You have to describe how you are attempting to do this if we have any chance of figuring or why it’s failing.
I have tried several methods:
- in program- my osmc addon I have written the license directly in its apart
- in program- my osmc addon I have edited config.txt and add new line with "decode_MPG2=XXXXXXXXX
In both cases negative result
Finally I tried to download the config.txt and edit it in my pc but I have no permission to modify it, so could it be a problem of permission and that’s why it cannot be modified?
Have you verified it is the right licence for the device?
Provide logs with grab-logs -A
I assume you use a program like winscp. The files in /boot can only be written by root. So if you manually want to change it either copy to /home/osmc with winscp and then login with ssh and move it with sudo mv.
Alternatively just ssh in and change it with sudo nano /boot/config.txt
this is the log
http://paste.osmc.io/erumatayux
MY MISTAKE!!! VERY SORRY!!! I introduced wrong linceses!!!
very very sorry!!
