Indeed - all of the servers are NTP servers and are simply being used to consult the time.
@mexjerry - I can understand your concerns in an ever intrusive world, but rest assured the IPs that you have provided are simply for time lookups and if this is not to your satisfaction then we can tell you how to change this list of servers or prevent your device from consulting them altogether.
I’m happy to take a call to discuss any particular concerns you have
Many thanks
@mexjerry: You know that you can install your own Timeserver (ntpd) at home and point your vero to that timeserver? This is what I do here.
I even have my own DNS Servers at home, and route most request through my TOR Gateway/Hub.
So whatever you do - setup your controlled environment (with all bells and whistles), and do it yourself.
And - BTW - I do not think the vero’s OSMC is the one connecting. It is probably the Kodi software (Didn’t check - but the way I know Sam & Team, they do things right and clean). And in the eventual case you installed some add-ons, I’d also check these Kodi addons.
