Galaxy Bluetooth earbuds no sound
Raised the issue.
Now I have a strange stuttering video issue. Any chance the modifications we did regarding alsa caused it?
Not if you are using your default audio output (?HAT) and no BT devices are connected.
Can you give him bluealsa-aplay -l? (with the buds connected, I guess).
Sure, but don’t know how to rebuild with debug.
No. We would have to do that. bluealsa-aplay will work anyway.
I’ve connected the buds again to provide the blealsa-aplay -l
Afterwards, I’ve chosen Galaxy Buds+ from the Audio settings just to try one more time and it worked.
Ran the test and it works also:
osmc@osmc:~$ speaker-test -D galaxybuds -c 2 -p 1 -t wav -l 3
speaker-test 1.1.8
Playback device is galaxybuds
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 960 to 4194304
Period size range from 480 to 4096
Requested period time 1 us
Periods = 4
was set period_size = 480
was set buffer_size = 1920
 0 - Front Left
 1 - Front Right
Time per period = 2.982257
 0 - Front Left
 1 - Front Right
Time per period = 3.009906
 0 - Front Left
 1 - Front Right
Time per period = 3.009312
Is there any chance your phone is grabbing the connection??
No, I’ve made sure the only phone in the house that is paired up with the buds has it’s bluetooth turned off.
Plus, it can only be connected with one device, so I would not be able to connect to it if some other device grabbed the connection.
And after a reboot, the stuttering is gone, but I don’t have the sound on the buds anymore…
speaker-test 1.1.8
WAV file(s)
Periods = 4
Unable to set hw params for playback: Device or resource busy
Setting of hwparams failed: Device or resource busy
I’ve managed to figure it out.
So, if you get the buds out of their case and then connect them with rpi it won’t work, but if I leave them in the case, enable bluetooth and then get them out, they will automatically connect to rpi and work.
Tried it 3 times and this is definitely the way to make them work.
They need to connect automatically, otherwise they won’t work.
Interesting. But the other buds can be connected from either side?
I’ll try this now. First need to add them to the .asoundrc file.
Should I use the same logic as fir buds, e.g.:
pcm.enacfirefuture {
        type plug
        slave.pcm {
        type bluealsa
        device "00:00:90:B0:EF:77"
        profile "a2dp"
        hint { show on description "ENACFIRE Future"}
Yes, that should do it. Arkq is saying the automatic ā€˜use the last connected device’ should work just as well. We’ll do some more testing here.
You can revert to the way we do it now (and in the future) with
cd /etc/alsa/conf.d
sudo ln -s /usr/share/alsa/alsa.conf.d/21-bt-audio-osmc.conf 21-bt-audio-osmc.conf
and delete/rename .asoundrc. I’d love to know whether that works with the connect method you have found.
Tried it with ENACFIRE and additional entry in .asoundrc
Works both ways with them, automatic connection or manual.
I’ll revert back to the current way and test both headsets.
Reverted back per your instructions.
I can connect to buds using the automatic way, it still doesn’t work if I connect manually.
Enacfire works fine either way.
The problem I have is that after I start watching something, video starts stuttering in less then a minute. Videos that have been playing well before are behaving like this.
Reboot didn’t help either.
If I get that, pausing and restarting the video fixes it.
It looks like the latest update resolved the issue.
Video playback is working now, no problems.
@grahamh thanks for all the help, this topic can be closed now unless you need me to do more testing.
