Assuming Brian means me as ‘expert’ I have to say it’s a while since I did my head in with the full/limited issue. I do remember that Kodi article wasn’t very helpful in our case. I have never seen grey bars on my TV.
Anyway, thanks for the datapoints. I’ll have a look when I’m home after Christmas.
Enjoy your Christmas - I’m surprised by the number of people happy to help out in what’s always a busy time of year.
Discussion here has at the very least led me to a way that I can watch these videos without the bars. Even if I have to fuss with settings to do so, it’s an improvement.
Sorry for necro, but it’s a shame that this topic suddenly ended as I have this exact same issue.
TV, Receiver are both set to HDMI Full range/Enhanced, with Kodi in limited range, the bars are black. With Kodi limited range disabled, the bars go grey and the Kodi interface seems to lose a lot of contrast and colour. The video playing does have the correct colours though, but the grey bars are very distracting. I’m playing 4:3 videos at the moment, so the bars are to be expected, but Kodi does not give out the correct range for its own interface and thus also not for the black bars.
Currently I’m just running limited range, but would like to have it running properly.
I have Sony AF9/A9F OLED, 4k HDR10 and Dolby Vision (no HDR10+)
The Vero 4k is connected to my receiver, Sony STR-DN1080.
The proper setting for you is likely to be running in limited range, as it would be for most people outputting to a TV. It would be highly unlikely the 4:3 video’s your playing where mastered full range anyway so even if you were able to get this working there would be no extra color information there to be gained. This setting does not affect HDR. If you really want to run it this way you may be able to use a whitelist to output to 4:3 content in 4:3 so the bars are generated by your TV instead of Kodi. You can find more information about them here…
Thanks for that, good article. How do I enable YCC?
Still strange that some content is ok; and for content that isn’t - the video itself has perfect blacks; only the letterboxing is grey.
Not sure what mediainfo you need or how to get it? I don’t want to get into the logs like other users, if it didn’t solve the problem for them it won’t be any different for me
Ah thanks. well that is off. How can I get the mediainfo you need?
I’m starting to think it is nothing to do with these video settings. More to do with UI background? Any time some UI form is loading and so nothing is visible, I get the same grey background.
Don’t know what is going on with that link though; says I need to login - pops up window which shows that I am logged in, then nothing changes.
So:
General
Format : Matroska
Format version : Version 4
File size : 8.53 GiB
Duration : 1 h 38 min
Overall bit rate : 12.4 Mb/s
Encoded date : UTC 2021-01-16 11:41:45
Writing application : mkvmerge v31.0.0 (‘Dolores In A Shoestand’) 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Audio
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 1 868 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 16 bits
Compression mode : Lossless
Stream size : 1.28 GiB (15%)
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 36 min
Bit rate : 47.7 kb/s
Count of elements : 3762
Stream size : 32.9 MiB (0%)
Language : German
Default : No
Forced : No
Just to confirm, as I’m not sure anyone has directly acknowledged; this is ONLY the letterboxing; the “black” bars above and below the video are actually grey.
The video itself has the blackest of blacks.
If I enable the limited range, then the video itself no longer has the blackest blacks, instead it is also grey.
All we need is for the letterboxing to ALSO be black as well as the video which already is.
@herculainn1, yes, my problem seems the same as yours. Your video is also not a standard size (it has likely been cropped from a 1080p source), and the empty space outside the video frame is showing the wrong color.
I also get perfect blacks in the video.
If your tv has a “limited range” setting somewhere, you could try turning that on in addition to turning on kodi’s limited range setting. For me that makes the grey bars black, but for me it also messes up HDR video.
Really hoping the fix in the next release solves this long standing annoyance. At least there seems to be some acknowledgement that this is actually a bug.
That doesn’t sound right. For me, using YCC and limited throughout works with SDR and HDR. All three of my screens expect limited range when sending YCC. One of them offers full range but only for RGB. There are so many variables, that’s why I wrote this. If you have a moment, could you read through that and let us know which bits of it don’t match your experience. And what do mean by ‘messes up HDR video’? Is this with sending HDR to an HDR screen or to to a SDR screen?
Hey, yep, I experimented with the black/dark levels on the TV to get closer but it all just kills the quality of the video, and is never “black-black”
For me I can just play the same file via my PC instead; but would be great to be keep it all in one place on the Vero4kp.
