What was the Vero doing when it became unresponsive? Was it on the Main Screen? I wonder if you for testing could use ethernet connection for a few days to figure out if it is really related to the wifi being lost or something else freezing the Vero.
The old Kodi log is showing that you were experiencing slow bandwidth before the hang occurred.
On the basis of some kind of algorithm, Kodi calculated that it would throttle the cache write rate to 2902343 bytes per second::
2020-04-24 09:16:56.785 T:3498025696 DEBUG: CDVDInputStreamFile::SetReadRate - set cache throttle rate to 2902343 bytes per second
but it wasn’t seeing that speed being achieved:
2020-04-24 09:31:08.155 T:3498025696 DEBUG: Readrate 2902000 is too low with 2902343 required
These warning messages show a slow decline in the read rate over a 5 minute period, so whatever is occurring doesn’t happen without warning.
Although the debug Kodi log is useful, it’s only showing the consequences of what seems to be a WiFi problem. (I noticed that even with an uptime of only 27 seconds and 25 KiB read, the ifconfig stats already show 60 dropped read packets.)
I think it might be useful to run some iperf3 tests between the NAS and Vero. [How To] Check Network Performance with iperf3
Black screen, top right a blue rectangle with the text “Zwischenspeichern…” (German for buffering) and the 3 debug lines that appeared since activating debug logging where in the top left (not changing values).
It was playing a video at the time it went unresponsive.
Ok thanks for clarification. So my gut feeling it is not crashed just locked in getting the data.
As @dillthedog wrote, looks like quite some network/WiFi issues. Do some longer iperf3 tests to get a view on that
NAS -> Vero
osmc@Vero:~$ iperf3 -t 60 -R -c nas
Connecting to host nas, port 5201
Reverse mode, remote host nas is sending
[ 4] local 192.168.178.51 port 34993 connected to 192.168.178.48 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 27.1 MBytes 227 Mbits/sec
[ 4] 1.00-2.00 sec 27.9 MBytes 234 Mbits/sec
[ 4] 2.00-3.00 sec 20.0 MBytes 168 Mbits/sec
[ 4] 3.00-4.00 sec 21.7 MBytes 182 Mbits/sec
[ 4] 4.00-5.00 sec 23.3 MBytes 196 Mbits/sec
[ 4] 5.00-6.00 sec 23.2 MBytes 194 Mbits/sec
[ 4] 6.00-7.00 sec 23.8 MBytes 200 Mbits/sec
[ 4] 7.00-8.00 sec 28.4 MBytes 238 Mbits/sec
[ 4] 8.00-9.00 sec 23.0 MBytes 193 Mbits/sec
[ 4] 9.00-10.00 sec 22.5 MBytes 188 Mbits/sec
[ 4] 10.00-11.00 sec 23.3 MBytes 195 Mbits/sec
