Did you change WinSCP editor to Notepad++ or did you use the default Windows Notepad??
Notepad++
Just do it in MyOSMC → Pi COnfig
login as: osmc
osmc@192.168.0.108’s password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Mar 29 14:03:13 2016 from 192.168.0.103
osmc@osmc:~$ grab-logs -A
Logs successfully uploaded.
Logs available at http://paste.osmc.io/ubinebegoj (using wired connection)
Logs available at http://paste.osmc.io/exusufilep (using WiFi conection)
