That should do it
cheers, thanks for the help. I’ll give it a go and report back.
Did you try the repair first?
-bash-4.3# df -h
Filesystem Size Used Available Use% Mounted on
rootfs 9.7M 5.7M 3.5M 62% /
/dev/root 9.7M 5.7M 3.5M 62% /
mdev 248.9M 0 248.9M 0% /dev
/dev/loop0 43.8M 43.8M 0 100% /usr/local/modules
/dev/mtdblock5 5.0M 448.0k 4.6M 9% /usr/local/config
/dev/sda4 959.9M 84.1M 875.8M 9% /mnt/HD_a4
/dev/sdb4 959.9M 33.3M 926.6M 3% /mnt/HD_b4
/dev/sdc4 959.9M 33.3M 926.6M 3% /mnt/HD_c4
/dev/sdd4 959.9M 33.3M 926.6M 3% /mnt/HD_d4
/dev/md1 8.1T 2.6T 5.5T 33% /mnt/HD/HD_a2
/dev/md1 8.1T 2.6T 5.5T 33% /mnt/HD/HD_a2/Nas_Prog/elfinder/web/php/HD/Volume_1
/dev/md1 8.1T 2.6T 5.5T 33% /home/root/.ssh
So where exactly does /tmp go? There’s no tmpfs and the root partition has only 3.5MB free. With only 9.7MB for the root partition, it doesn’t look like your average Linux box.
Edit: The Kodi log(s) show that the error #126 occurred 37 times for queries to the MyVideos107 database and 802 times for queries to the MyMusic60 database. This suggests that the error #126 is not a result of a corruption in the MyVideos107 database, since it also occurs with the MyMusic60 database.
As an update, after trying a number of things, including deleting and reinstalling the addon numerous times I still couldn’t log in. I downgraded phpmyadmin to 1.1 and upgraded the NAS a DNS-345 to the latest firmware, but it made no difference. I am starting to think that the mysql database program just isn’t loading and phpmyadmin refuses to log in because as far as it is concerned the mysql database doesn’t exist. I had hoped that upgrading the DNS would reinstall mysql, if that is the problem, but no luck. Along the way I have tried to edit the php config file but that seems to create more problems.
When everything completely failed I had a delve into the NAS OS using Webmin and found two things which may mean something, 1st - PostgreSQL Database Server - not installed and 2nd - (under Disk and Network Filesystems)
/usr/local/modules SQUASHFS /usr/local/tmp/image.cfs 100 % (used)
These may mean nothing but as the only reference to SQL is that above I sense that I am correct in my idea that for some reason the MySQL server has dropped out.
As I can run commands under Webmin and /or SSH is there a way to restart MySQL or see if it is actually installed.
I don’t have any experience of this NAs but I see that you were able to get to a bash shell. If you can log back on, see if mysql is running with ps -ef | grep sql or if that fails try ps ax | grep sql.
Well usigned int, so 4,294,967,295 episodes, seasons, shows possible.
Regarding your error 126.
Your query returned a “larger” number of results requiring MySQL to create a temporary table. This is usually created under /tmp. And there is not enough space there.
Check your SQL server config fir “tmpdir”.
Also might not hurt to check the values for check “tmp_table_size” and, “max_heap_table_size”
I put my money on the /tmp filesystem size though…
Or there is just crap in some of the tables for whatever reason… You could try by setting kodi to a new SQLDB and rescrape stuff and see what happens.
For
I got - 17119 17067 0 10:55 ttyp0 00:00:00 grep sql
Once I get the whole ‘can’t log in at all’ issue sorted is there a way to specify where /tmp is? If I can set up the /tmp outside the NAS OS but on the storage instead then it shouldn’t be an issue.
It’ll be in a file called my.cnf (possibly /etc/mysql/my.cnf). Look for tmpdir.
Then mysql isn’t running. You need to at least get the server to start first.
