I can do a test build if you want to try a fix. What platform do you want it for @dillthedog? Saves me building all platforms
I don’t think there’s a fix to be tried. It’s just a matter of knowing what to do.
It could be argued that it’ll be a bit more convenient if all the languages were enabled, but that’s as far as it goes, IMO.
Yes, I think we should enable them by default.
Yep, otherwise the language selection screen in the walkthrough is broken.
No – it will still work. Try it
It’s just if people want to change language either
Ah, indeed…
I have chosen chinese language at first boot time ,it didn’t work ,help!
Raspberry Pi 2 / 3
Release Checksum (MD5)
2017.06-1 d36818b085908cfe4da0079035a5104e
You would need to change the font to Arial. EIther reinstall and choose english at the beginning at change the font to Arial and then change to chinese.
Or you could try to do that now manually via ssh.
@fzinken Thank you very much ! This is useful !
The issue with languages not being enabled by default should be resolved in:
