Thanks but unfortunately not what I’m looking for. I think you should be able to provide the service file with:
cat /lib/systemd/system/wg-quick.service | paste-log
Conf file as follows:
cat /etc/wireguard/Toronto.conf | paste-log
Or if contains any login credentials you may wish to copy and modify before uploading:
cp /etc/wireguard/Toronto.conf ~
modify with nano or vi to remove any credentials: nano ~/Toronto.conf
Then upload:
cat ~/Toronto.conf | paste-log
Regards Tom.
Please provide the out of: systemctl status wg-quick
Thanks Tom.
Tom try this, a start and stop of wg-quick.
https://paste.osmc.tv/ceyipokopo.avrasm
Also here is my current wg0.conf
http://paste.osmc.tv/ufozagerek.vala
My current setup works correctly with these commands
systemctl enable wg-quick@wgo - boots with IP and DNS provided by Surfshark
or if not enabled
systemctl start wg-quick@wgo
What still is not working
systemctl stop wg-quick@wgo - the original DNS I provided in network setup is lost
/etc/resolv.conf is empty.
Is this with openresolv or resolvconf
Also please provide the link from:
cat /lib/systemd/system/wg-quick@.service | paste-log
Thanks Tom.
Thanks Tom got it. Did a fresh os install turned instructions into a script bingo, everything worked.
Went back to the other sdcard and purged resolvconf, worked. Connman wasn’t the problem.
Weird how manual worked but systemctl didn’t.
Once again thanks
just in case sb stumbles over this topic (as I did) and finds the pastes are gone (as expected), I shared a small pseudo-tutorial on the other thread:
just in case somebody stumbles over this topic trying to configure wireguard (as I did) and hitting a dead end as the pastes in the linked thread are down by now (as expected), I share with you my pseudo-tutorial (what eventually worked for me) to set up a Vero as a WireGuard “client”:
ssh to your Vero
first we install wireguard and openresolv, which you need if you want to provide a DNS in your conf
sudo apt install wireguard-tools
sudo apt install openresolv
now we configure the client …