[ 4] 11.00-12.00 sec 22.5 MBytes 189 Mbits/sec
[ 4] 12.00-13.00 sec 22.6 MBytes 190 Mbits/sec
[ 4] 13.00-14.00 sec 21.0 MBytes 176 Mbits/sec
[ 4] 14.00-15.00 sec 23.3 MBytes 196 Mbits/sec
[ 4] 15.00-16.00 sec 24.0 MBytes 202 Mbits/sec
[ 4] 16.00-17.00 sec 20.1 MBytes 169 Mbits/sec
[ 4] 17.00-18.00 sec 17.9 MBytes 150 Mbits/sec
[ 4] 18.00-19.00 sec 23.0 MBytes 193 Mbits/sec
[ 4] 19.00-20.00 sec 22.2 MBytes 186 Mbits/sec
[ 4] 20.00-21.00 sec 21.1 MBytes 177 Mbits/sec
[ 4] 21.00-22.00 sec 25.7 MBytes 215 Mbits/sec
[ 4] 22.00-23.00 sec 22.8 MBytes 191 Mbits/sec
[ 4] 23.00-24.00 sec 27.9 MBytes 234 Mbits/sec
[ 4] 24.00-25.00 sec 28.0 MBytes 235 Mbits/sec
[ 4] 25.00-26.00 sec 28.4 MBytes 238 Mbits/sec
[ 4] 26.00-27.00 sec 30.2 MBytes 253 Mbits/sec
[ 4] 27.00-28.00 sec 30.1 MBytes 253 Mbits/sec
[ 4] 28.00-29.00 sec 28.7 MBytes 241 Mbits/sec
[ 4] 29.00-30.00 sec 28.5 MBytes 239 Mbits/sec
[ 4] 30.00-31.00 sec 28.0 MBytes 235 Mbits/sec
[ 4] 31.00-32.00 sec 30.3 MBytes 254 Mbits/sec
[ 4] 32.00-33.00 sec 29.9 MBytes 251 Mbits/sec
[ 4] 33.00-34.00 sec 31.3 MBytes 262 Mbits/sec
[ 4] 34.00-35.00 sec 30.2 MBytes 253 Mbits/sec
[ 4] 35.00-36.00 sec 30.9 MBytes 259 Mbits/sec
[ 4] 36.00-37.00 sec 24.7 MBytes 207 Mbits/sec
[ 4] 37.00-38.00 sec 25.9 MBytes 217 Mbits/sec
[ 4] 38.00-39.00 sec 29.9 MBytes 251 Mbits/sec
[ 4] 39.00-40.00 sec 24.5 MBytes 205 Mbits/sec
[ 4] 40.00-41.00 sec 27.5 MBytes 231 Mbits/sec
[ 4] 41.00-42.00 sec 25.3 MBytes 212 Mbits/sec
[ 4] 42.00-43.00 sec 26.9 MBytes 225 Mbits/sec
[ 4] 43.00-44.00 sec 28.0 MBytes 235 Mbits/sec
[ 4] 44.00-45.00 sec 28.0 MBytes 235 Mbits/sec
[ 4] 45.00-46.00 sec 24.3 MBytes 204 Mbits/sec
[ 4] 46.00-47.00 sec 23.6 MBytes 198 Mbits/sec
[ 4] 47.00-48.00 sec 23.9 MBytes 201 Mbits/sec
[ 4] 48.00-49.00 sec 23.5 MBytes 197 Mbits/sec
[ 4] 49.00-50.00 sec 22.9 MBytes 192 Mbits/sec
[ 4] 50.00-51.00 sec 24.5 MBytes 206 Mbits/sec
[ 4] 51.00-52.00 sec 24.7 MBytes 207 Mbits/sec
[ 4] 52.00-53.00 sec 24.8 MBytes 208 Mbits/sec
[ 4] 53.00-54.00 sec 22.1 MBytes 185 Mbits/sec
[ 4] 54.00-55.00 sec 23.0 MBytes 193 Mbits/sec
[ 4] 55.00-56.00 sec 22.5 MBytes 189 Mbits/sec
[ 4] 56.00-57.00 sec 23.2 MBytes 194 Mbits/sec
[ 4] 57.00-58.00 sec 22.3 MBytes 187 Mbits/sec
[ 4] 58.00-59.00 sec 23.6 MBytes 198 Mbits/sec
[ 4] 59.00-60.00 sec 22.9 MBytes 192 Mbits/sec
[ ID] Interval Transfer Bandwidth Retr
[ 4] 0.00-60.00 sec 1.47 GBytes 211 Mbits/sec 0 sender
[ 4] 0.00-60.00 sec 1.47 GBytes 211 Mbits/sec receiver
iperf Done.
