We have a fix for the Aerial screensaver. It may help with your issue and I suggest you check after the next release.
Hopefully the issue is now addressed with the following commit:
Iād appreciate it if you could test this and provide feedback before we potentially release this as an update to other users. To test this update:
- Login via the command line
- Run the following command to add the staging repository:
echo 'deb http://apt.osmc.tv bullseye-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list - Go to My OSMC ā Updater ā Manual Controls ā and select Check for Updates now. When prompted to do so on screen, please choose to install the update.
- Your system should have have received the update.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
