I tried to change pcm_slave.pairup.pcm —> pcm.pairup and use pairup ad device. I get the same error. I think the problem is in that part, but I do not see any.
@grahamh Would it be easier if I just started a new topic and tagged you in it? It looks like we have about 3 different conversations happening in this one thread, which is partially my fault.
The only output I get is the /usr/bin/bluealsa: E: Couldn’t set audio object type: Invalid config error, the same error I get when I try to use aplay. I looked for some sort of extra debug output for bluealsa and don’t see anything unfortunately.
Let’s leave it in here - it’s all a consequence of pulseaudio and buster not playing nicely.
Please post a full debug log so we can check your setup.
reproduce the issue
upload the log set (all configs and logs!) either using the
ALSA lib pcm_params.c:2226:(snd1_pcm_hw_refine_slave) Slave PCM not usable aplay: set_params:1310: Broken configuration for this PCM: no configurations available
I’ve been having a play and probably owe you an apology. I’ve had more success with wrapping each BT device in a plug the same way you did in your first .asoundrc.
pcm.jblflip {
type plug
slave.pcm {
type bluealsa
device "FC:A8:9A:B3:42:4F"
profile "a2dp"
hint { show on description "JBL Flip 3"}
I’m also using a route plugin like you did at first, but as far as I can tell it behaves exactly the same as the upmix.
pcm.bothBT {
type route
slave "pairupBT"
ttable.0.0 1
ttable.1.1 1
ttable.0.2 1
ttable.1.3 1
hint {
show {
@func refer
name defaults.namehint.extended
description "BT & BT"
pcm_slave.pairupBT.pcm {
type plug
slave.pcm {
type multi
slaves {
a { pcm "jblflip" channels 2 }
b { pcm "vero4k" channels 2 }
bindings [
{ slave a channel 0 }
{ slave a channel 1 }
{ slave b channel 0 }
{ slave b channel 1 }
I’ve only got one BT adapter and only one BT speaker so I’m using a vero4k running bluealsa-aplay as a second sink.
With the above configs I can aplay -DbothBT /usr/share/sounds/alsa/Front_Center.wav and sound comes out of both my JBL speaker and the vero4k but not very smoothly
But I can’t play a stereo 44.1kHz wav file:
osmc@vero4kp2:/mnt/1Text4/Music/Test files$ aplay -DbothBT blind1full.WAV
Playing WAVE 'blind1full.WAV' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
aplay: xrun:1664: read/write error, state = PREPARED
osmc@vero4kp2:/mnt/1Text4/Music/Test files$ aplay -Dplug:bothBT blind1full.WAV
aplay: pcm_params.c:170: snd1_pcm_hw_param_get_min: Assertion `!snd_interval_empty(i)' failed.
Aborted by signal Aborted...
And Kodi can’t open the bothBT pcm either.
2020-10-24 10:50:47.337 T:4027576544 INFO: CAESinkALSA::EnumerateDevice - device bothBT description BT & BT
2020-10-24 10:50:47.337 T:4027576544 INFO: CAESinkALSA - No playback configurations available for device "bothBT"
I think your best bet is to ask on the bluez-alsa github. They are very responsive. We are building from their version 2.1.0, commit 49ad348.
You were right, bluez-alsa github was very helpful. According this topic
Use bluealsa device within a multi in asound.conf · Issue #379 · arkq/bluez-alsa · GitHub
i changed .asounrc to:
pcm.headphones_1 {
type plug
slave.pcm {
service "org.bluealsa.bluealsa1"
type bluealsa
device "5C:FB:7C:16:79:FC"
profile "a2dp"
hint { show on description "description - Headphones 1" }
pcm.headphones_2 {
type plug
slave.pcm {
type bluealsa
service "org.bluealsa.bluealsa2"
device "5C:FB:7C:16:20:1E"
profile "a2dp"
hint { show on description "description - Headphones 2" }
pcm.headphones_3 {
type plug
slave.pcm {
type bluealsa
service "org.bluealsa.bluealsa3"
device "E8:D0:3C:FC:3C:E2"
profile "a2dp"
hint { show on description "description - Headphones 3" }
ctl.headphones_1 {
type bluealsa
ctl.headphones_2 {
type bluealsa
ctl.headphones_3 {
type bluealsa
pcm.headphones-multi {
type plug;
slave.pcm {
type multi;
slaves.a.pcm "headphones_1";
slaves.a.channels 2;
slaves.b.pcm "headphones_3";
slaves.b.channels 2;
bindings.0 { slave a; channel 0; }
bindings.1 { slave a; channel 1; }
bindings.2 { slave b; channel 0; }
bindings.3 { slave b; channel 1; }
ttable.0.0 1
ttable.1.1 1
ttable.0.2 1
ttable.1.3 1
I’m testing now only on two bluetooth headphones (I have to change third dongle - it is very old and I get a lot o noise and frequent disconnecting) and IT IS WORKING!
aplay -d headphones-multi plays on both devices.
I see the hedphones_[1-3] in kodi audio outputs, but I do not see headphones-multi.
kodi log:
2020-10-24 18:05:07.071 T:1885335776 NOTICE: Enumerated ALSA devices:
2020-10-24 18:05:07.071 T:1885335776 NOTICE: Device 1
2020-10-24 18:05:07.071 T:1885335776 NOTICE: m_deviceName : @
2020-10-24 18:05:07.071 T:1885335776 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
2020-10-24 18:05:07.071 T:1885335776 NOTICE: m_displayNameExtra:
2020-10-24 18:05:07.071 T:1885335776 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-10-24 18:05:07.071 T:1885335776 NOTICE: m_channels : FL, FR
2020-10-24 18:05:07.071 T:1885335776 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
2020-10-24 18:05:07.071 T:1885335776 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
2020-10-24 18:05:07.071 T:1885335776 NOTICE: m_streamTypes : No passthrough capabilities
2020-10-24 18:05:07.071 T:1885335776 NOTICE: Device 2
2020-10-24 18:05:07.071 T:1885335776 NOTICE: m_deviceName : headphones_1
2020-10-24 18:05:07.071 T:1885335776 NOTICE: m_displayName : description - Headphones 1
2020-10-24 18:05:07.071 T:1885335776 NOTICE: m_sampleRates : 44100
2020-10-24 18:05:07.071 T:1885335776 NOTICE: Device 3
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_deviceName : headphones_3
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_displayName : description - Headphones 3
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_displayNameExtra:
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_channels : FL, FR
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_sampleRates : 48000
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_streamTypes : No passthrough capabilities
2020-10-24 18:05:07.072 T:1885335776 NOTICE: Device 4
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_deviceName : sysdefault:CARD=ALSA
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_displayName : bcm2835 ALSA
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_displayNameExtra: bcm2835 ALSA
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
2020-10-24 18:05:07.072 T:1885335776 NOTICE: Device 5
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_deviceName : @:CARD=Audio,DEV=0
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_displayName : iFi (by AMR) HD USB Audio
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_displayNameExtra: Analog
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_dataFormats : AE_FMT_S32NE
2020-10-24 18:05:07.072 T:1885335776 NOTICE: Device 6
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_deviceName : iec958:CARD=Audio,DEV=0
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_displayNameExtra: S/PDIF
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_sampleRates : 44100,48000,88200,96000,176400,192000,384000
2020-10-24 18:05:07.072 T:1885335776 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S32NE
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512
2020-10-24 18:05:07.073 T:1885335776 NOTICE: Enumerated PI devices:
2020-10-24 18:05:07.073 T:1885335776 NOTICE: Device 1
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_deviceName : HDMI
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_displayName : HDMI
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_displayNameExtra:
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_channels : FL, FR
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
2020-10-24 18:05:07.073 T:1885335776 NOTICE: Device 2
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_deviceName : Analogue
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_displayName : Analogue
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_sampleRates : 48000
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_streamTypes : No passthrough capabilities
2020-10-24 18:05:07.073 T:1885335776 NOTICE: Device 3
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_deviceName : Both
2020-10-24 18:05:07.073 T:1885335776 NOTICE: m_displayName : HDMI and Analogue
2020-10-24 18:05:07.170 T:1916453808 NOTICE: Raspberry PI firmware version: Mar 10 2020 16:00:17
It sees the headphones_1 and headphones_3, but not see headphones-multi (with is accessible by aplay for sure)
BTW: Do You think it is possible for alsa to ignore one output of multi device without getting error - The case when only two of three headphones are connected. Or do I have to create some kind of “dynamic” config?