Vero -> NAS
osmc@Vero:~$ iperf3 -t 60 -c nas
[ 4] local 192.168.178.51 port 34995 connected to 192.168.178.48 port 5201
[ 4] 0.00-1.00 sec 28.8 MBytes 242 Mbits/sec 0 529 KBytes
[ 4] 1.00-2.00 sec 28.1 MBytes 235 Mbits/sec 0 578 KBytes
[ 4] 2.00-3.00 sec 23.9 MBytes 201 Mbits/sec 0 580 KBytes
[ 4] 3.00-4.00 sec 24.9 MBytes 208 Mbits/sec 0 597 KBytes
[ 4] 4.00-5.00 sec 27.9 MBytes 234 Mbits/sec 0 645 KBytes
[ 4] 5.00-6.00 sec 28.3 MBytes 238 Mbits/sec 0 670 KBytes
[ 4] 6.00-7.00 sec 29.4 MBytes 247 Mbits/sec 0 742 KBytes
[ 4] 7.00-8.00 sec 27.3 MBytes 230 Mbits/sec 0 783 KBytes
[ 4] 8.00-9.00 sec 27.8 MBytes 233 Mbits/sec 0 792 KBytes
[ 4] 9.00-10.00 sec 27.8 MBytes 234 Mbits/sec 0 802 KBytes
[ 4] 10.00-11.00 sec 28.1 MBytes 235 Mbits/sec 0 853 KBytes
[ 4] 11.00-12.00 sec 28.1 MBytes 236 Mbits/sec 0 853 KBytes
[ 4] 12.00-13.00 sec 26.5 MBytes 223 Mbits/sec 0 964 KBytes
[ 4] 13.00-14.00 sec 28.2 MBytes 237 Mbits/sec 0 1.01 MBytes
[ 4] 14.00-15.00 sec 28.5 MBytes 239 Mbits/sec 0 1.04 MBytes
[ 4] 15.00-16.00 sec 28.3 MBytes 237 Mbits/sec 0 1.12 MBytes
[ 4] 16.00-17.00 sec 27.4 MBytes 231 Mbits/sec 0 1.12 MBytes
[ 4] 17.00-18.00 sec 26.9 MBytes 225 Mbits/sec 0 1.19 MBytes
[ 4] 18.00-19.01 sec 28.1 MBytes 235 Mbits/sec 0 1.23 MBytes
[ 4] 19.01-20.01 sec 28.3 MBytes 237 Mbits/sec 0 1.26 MBytes
[ 4] 20.01-21.00 sec 26.1 MBytes 220 Mbits/sec 0 1.26 MBytes
[ 4] 21.00-22.00 sec 28.0 MBytes 235 Mbits/sec 0 1.30 MBytes
[ 4] 22.00-23.00 sec 26.7 MBytes 224 Mbits/sec 0 1.35 MBytes
[ 4] 23.00-24.00 sec 28.2 MBytes 236 Mbits/sec 0 1.35 MBytes
[ 4] 24.00-25.00 sec 28.2 MBytes 237 Mbits/sec 0 1.37 MBytes
[ 4] 25.00-26.00 sec 28.7 MBytes 240 Mbits/sec 0 1.37 MBytes
[ 4] 26.00-27.00 sec 29.0 MBytes 244 Mbits/sec 0 1.41 MBytes
[ 4] 27.00-28.00 sec 27.6 MBytes 232 Mbits/sec 0 1.41 MBytes
[ 4] 28.00-29.00 sec 25.8 MBytes 215 Mbits/sec 0 1.41 MBytes
[ 4] 29.00-30.00 sec 26.8 MBytes 225 Mbits/sec 0 1.41 MBytes
[ 4] 30.00-31.00 sec 29.1 MBytes 245 Mbits/sec 0 1.43 MBytes
[ 4] 31.00-32.00 sec 27.8 MBytes 233 Mbits/sec 0 1.44 MBytes
[ 4] 32.00-33.00 sec 27.5 MBytes 231 Mbits/sec 0 1.44 MBytes
[ 4] 33.00-34.00 sec 27.3 MBytes 229 Mbits/sec 0 1.47 MBytes
[ 4] 34.00-35.00 sec 28.0 MBytes 235 Mbits/sec 0 1.49 MBytes
[ 4] 35.00-36.00 sec 27.2 MBytes 228 Mbits/sec 0 1.49 MBytes
[ 4] 36.00-37.00 sec 27.9 MBytes 234 Mbits/sec 0 1.51 MBytes
[ 4] 37.00-38.00 sec 28.3 MBytes 236 Mbits/sec 0 1.51 MBytes
[ 4] 38.00-39.00 sec 25.3 MBytes 213 Mbits/sec 0 1.51 MBytes
[ 4] 39.00-40.00 sec 27.0 MBytes 227 Mbits/sec 0 1.51 MBytes
[ 4] 40.00-41.00 sec 28.1 MBytes 235 Mbits/sec 0 1.51 MBytes
[ 4] 41.00-42.00 sec 27.2 MBytes 228 Mbits/sec 0 1.53 MBytes
[ 4] 42.00-43.00 sec 27.0 MBytes 227 Mbits/sec 0 1.53 MBytes
[ 4] 43.00-44.00 sec 29.5 MBytes 247 Mbits/sec 0 1.55 MBytes
[ 4] 44.00-45.00 sec 27.8 MBytes 233 Mbits/sec 0 1.55 MBytes
[ 4] 45.00-46.01 sec 28.4 MBytes 237 Mbits/sec 0 1.55 MBytes
[ 4] 46.01-47.00 sec 27.0 MBytes 227 Mbits/sec 0 1.55 MBytes
[ 4] 47.00-48.00 sec 27.7 MBytes 232 Mbits/sec 0 1.55 MBytes
