [CHG] Device CC:98:8B:B1:8B:84 UUIDs: fe59bfa8-7fe3-4a05-9d94-99fadc69faff Connection successful [CHG] Device CC:98:8B:B1:8B:84 ServicesResolved: no [WH-1000XM3]# info CC:98:8B:B1:8B:84 Device CC:98:8B:B1:8B:84 Name: WH-1000XM3 Alias: WH-1000XM3 Paired: yes Trusted: yes Blocked: no Connected: yes LegacyPairing: no UUID: Vendor specific (00000000-deca-fade-deca-deafdecacaff) UUID: Headset (00001108-0000-1000-8000-00805f9b34fb) UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb) UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb) UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb) UUID: Handsfree (0000111e-0000-1000-8000-00805f9b34fb) UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb) UUID: Generic Access Profile (00001800-0000-1000-8000-00805f9b34fb) UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb) UUID: Unknown (0000fe03-0000-1000-8000-00805f9b34fb) UUID: Vendor specific (5b833e05-6bc7-4802-8e9a-723ceca4bd8f) UUID: Vendor specific (5b833e06-6bc7-4802-8e9a-723ceca4bd8f) UUID: Vendor specific (69a7f243-e52f-4443-a7f9-cb4d053c74d6) UUID: Vendor specific (7b265b0e-2232-4d45-bef4-bb8ae62f813d) UUID: Vendor specific (81c2e72a-0591-443e-a1ff-05f988593351) UUID: Vendor specific (91c10d9c-aaef-42bd-b6d6-8a648c19213d) UUID: Vendor specific (931c7e8a-540f-4686-b798-e8df0a2ad9f7) UUID: Vendor specific (96cc203e-5068-46ad-b32d-e316f5e069ba) UUID: Vendor specific (b9b213ce-eeab-49e4-8fd9-aa478ed1b26b) UUID: Vendor specific (f8d1fbe4-7966-4334-8024-ff96c9330e15) UUID: Vendor specific (fe59bfa8-7fe3-4a05-9d94-99fadc69faff) Modalias: usb:v054Cp0CD3d0422 ManufacturerData Key: 0x012d ManufacturerData Value: 0x04 ManufacturerData Value: 0x00 ManufacturerData Value: 0x01 ManufacturerData Value: 0x31 ManufacturerData Value: 0x00 ManufacturerData Value: 0x01 ManufacturerData Value: 0x7d ManufacturerData Value: 0x73 ManufacturerData Value: 0xf3 ManufacturerData Value: 0x38 ManufacturerData Value: 0x00 ManufacturerData Value: 0x60 ManufacturerData Value: 0xd0 ManufacturerData Value: 0x00 ManufacturerData Value: 0x00 ManufacturerData Value: 0x00 ManufacturerData Value: 0x00 ManufacturerData Value: 0x00 ManufacturerData Value: 0x00 [WH-1000XM3]# exit [DEL] Controller B8:27:EB:DB:69:DE osmc [default] [DEL] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0001 00001801-0000-1000-8000-00805f9b34fb Generic Attribute Profile [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0001/char0002 00002a05-0000-1000-8000-00805f9b34fb Service Changed [DEL] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0001/char0002/desc0004 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [DEL] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service000a 69a7f243-e52f-4443-a7f9-cb4d053c74d6 Vendor specific [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service000a/char000b be8692b1-3b29-410d-94d3-50281940553e Vendor specific [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service000a/char000d 3f92019d-ac1d-48dc-9d94-86a0fb507591 Vendor specific [DEL] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service000a/char000d/desc000f 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service000a/char0010 5bc06a57-f84d-4086-a65a-2a238cb39cdb Vendor specific [DEL] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012 fe59bfa8-7fe3-4a05-9d94-99fadc69faff Vendor specific [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char0013 104c022e-48d6-4dd2-8737-f8ac5489c5d4 Vendor specific [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char0015 69745240-ec29-4899-a2a8-cf78fd214303 Vendor specific [DEL] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char0015/desc0017 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char0018 70efdf00-4375-4a9e-912d-63522566d947 Vendor specific [DEL] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char0018/desc001a 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char001b eea2e8a0-89f0-4985-a1e2-d91dc4a52632 Vendor specific [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0012/char001d a79e2bd1-d6e4-4d1e-8b4f-141d69011cbb Vendor specific [DEL] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f 91c10d9c-aaef-42bd-b6d6-8a648c19213d Vendor specific [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0020 99d1064e-4517-46aa-8fb4-6be64dd1a1f1 Vendor specific [DEL] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0020/desc0022 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0023 fbe87f6c-3f1a-44b6-b577-0bac731f6e85 Vendor specific [DEL] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0023/desc0025 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0026 420791c0-bff5-4bd1-b957-371614031136 Vendor specific [DEL] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0026/desc0028 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0029 e4ef5a46-30f9-4287-a3e7-643066acb768 Vendor specific [DEL] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service001f/char0029/desc002b 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [DEL] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service002c 0000fe03-0000-1000-8000-00805f9b34fb Unknown [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service002c/char002d f04eb177-3005-43a7-ac61-a390ddf83076 Vendor specific [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service002c/char002f 2beea05b-1879-4bb4-8a2f-72641f82420b Vendor specific [DEL] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service002c/char002f/desc0031 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [DEL] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0032 5b833e05-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0032/char0033 5b833c11-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0032/char0035 5b833c13-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [DEL] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0032/char0035/desc0037 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service0032/char0038 5b833c14-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [DEL] Primary Service /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service003a 5b833e06-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service003a/char003b 5b833c10-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [DEL] Characteristic /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service003a/char003d 5b833c12-6bc7-4802-8e9a-723ceca4bd8f Vendor specific [DEL] Descriptor /org/bluez/hci0/dev_CC_98_8B_B1_8B_84/service003a/char003d/desc003f 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration osmc@osmc:~$ pactl list sources short 0 alsa_output.platform-soc_audio.analog-stereo.monitor module-alsa-card.c s16le 2ch 44100Hz SUSPENDED osmc@osmc:~$
How do I do that?
Both of them are pretty new and I would be surprised if they didn’t support a2dp. I looked up the tech spec and both supports a2dp. In the new logs I don’t see this error.
Tried it again now, see logs above. Here is grab-logs -A
dmesg looks good too, but no progress with the issue though
[Sat Apr 11 13:28:16 2020] Bluetooth: Core ver 2.22 [Sat Apr 11 13:28:16 2020] NET: Registered protocol family 31 [Sat Apr 11 13:28:16 2020] Bluetooth: HCI device and connection manager initialized [Sat Apr 11 13:28:16 2020] Bluetooth: HCI socket layer initialized [Sat Apr 11 13:28:16 2020] Bluetooth: L2CAP socket layer initialized [Sat Apr 11 13:28:16 2020] Bluetooth: SCO socket layer initialized [Sat Apr 11 13:28:16 2020] Bluetooth: HCI UART driver ver 2.3 [Sat Apr 11 13:28:16 2020] Bluetooth: HCI UART protocol H4 registered [Sat Apr 11 13:28:16 2020] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [Sat Apr 11 13:28:16 2020] Bluetooth: BNEP filters: protocol multicast [Sat Apr 11 13:28:16 2020] Bluetooth: BNEP socket layer initialized [Sat Apr 11 13:28:16 2020] Bluetooth: RFCOMM TTY layer initialized [Sat Apr 11 13:28:16 2020] Bluetooth: RFCOMM socket layer initialized [Sat Apr 11 13:28:16 2020] Bluetooth: RFCOMM ver 1.11
'sudo apt-get remove --purge a2dp-app-osmc bluetooth bluez pulseaudio-module-bluetooth`
Well I wasn’t pointing to the speakers, I was pointing to the controller not supporting it.
Might check out my Pi3 later today without my BT Dongle.