After digging two days in web I found no solution - only a few topics with similar problem. According to standing that if something does not exist in web - does not exist at all - I tested again, after several reboots, to get debug log, and…
2020-10-26 10:57:42.126 T:1885335776 NOTICE: Found 2 Lists of Devices
2020-10-26 10:57:42.126 T:1885335776 NOTICE: Enumerated ALSA devices:
2020-10-26 10:57:42.126 T:1885335776 NOTICE: Device 1
2020-10-26 10:57:42.126 T:1885335776 NOTICE: m_deviceName : @
2020-10-26 10:57:42.126 T:1885335776 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
2020-10-26 10:57:42.126 T:1885335776 NOTICE: m_displayNameExtra:
2020-10-26 10:57:42.126 T:1885335776 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-10-26 10:57:42.126 T:1885335776 NOTICE: m_channels : FL, FR
2020-10-26 10:57:42.126 T:1885335776 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
2020-10-26 10:57:42.126 T:1885335776 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
2020-10-26 10:57:42.126 T:1885335776 NOTICE: m_streamTypes : No passthrough capabilities
2020-10-26 10:57:42.126 T:1885335776 NOTICE: Device 2
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_deviceName : headphones_1
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_displayName : description - Headphones 1
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_displayNameExtra:
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_channels : FL, FR
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_sampleRates : 44100
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_streamTypes : No passthrough capabilities
2020-10-26 10:57:42.127 T:1885335776 NOTICE: Device 3
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_deviceName : headphones_3
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_displayName : description - Headphones 3
2020-10-26 10:57:42.127 T:1885335776 NOTICE: Device 4
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_deviceName : headphones-multi
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_displayName : headphones-multi
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_channels : FL, FR, BL, BR
2020-10-26 10:57:42.127 T:1885335776 NOTICE: Device 5
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_deviceName : sysdefault:CARD=ALSA
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_displayName : bcm2835 ALSA
2020-10-26 10:57:42.127 T:1885335776 NOTICE: m_displayNameExtra: bcm2835 ALSA
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_streamTypes : No passthrough capabilities
2020-10-26 10:57:42.128 T:1885335776 NOTICE: Device 6
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_deviceName : @:CARD=Audio,DEV=0
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_displayName : iFi (by AMR) HD USB Audio
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_displayNameExtra: Analog
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_channels : FL, FR
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_sampleRates : 48000
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_dataFormats : AE_FMT_S32NE
2020-10-26 10:57:42.128 T:1885335776 NOTICE: Device 7
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_deviceName : iec958:CARD=Audio,DEV=0
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_displayNameExtra: S/PDIF
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_sampleRates : 44100,48000,88200,96000,176400,192000,384000
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S32NE
2020-10-26 10:57:42.128 T:1885335776 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512
So the problem disappeared ;-)). Now I have to create multi devices in .asoundrc for different combination of BT headsets connected.
The thing that bothers me is the number of channels seen by KODI - BL and BL?? So the channels are no copied in alsa only? I thought that “outside” alsa only 2 channels will be visible ;-/
Glad you are nearly there!