[ 4] 48.00-49.00 sec 28.0 MBytes 235 Mbits/sec 0 1.55 MBytes
[ 4] 49.00-50.00 sec 28.0 MBytes 235 Mbits/sec 0 1.55 MBytes
[ 4] 50.00-51.00 sec 27.3 MBytes 229 Mbits/sec 0 1.55 MBytes
[ 4] 51.00-52.00 sec 23.9 MBytes 201 Mbits/sec 0 1.55 MBytes
[ 4] 52.00-53.00 sec 23.7 MBytes 199 Mbits/sec 0 1.55 MBytes
[ 4] 53.00-54.00 sec 27.9 MBytes 234 Mbits/sec 0 1.55 MBytes
[ 4] 54.00-55.00 sec 27.2 MBytes 229 Mbits/sec 0 1.57 MBytes
[ 4] 55.00-56.00 sec 28.0 MBytes 234 Mbits/sec 0 1.57 MBytes
[ 4] 56.00-57.00 sec 29.3 MBytes 246 Mbits/sec 0 1.57 MBytes
[ 4] 57.00-58.00 sec 28.6 MBytes 240 Mbits/sec 0 1.57 MBytes
[ 4] 58.00-59.00 sec 27.0 MBytes 227 Mbits/sec 0 1.57 MBytes
[ 4] 59.00-60.00 sec 28.5 MBytes 239 Mbits/sec 0 1.57 MBytes
[ 4] 0.00-60.00 sec 1.61 GBytes 231 Mbits/sec 0 sender
[ 4] 0.00-60.00 sec 1.61 GBytes 231 Mbits/sec receiver
iperf Done.
60 seconds was the example given at your guide for a longer running test. If you need an other duration let me know.
@Crossi36 Could you check on the AVM router what was logged there around 2020-04-24 09:31:08? FRITZ!Box GUI -> System -> Ereignisse -> Druckansicht … if you want you can copy’n paste some lines of logs here.
The same for your AVM repeater.
[24.04.20 10:12:23] WLAN-Übertragungsqualität durch reduzierte Kanalbandbreite erhöht (2,4 GHz).
[24.04.20 09:55:18] WLAN-Übertragungsqualität durch reduzierte Kanalbandbreite erhöht (2,4 GHz).
[24.04.20 09:54:46] [fritz.repeater] WLAN-Übertragungsqualität durch reduzierte Kanalbandbreite erhöht (2,4 GHz). [4 Meldungen seit 24.04.20 09:02:23]
[24.04.20 05:58:52] WLAN-Übertragungsqualität durch reduzierte Kanalbandbreite erhöht (2,4 GHz).
Redacted some FRITZ!App Fon logins.
This looks like your wifi spectrum and current channel is disturbed by something maybe a neighbour’s wifi router or some interference on the 2.4 GHz frequencies.
There is a fine Anrdoid app from AVM for your smartphone: AVM Fritz!app WLAN which gives you a nice view about the used free channels of the 2.4 GHz and 5 GHz wifi spectrum. Wifiman is a more international known Android app.
Check your wifi channels and use unused ones for 2.4 and 5 GHz (so, don’t use the AUTO setting but instead a fix channel on the AVM router).
Just one observation. In the log snippet above from the Vero4K, we see:
Those sequential MAC addresses suggest the same device, the first one probably being 5 GHz and the second one being 2.4 GHz (channel 6). The 2.4 GHz SSID is “Hermes”.
In the log you provided, we see that the MAC address of 98:9B:CB:B7:3F:07 does operate on 5 GHz (channel 36) and uses the same SSID of “Hermes”.
Apr 23 13:36:33 Vero wpa_supplicant[427]: wlan0: Trying to associate with 98:9b:cb:b7:3f:07 (SSID='Hermes' freq=5180 MHz)
Apr 23 13:36:33 Vero kernel: Connectting with 98:9b:cb:b7:3f:07 channel (36) ssid "Hermes", len (14)
So, unless the router and upstairs repeater have consecutive MAC addresses, the disconnect/reconnect occurred on a dual-band device that went from 5 GHz to 2.4 GHz - and the repeater wasn’t used.
