I’ve tried both ways, cleaning up library then update, nothing has changed. The only way to make scraper working properly is to place the nfo file like they have suggested me before.
I’m gonna scan one of the “rip” with mediainfo on Mac, I’ll copy the output soon
UPDATE: `General
Unique ID : 62858496254781245081722731975949143680 (0x2F4A1B241A20257175D3CEBF8907CE80)
Complete name : /Volumes/MOVIES/Sicario.Day.of.the.Soldado.2018.2160p.BluRay.x265.10bit.HDR.DTS-HD.MA.TrueHD.7.1.Atmos-SWTYBLZ.mkv
Format : Matroska
Format version : Version 4
File size : 20.2 GiB
Duration : 2 h 2 min
Overall bit rate : 23.7 Mb/s
Movie name : Sicario.Day.of.the.Soldado.2018.2160p.BluRay.x265.10bit.HDR.DTS-HD.MA.TrueHD.7.1.Atmos-SWTYBLZ
Encoded date : UTC 2018-09-27 15:10:51
Writing application : mkvmerge v26.0.0 (‘In The Game’) 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Cover : Yes
Attachments : cover.jpg
Video
Format : HEVC
Commercial name : HDR10
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 15.7 Mb/s
Width : 3 840 pixels
Height : 1 600 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.107
Stream size : 13.4 GiB (66%)
Title : Sicario.Day.of.the.Soldado.2018.2160p.BluRay.x265.10bit.HDR.DTS-HD.MA.TrueHD.7.1.Atmos-SWTYBLZ
Writing library : x265 2.8+54-79c76e42cb28:[Windows][GCC 7.3.1][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=16 / numa-pools=24,24,24,24 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1600 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / radl=0 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=16.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,01) / max-cll=8325,775 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-mv-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 8325 cd/m2
Maximum Frame-Average Light Level : 775 cd/m2
Audio #1
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 2 990 kb/s
Maximum bit rate : 5 031 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Delay relative to video : 1 ms
Stream size : 2.56 GiB (13%)
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate : 4 152 kb/s
Channel layout : C L R LFE Lb Rb Lss Rss
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Stream size : 3.55 GiB (18%)
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 560 MiB (3%)
Language : English
Service kind : Complete Main
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 27 min
Bit rate : 6 b/s
Count of elements : 172
Stream size : 4.44 KiB (0%)
Title : English-FORCED-SRT
Language : English
Default : Yes
Forced : Yes
Text #2
Format : UTF-8
Duration : 1 h 52 min
Bit rate : 30 b/s
Count of elements : 831
Stream size : 25.3 KiB (0%)
Title : English-SRT
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Bit rate : 20.3 kb/s
Count of elements : 1624
Stream size : 16.4 MiB (0%)
Title : English-PGS
Language : English
Default : No
Forced : No
Text #4
Format : PGS
Muxing mode : zlib
Duration : 2 h 1 min
Bit rate : 24.1 kb/s
Count of elements : 2098
Stream size : 20.9 MiB (0%)
Title : English-SDH-PGS
Language : English
Default : No
Forced : No
Text #5
Format : PGS
Muxing mode : zlib
Title : English-PGS
Language : English
Default : No
Forced : No
Text #6
Format : PGS
Muxing mode : zlib
Language : English
Default : No
Forced : No
Text #7
Format : PGS
Muxing mode : zlib
Bit rate : 16.9 kb/s
Count of elements : 1588
Stream size : 14.7 MiB (0%)
Title : French-PGS
Language : French
Default : No
Forced : No
Text #8
Format : PGS
Muxing mode : zlib
Bit rate : 17.6 kb/s
Count of elements : 1648
Stream size : 15.3 MiB (0%)
Title : Portuguese-PGS
Language : Portuguese
Default : No
Forced : No
Text #9
Format : PGS
Muxing mode : zlib
Bit rate : 12.8 kb/s
Count of elements : 1336
Stream size : 11.1 MiB (0%)
Title : Spanish-PGS
Language : Spanish
Default : No
Forced : No
Text #10
Format : PGS
Muxing mode : zlib
Bit rate : 13.9 kb/s
Count of elements : 1334
Stream size : 12.1 MiB (0%)
Title : Spanish-PGS
Language : Spanish
Default : No
Forced : No
Menu
00:00:00.000 : :Chapter 1
00:06:38.189 : :Chapter 2
00:14:45.593 : :Chapter 3
00:18:48.502 : :Chapter 4
00:27:08.335 : :Chapter 5
00:34:08.963 : :Chapter 6
00:42:28.671 : :Chapter 7
00:51:10.442 : :Chapter 8
01:00:58.071 : :Chapter 9
01:09:20.114 : :Chapter 10
01:14:26.795 : :Chapter 11
01:23:24.958 : :Chapter 12
01:28:41.357 : :Chapter 13
01:35:38.899 : :Chapter 14
01:41:44.348 : :Chapter 15
01:46:15.494 : :Chapter 16