Kodi won’t display an alsa device unless it can open it, which I guess means it needs to open all the BT devices in the multi. Sounds like you have the right solution.
You might try adding a line channels 2 after the line type multi. Then aplay -v ..... to check it doesn’t throw a syntax error.
Hi @fzinken,
I’d be interested to get clues to configure Bluetooth devices inside KODI/OSMC because I’ve tried via PulseAudio following obsoletes tutoriels all over the forum and the web. But I was only able to make bluetooth working outside of KODI.
I’ve removed all pulseaudio packages and I’d be glad if you could give me instructions with the new alsa approach you’re mentioning.
Sorry if I’ve missed a documentation elsewhere, my searches were unsuccessful. Please, let me know if you want me to create a dedicated topic or if we continue here.
Thanks.
It is currently still hidden as it still requries some manual work. But here you find the instructions which work quite well for me.
[Updated November 2021] Bluez-alsa allows you to stream audio both to and from your OSMC device. We have now integrated bluez-alsa into OSMC as a replacement for our a2dp package which is deprecated. Our Kodi v19 builds include bluez-alsa. If you are still on v18.9, you can install it on Vero 4k or RPi 2/3 with: sudo apt-get install armv7-bluezalsa-osmc and re-boot to get the bluealsa service started. If you have previously installed one of our older BT audio packages, you will need to re…
Great! Thanks for the link, I’m looking at it right now!
Hi fzinken,
Oh yes please, some instructions would be amazing.
I’m having trouble with my BT headphones, Bose QC35. Am able; to trust, unblock & connect them to the Vero 4k tv, however, no sound will come out on them.
Cheers in advance!
Did you follow these instructions especially created the .asoundrc?
Hi Fzinken,
Thanks for the speedy reply!
Yep all followed as per steps, sadly no sound going to BT headphones. Unless I made a mistake with the format of the .asoundrc file…?
# This file describes the bluetooth sinks available for Kodi to play to
# add lines like the following for each BT device (speaker or headphones)
#pcm.mybtdevice {
# type bluealsa
# device "2C:41:A1:4F:54:1A"
# profile "a2dp"
# hint { show on description "My device name"}
# using the MAC of the device (see bluetoothctl) instead of 12:34:56:78:9A:BC
# Use any letters or numbers for the description which will show up in Settings-System-Audio
Perhaps I’d be best waiting until final release.
EDIT: sorry was having trouble posting it haha
Well we can get you going with some help.
You would need to remove the # in your .asoundrc as that makes the entries comments.
So it should look like:
# This file describes the bluetooth sinks available for Kodi to play to # add lines like the following for each BT device (speaker or headphones) pcm.myQC35 { type bluealsa device "2C:41:A1:4F:54:1A" profile "a2dp" hint { show on description "Bose QC35"} } # using the MAC of the device (see bluetoothctl) instead of 12:34:56:78:9A:BC # Use any letters or numbers for the description which will show up in Settings-System-Audio
Hi fzinken,
Thanks for the reply.
Ahh I see, that makes sense! So I’ve made that change and connected to the headset, however, still no sound received. But that’s ok, am happy to wait till final release.
“Good things come to those who wait”
If it doesn’t work with that, you won’t be any better off with any future release. It would be good to know what’s wrong. Does your headphone show up in Settings->System->Audio? If not, try restarting Kodi with Power->Exit.
Hi grahamh, thanks for the reply.
oh, ah no It doesn’t actuality show up in audio settings as a source… just tried restarting kodi using “exit” no go.
You did make a new file called .asoundrc - not still using the name .asoundrc.example?
opps, I feel a fool. Was editing the “.asoundrc.example” file. ahah. It’s all working perfectly now, Thanks!
Do you know if multiple audio sources will be supported in the final release? eg: BT & HDMI, etc?
Thanks again!
That’s the ambition. It is possible with some alsa-config-fu if you are interested and have the patience. Bringing it all to an intuitive and foolproof UI is the challenge, though.
