Let me know how you get on. You should find the build process relatively hands-off. Make sure you have a few GB free on the SD card (as the kernel is a large package)
osmc@RASPI2:~$ uname -a
Linux RASPI2 4.4.16-1-osmc #1 SMP PREEMPT Thu Aug 18 16:30:00 UTC 2016 armv7l GNU/Linux
It took nearly five hours to build, but at least I built my first (custom) kernel, yay. Btw, it worked with an 8 GB µSD card that contained nothing but OSMC.
Before I started building, I edited the /home/osmc/osmc/package/kernel-osmc/patches/rbp2-000-add-kernel-config.patch to contain
+CONFIG_JOYSTICK_XPAD is not set
+CONFIG_JOYSTICK_XPAD_FF is not set
During building some y/n/m questions came up for including stuff into the kernel, I answered n to CONFIG_JOYSTICK_XPAD and CONFIG_JOYSTICK_XPAD_FF. Also about six questions about sound broadcom thingie (unfortunately didn’t take screenhots) to which I replied n as well. sudo dpkg -i rbp2-image-4.4.16-1-osmc.deb, edited /etc/osmc/prefs.d/update_preferences, removed the sudo rmmod xpad line from /home/osmc/start.sh, rebooted, tested controller.
Unfortunately it still doesn’t work reliably. All tests/methods from the last ten posts above showed the same behaviour and error messages.
Now it might be imagination, but with the new kernel it worked in 4/5 cases. What also changed was the LED behaviour; now flashing always means working, and staying lit in position 1 always means not working. This is strange, as this is exactly what the --led=2 in /home/osmc/start.sh tells it to do.
Therefore I still think it can’t be a problem in principle but has to do with the order or way the USB device is initialised. If this can be determined by syslogs or anything, I’m happy to provide them.
NOTE: Some people have been having trouble with the XBox/XBox 360 controller driver xboxdrv on the current Raspbian Kernel. To work around this we now include the latest xpad kernel driver with the image (it is available from the Packages → Drivers menu for those upgrading). The included xpad has been patched to map the Xbox 360 triggers to buttons, so they work out of the box with Emulation Station, without the need for xboxdrv.
I’ve tried to install xpad but it ended up with could not install package : dkms raspberrypi-kernel-headers
We don’t use DKMS modules. If someone gets in touch with them and finds out where they sourced the updated kernel module from I will update our kernel.
Seems like the RetroPie guys are suggesting the kernel module is problematic. If this is the case I’m not sure why excluding it from the build as @RJ45 did doesn’t fix the problem.
You may not want our xpad, as it may cause problems with Kodi on OSMC or other issues. We have some support for OSMC but I don’t think I can help get xpad working if they are managing their own kernels that won’t work with dkms.
However due to problems with ES and the triggers, I have patched it so the triggers are forced to act as buttons (can be switched off via module param).
I need to know if this causes regressions, as this may have an impact on RetroPlayer in v18. I can backport the driver if someone is willing to give it a go.
It looks like there is a small downstream (RetroPie) patch, which is applied to the xpad.git tree which is based on the latest upstream kernel.
I’m willing to test anything, although I managed to get the standard xpad driver to work reasonably good by simply removing all custom configs. It works ok with the autoconfig. I’m just not sure how to test it. All that git magic is fairly new to me so I’m still trying to wrap my head around it.
Sorry to disappoint you, but I couldn’t get to work the wireless 360 controller even with a custom built kernel. It either works in OSMC or in RetroPie, but not in both.
Waiting for Kodi 18 and its integration into OSMC now, it’ll have a built-in RetroPie, so to say, called RetroPlayer.
first of all thanks for the great project, been using it for quite a while now. Since the xboxdrv debacle I am successfully using xpad in Emulationstation and moonlight-embedded…but the flashing LEDs are driving me insane. Has there been any progress on integrating the updated xpad packages?
