Yes space separated, but with your output and not mine, so probably not media-externalHD.mount but your 3 disks. If you’re still confused please post the output from; sudo systemctl list-units --type=mount
I will then post what you should have. If that doesn’t work, you’re on your own
I’ve no experience of nzbget, but I do have a few observations/recommendations:
1 Instead of using network.target, I’d recommend that you use network-online.target and ensure that connman-wait-for-network.service is also enabled. After the After = line, add one more line:
Wants = network-online.target
2 What happens if you try to run the ExecStart command /opt/nzbget/nzbget -c /opt/nzbget/nzbget.conf -D from the command line? (With and without the -D.)
3 Close your SSH port on the router:
Jan 07 20:34:24 HTPC sshd[2149]: Failed password for root from 218.92.1.179 port 28175 ssh2
That IP address is coming from China. If you were using the default password for user osmc, it’s very possible that your device has been hacked by now.
I’ll give 1. a shot.
2 - with the -D there is no output, the command just runs, without , we have the following
osmc@HTPC:~$ /opt/nzbget/nzbget -c /opt/nzbget/nzbget.conf
Nzb-file or Url not specified
Usage:
nzbget [switches]
Switches:
-h, --help Print this help-message
-v, --version Print version and exit
-c, --configfile Filename of configuration-file
-n, --noconfigfile Prevent loading of configuration-file
(required options must be passed with --option)
-p, --printconfig Print configuration and exit
-o, --option <name=value> Set or override option in configuration-file
-s, --server Start nzbget as a server in console-mode
-D, --daemon Start nzbget as a server in daemon-mode
-V, --serverversion Print server’s version and exit
-Q, --quit Shutdown server
-O, --reload Reload config and restart all services
-A, --append [] <nzb-file/url> Send file/url to server’s
download queue
are (multiple options must be separated with space):
T Add file to the top (beginning) of queue
P Pause added files
C Assign category to nzb-file
N Use this name as nzb-filename
I Set priority (signed integer)
DK Set duplicate key (string)
DS Set duplicate score (signed integer)
DM (score|all|force) Set duplicate mode
-C, --connect Attach client to server
-L, --list [F|FR|G|GR|O|H|S] [RegEx] Request list of items from server
F List individual files and server status (default)
FR Like “F” but apply regular expression filter
G List groups (nzb-files) and server status
GR Like “G” but apply regular expression filter
O List post-processor-queue
H List history
HA List history, all records (incl. hidden)
S Print only server status
Regular expression (only with options “FR”, “GR”)
using POSIX Extended Regular Expression Syntax
-P, --pause [D|O|S] Pause server
D Pause download queue (default)
O Pause post-processor queue
S Pause scan of incoming nzb-directory
-U, --unpause [D|O|S] Unpause server
D Unpause download queue (default)
O Unpause post-processor queue
S Unpause scan of incoming nzb-directory
-R, --rate Set download rate on server, in KB/s
-G, --log Request last lines from server’s screen-log
-W, --write <D|I|W|E|G> “Text” Send text to server’s log
-S, --scan [W] Scan incoming nzb-directory on server
W Wait until scan completes (synchronous mode)
-E, --edit [F|FN|FR|G|GN|GR|O|H] <IDs/Names/RegExs> Edit items
on server
F Edit individual files (default)
FN Like “F” but uses names (as “group/file”)
instead of IDs
FR Like “FN” but with regular expressions
G Edit all files in the group (same nzb-file)
GN Like “G” but uses group names instead of IDs
GR Like “GN” but with regular expressions
O Edit post-processor-queue
H Edit history
is one of:
- for files (F) and groups (G):
<+offset|-offset> Move in queue relative to current position,
offset is an integer value
T Move to top of queue
B Move to bottom of queue
D Delete
P Pause
U Resume (unpause)
- for groups (G):
A Pause all pars
R Pause extra pars
DP Delete but keep downloaded files
C Set category
CP Set category and apply post-process parameters
N Rename
M Merge
SF Sort inner files for optimal order
S Split - create new group from selected files
O = Set post-process parameter
- for post-jobs (O):
D Delete (cancel post-processing)
- for history (H):
D Delete
P Post-process again
R Download remaining files
A Download again
F Retry download of failed articles
B Mark as bad
G Mark as good
S Mark as success
Comma-separated list of file- or group- ids or
ranges of file-ids, e. g.: 1-5,3,10-22
List of names (with options “FN” and “GN”),
e. g.: “my nzb download/myfile.nfo” “another nzb”
List of regular expressions (options “FR”, “GR”)
Bit of a worry. Do you mean close port 22 on the router?
And yes, your open port is a big security risk. If you really need outside SSH access, choose a number > 50000 and (optionally) install something like fail2ban.
Reinstalled from SD and got successfully installed message. Now It boots to home screen, then quickly reverts to language selection in set up menu. I cannot progress further as the remote isn’t functional. I have swapped batteries but the same issue.
Any ideas? Ta
Not sure about vero remote but used Kore and it’s working
