I formatted the drive on my Ubuntu laptop. It works fine when connected to the laptop.
I’ll format a USB drive and write some files to it and see if I can reproduce.
I installed btrfs-progs on Vero V:
root@osmc:/home/osmc# apt-get update && apt-get install btrfs-progs
Get:1 https://deb.debian.org/debian bullseye InRelease [116 kB]
Get:2 https://security.debian.org bullseye-security InRelease [48.4 kB]
Get:4 https://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Get:3 https://ftp.fau.de/osmc/osmc/apt bullseye InRelease [4683 B]
Get:5 https://deb.debian.org/debian bullseye/main armhf Packages [7842 kB]
Get:6 https://security.debian.org bullseye-security/main armhf Packages [275 kB]
Get:7 https://security.debian.org bullseye-security/main arm64 Packages [274 kB]
Get:8 https://security.debian.org bullseye-security/main Translation-en [178 kB]
Get:9 https://security.debian.org bullseye-security/non-free Translation-en [472 B]
Get:10 https://deb.debian.org/debian bullseye/main arm64 Packages [7957 kB]
Get:11 https://ftp.fau.de/osmc/osmc/apt bullseye/main armhf Packages [32.4 kB]
Get:12 https://ftp.fau.de/osmc/osmc/apt bullseye/main arm64 Packages [39.2 kB]
Get:13 https://deb.debian.org/debian bullseye/main Translation-en [6236 kB]
Get:14 https://deb.debian.org/debian bullseye/contrib armhf Packages [40.1 kB]
Get:15 https://deb.debian.org/debian bullseye/contrib arm64 Packages [40.8 kB]
Get:16 https://deb.debian.org/debian bullseye/contrib Translation-en [46.9 kB]
Get:17 https://deb.debian.org/debian bullseye/non-free arm64 Packages [72.3 kB]
Get:18 https://deb.debian.org/debian bullseye/non-free armhf Packages [56.0 kB]
Get:19 https://deb.debian.org/debian bullseye/non-free Translation-en [92.2 kB]
Get:20 https://deb.debian.org/debian bullseye-updates/main arm64 Packages [16.3 kB]
Get:21 https://deb.debian.org/debian bullseye-updates/main armhf Packages [16.3 kB]
Get:22 https://deb.debian.org/debian bullseye-updates/main Translation-en [10.9 kB]
Fetched 22.0 MB in 10s (2132 kB/s)
Reading package lists... Done
Building dependency tree... Done
Suggested packages:
duperemove
btrfs-progs
0 upgraded, 1 newly installed, 0 to remove and 10 not upgraded.
Need to get 656 kB of archives.
After this operation, 3316 kB of additional disk space will be used.
Get:1 https://deb.debian.org/debian bullseye/main armhf btrfs-progs armhf 5.10.1-2 [656 kB]
Fetched 656 kB in 0s (2605 kB/s)
Made a filesystem with attached media:
root@osmc:/home/osmc# mkfs.btrfs /dev/sda1 -f
btrfs-progs v5.10.1
See http://btrfs.wiki.kernel.org for more information.
Label: (null)
UUID: 09bbe1b6-e116-4270-a5a1-b4a8d496a91a
Node size: 16384
Sector size: 4096
Filesystem size: 316.00MiB
Block group profiles:
Data: single 8.00MiB
Metadata: DUP 32.00MiB
System: DUP 8.00MiB
SSD detected: no
Incompat features: extref, skinny-metadata
Runtime features:
Checksum: crc32c
Number of devices: 1
Devices:
ID SIZE PATH
1 316.00MiB /dev/sda1
Writing to the drive and filesystem seems fine:
root@osmc:/home/osmc# dd if=/dev/urandom of=/mnt/testfile bs=1M count=128 conv=fdatasync
128+0 records in
128+0 records out
134217728 bytes (134 MB, 128 MiB) copied, 6.96191 s, 19.3 MB/s
Your btrfs-progs seems quite old. Which version of Ubuntu are you using? Have you tried formatting the drive on the Vero V?
I recently started moving all external storage to btrfs since its COW nature was more resilient during accident power lost.
A 512G micro SD card formatted on Fedora 40 with 6.11 works fine on Vero 4K with latest update.
I’m in the process to move to a 18T external drive. I will report back how Btrfs on that works with Vero 4K later.
Allow me to provide more updates after using btrfs extensively with Vero 4K from last month:
- For almost all cases, it works just like ext4 formatted one on this 18T external drive.
- While using FTP transfer (Server: vsftpd; Client: FileZilla), there would be occasionally speed drop during large file transfer. It can complete with no error, but slower than ext4 formatted one.
- In last week, a kernel error was hitting, probably due to a long aria2 seeding session. This renders the disk not recognizable by the Vero 4K. After rebooting, the system returns to the normal status, without any files lost. Errors from
dmesgwere printed like below:
[1692937.696588] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 1, rd 0, flush 0, corrupt 0, gen 0
[1692937.696603] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 2, rd 0, flush 0, corrupt 0, gen 0
[1692937.696929] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 3, rd 0, flush 0, corrupt 0, gen 0
[1692937.696941] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 4, rd 0, flush 0, corrupt 0, gen 0
[1692937.697214] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 5, rd 0, flush 0, corrupt 0, gen 0
[1692937.697225] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 6, rd 0, flush 0, corrupt 0, gen 0
[1692937.697648] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 7, rd 0, flush 0, corrupt 0, gen 0
[1692937.697659] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 8, rd 0, flush 0, corrupt 0, gen 0
[1692937.698082] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 9, rd 0, flush 0, corrupt 0, gen 0
[1692937.698095] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 10, rd 0, flush 0, corrupt 0, gen 0
[1692948.720840] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 10, rd 1, flush 0, corrupt 0, gen 0
[1692948.721186] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 10, rd 2, flush 0, corrupt 0, gen 0
[1692983.014150] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 10, rd 3, flush 0, corrupt 0, gen 0
[1692983.014460] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 10, rd 4, flush 0, corrupt 0, gen 0
[1692991.494405] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 10, rd 5, flush 0, corrupt 0, gen 0
[1692992.945727] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 10, rd 6, flush 0, corrupt 0, gen 0
[1692992.946829] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 10, rd 7, flush 0, corrupt 0, gen 0
[1692993.941615] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 10, rd 8, flush 0, corrupt 0, gen 0
[1692993.941785] BTRFS error (device sda1): bdev /dev/sdb1 errs: wr 10, rd 9, flush 0, corrupt 0, gen 0
I guess I will continously using btrfs on this external drive with Vero 4K for now.
