Make sure you don’t have dtoverlay=sdhost in /boot/config.txt[quote=“Andrea_Bisello, post:61, topic:430”]
i activated wifi in by sudo nano /var/lib/connman/settings and then i rebooted.
[/quote]
You should not edit any files under /var/lib/connman manually, instead use connmanctl.
There is no need to “enable” wifi by editing these files - if the wifi adaptor is found Wireless will appear in MyOSMC -> Network, or in technologies in connmanctl.
thanks DBMandrake, i will continue this discussion in the raspberry pi 3 wifi thread (Raspberry Pi 3 - ***Wifi Mega Thread*** - #54 by Andrea_Bisello) because i think is a better post for my problem, due i have a raspberry pi 3.
thanks again
A better post would have been starting your own thread. Please do this in future.
trying to follow this guide Enable wifi under GUI but when I type connmanctl command I get error… getting vpn connections the name .net connman.vpn was not provided by any …and also connmanctl unknown command ???
i try to use the Netgear G54/N150 but all i’ve tried fail…
[ 3.207276] usb 1-1.2: new high-speed USB device number 4 using dwc_otg [ 3.308609] usb 1-1.2: New USB device found, idVendor=0846, idProduct=9043 [ 3.308635] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 3.308648] usb 1-1.2: Product: WNA1000Mv2 [ 3.308659] usb 1-1.2: Manufacturer: Realtek [ 3.308671] usb 1-1.2: SerialNumber: 00e04c000001
Any idea?
