Please provide fresh logs.
started up OSMC, and LCD show 2 row (lcd screen is EMPTY)
https://paste.osmc.tv/jasewezopo -
restarted LCD (sudo systemctl restart LCDd), and LCD get worksâŚ
https://paste.osmc.tv/ezifuxoxak
Thanks. Iâm guessing that LCDd is starting too early in the boot sequence and something isnât ready. Try this:
sudo cp /lib/systemd/system/LCDd.service /etc/systemd/system
then edit (using sudo) /etc/systemd/system/LCDd.service and under the [Service] section add a line:
ExecStartPre=/bin/sleep 5
Reboot and see what happens. If it fails to start, please provide logs again.
So Bingo ! Youâre a star xD
then edit:
sudo nano /etc/systemd/system/LCDd.service
[Unit]
Description=LCD display daemon
Documentation=man:LCDd(8) http://www.lcdproc.org/
[Service]
User=root
ExecStart=/usr/sbin/LCDd -s 1 -f -c /etc/LCDd.conf
ExecStartPre=/bin/sleep 5 # add line Thus
[Install]
WantedBy=multi-user.target
log:
https://paste.osmc.tv/ufeximaruv
AND!
Thank You very much your help !
Youâre solved the LCDproc problem on newer Repo.
What you suggest for
â[HowTo] LCD HD44780 Through I2C Port Extenderâ
how need fix the guide for newer repoâs ?
Excellent news.
I think you need to include instructions to:
- enable the LCDd service
- create the modified copy of the LCDd.service to sleep 5 seconds
- set the DriverPath location to
/usr/lib/arm-linux-gnueabihf/lcdproc/
Thank You,
iâll later doing new fresh install on an another SD card,
and i testing, if everything is good, i will edit (how to) section,
what you pointed it.
(btw the âlircdâ works witout problem)
odd ![]()
Fresh installs 2020.11-1 built, like before.
after, installed all things and load up system: didnât works
blank screen.
https://paste.osmc.tv/yidaguyefo
Then, sudo systemctl restart LCDd: got welcome screen and stay in
https://paste.osmc.tv/tuxofopifu
Then: sudo systemctl restart mediacenter: got works
https://paste.osmc.tv/ixixevuzeg
Tuned off and turned on : blank lcd scree again ![]()
https://paste.osmc.tv/poyeqavaso
i hope you can check logâs what missing and why wonât works
It looks like you didnât enable the LCDd service:
sudo systemctl enable LCDd.service
LoL⌠i thought i can enable via OSMC
like:
11, Enable/install LCDproc via OSMC
In the OSMC main menu got to:
Settings >> Add-ons >> Get add-ons >> XBMC/Kodi add-on repository >> Services >> XBMC LCDproc >> Install
BTW:
[server]
DriverPath=/home/osmc/lcdproc/ # this way works too !
so @ dillthedog Thak You very much
âyour qick seviceâ =)
We are done with LCDprc.
