Disk full on EXT4 partition
HI,
Please clarify is the partition called EXT4 and formated as ext4 or is it called EXT4 and formated as fat32, are you sure the partition is labeled as EXT4?
Tom.
The partition is labeled NASEXT now also changed it on fstab. The router does pick it up as I created a folder inside using the router. I see there’s a reserved 50gb dunno if it’s for root or??anyway if I reboot should it mount correctly?
I think it’s fixed
osmc@osmc:/mnt/NAS$ df
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 370520 0 370520 0% /dev
tmpfs 375512 5304 370208 2% /run
/dev/mmcblk0p2 15022000 1627668 12608208 12% /
tmpfs 375512 0 375512 0% /dev/shm
tmpfs 5120 0 5120 0% /run/lock
tmpfs 375512 0 375512 0% /sys/fs/cgroup
//192.168.1.2/NAS/ 1026536408 789200500 237335908 77% /mnt/NAS
//192.168.1.2/NASEXT/ 868946452 46379864 822566588 6% /mnt/NAS_OSMC
/dev/mmcblk0p1 244988 21004 223985 9% /boot
/dev/sda1 976726012 953878820 22847192 98% /media/My Passport
tmpfs 75104 0 75104 0% /run/user/1000
looks good to me, is transmission now working as expected?
tom
it appears so, thanks everyone who helped really appreciate it.
Glad it is sorted.
Thanks Tom.
