Here is the patch: http://paste.osmc.tv/ofixoxonib.diff
@sam_nazarko it’s against older sources, which I still had, but it seems this part is not changed very often, so maybe you can use it as it is and make a test build for @boehan ?
(funny thing is that osmc already seems to have the actual firmware file “dvb-demod-si2168-d60-01.fw” here GitHub - osmc/dvb-firmware-osmc: DVB firmwares repository
Hopefully the issue is now addressed
- Login via the command line
- Run the following command to add the staging repository:
echo 'deb http://apt.osmc.tv bullseye-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list - Run the following commands to update:
sudo apt-get update && sudo apt-get dist-upgrade && reboot - Your system should have have received the update.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
@KickerTom thanks for your investigation and the fix. And thanks @sam_nazarko for the fast implementation. The device is now correctly recognized and works as expected ![]()
I’m glad to hear this. This will be made available in the next update
Cool, thanks for the feedback and thanks @sam_nazarko for the amazing support.