Today it occurred again. This time the Vero didn’t freeze, though. The screen didn’t turn black, it just paused the video and continued playing after a while.
https://paste.osmc.tv/mahinifaxi
6th May, around 8:30 - 8:40 AM.
A couple of days ago the Vero displayed an error message that an update failed. After restarting and manually searching for updates it said that no updates were found. Related?
You can see tons of entries like
2020-05-05 08:56:45.641 T:3394859744 DEBUG: Readrate 4028000 is too low with 4028868 required
which means the Vero cannot read/get the data fast enough. From the bandwidth perspective you’re running on the edge while this video playback with this wifi connection.
While the mentioned problem time interval you can see
May 06 08:30:22 Vero mediacenter[397]: PING 192.168.178.48 (192.168.178.48): 56 data bytes
May 06 08:30:22 Vero mediacenter[397]: --- 192.168.178.48 ping statistics ---
May 06 08:30:22 Vero mediacenter[397]: 1 packets transmitted, 0 packets received, 100% packet loss
May 06 08:30:23 Vero mediacenter[397]: PING 192.168.178.48 (192.168.178.48): 56 data bytes
May 06 08:30:23 Vero mediacenter[397]: --- 192.168.178.48 ping statistics ---
May 06 08:30:23 Vero mediacenter[397]: 1 packets transmitted, 0 packets received, 100% packet loss
May 06 08:30:24 Vero mediacenter[397]: PING 192.168.178.48 (192.168.178.48): 56 data bytes
May 06 08:30:24 Vero mediacenter[397]: --- 192.168.178.48 ping statistics ---
May 06 08:30:24 Vero mediacenter[397]: 1 packets transmitted, 0 packets received, 100% packet loss
May 06 08:30:26 Vero mediacenter[397]: PING 192.168.178.48 (192.168.178.48): 56 data bytes
May 06 08:30:26 Vero mediacenter[397]: --- 192.168.178.48 ping statistics ---
May 06 08:30:26 Vero mediacenter[397]: 1 packets transmitted, 0 packets received, 100% packet loss
May 06 08:30:27 Vero mediacenter[397]: PING 192.168.178.48 (192.168.178.48): 56 data bytes
May 06 08:30:27 Vero mediacenter[397]: 64 bytes from 192.168.178.48: seq=0 ttl=64 time=768.210 ms
May 06 08:30:27 Vero mediacenter[397]: --- 192.168.178.48 ping statistics ---
May 06 08:30:27 Vero mediacenter[397]: 1 packets transmitted, 1 packets received, 0% packet loss
May 06 08:30:27 Vero mediacenter[397]: round-trip min/avg/max = 768.210/768.210/768.210 ms
In summary: This network connection isn’t appropriate for your usage; you’ve to stabilize and improve the wifi connection in your environment or use a wired LAN connection means a simple cat 5e/cat6 LAN cable.
As already noted, the WiFi system is having significant problems. Your latest log shows that OSMC tried to connect 5 times to an access point:
May 04 08:40:55 Vero kernel: Connectting with 98:9b:cb:b7:3f:07 channel (36) ssid "Hermes", len (14)
May 05 04:03:43 Vero kernel: Connectting with 98:9b:cb:b7:3f:08 channel (6) ssid "Hermes", len (14)
May 05 04:04:25 Vero kernel: Connectting with 08:96:d7:90:83:c7 channel (1) ssid "Hermes", len (14)
May 05 04:10:33 Vero kernel: Connectting with 98:9b:cb:b7:3f:07 channel (52) ssid "Hermes", len (14)
May 06 03:35:57 Vero kernel: Connectting with 98:9b:cb:b7:3f:08 channel (6) ssid "Hermes", len (14)
The middle connection is to a different MAC address, 08:96:d7:90:83:c7, which I assume is the repeater. The Vero failed to connect and it took a further six minutes to reconnect. These repeated reconnects and the ping problems in the log show that your WiFi is clearly not stable.
The router is channel hopping on 5 GHz Do you know why? First it used channel 36 and later channel 52.
Realistically, unless you can fix these WiFi problems, the only sensible way forward is to connect the Vero4K+ by cable. If you don’t wish to choose this obvious solution, you must accept that problems will continue to occur – and that there is little more we can do to help.
