OPENELEC VS OSMC Short comparison
Hi Sam, I have set up everything, so I should start testing soon.
I have a question, a user on OE forum pointed me to this:
If your wireless adapter uses the 8192CU driver you can add the following to /storage/.config/modprobe.d/8192cu.conf
# Disable power management
options 8192cu rtw_power_mgnt=0 rtw_enusbss=0
since adding this (I'm using a D-Link DWA-131 Rev:B1 adapter) my wireless transfer speeds have improved quite a bit.
Before disabling power management the transfer speeds were between 3 and 4 Mbyte/sec, after they are now between 7 and 12 MByte/sec.
Note: I'm living in the country and there are no other Wifi networks around, so there is minimal outside interference.
In case of EW-7811UTC that would be 8812au.
Iā€™ve tried this out and it didnā€™t work for me on my OE setup.
Should this work at all?
Thank you
Voja
Hi Sam, Iā€™m stuck when I run apt-get update I end up with these messages:
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
I used sudo in front, that worked.
You need to run these commands as root. Please run sudo -s beforehand or prefix them with sudo.
No idea about OE, but OSMC handles these optimisations already
Let me know how scanning goes and I will then make the second series of improvements
These result are amazing!
I performed library scan twice. After the first one I change the content to None and then do everything all over again.
TV series: 735 episodes
Openelec
First run - 150
Second run - 138
OSMC
First run - 209
Second run - 204
OSMC New test version
First run - 105
Second run - 95
Thanks for reporting back.
Iā€™ll get the next fixes in as well and would love it if you can give that a go as well. Iā€™ll let you know when theyā€™re ready for testing.
Sounds good Sam, Iā€™ll be delighted to give it a spin when itā€™s ready.
Just a heads up, I encountered some errors during update, but since I was doing everything on my tv and not putty I couldnā€™t copy it here.
Everything works well, I didnā€™t encounter any bugs during testing.
Next time Iā€™ll definitely use putty so I can copy any information which might be relevant.
Sam I have another off topic question (Sorry for bugging you).
I know that force_turbo disables the dynamic CPU frequency and basically the Raspberry Pi CPU gets stuck to whatever is the highest frequency.
But does it use more power constantly or just when itā€™s under some load?
I would presume that when the CPU is idle nothing special happens.
Do you have any experience with this by any chance?
I am not Sam, but from my experience with other embedded hardware, I can tell that if the cpu is locked in full power mode, it will consume a lot more power when idle than downclocked and undervolted.
Good powermanagement will not only clock down the cpu but also deactivate some services when in low power mode like disabling the video and audiooutput or even send the ram to sleep.
This will not be the case here though as only the processor will clock down and up again when the power is needed. This will happen in small bursts though and you cqn get a bit of lag whenever it happens.
So not sure if it is worth the effort. Probably better to just force turbo if it is stable enough as you donā€™t have to worry about batterylife here. We are speaking about around 700mA vs 500mA without usb gear. So it will not be a huge gain anyway. Maybe a dollar or two when you leave it running 24/7.
There are some tests with the pi on the internet where real data was published. So some experiments have to be done.
Hi mcobit, thank for the answer!
I had a similar idea but wasnā€™t sure what happens with Raspberry Pi, does force turbo only affect CPU or more components.
If itā€™s just CPU than thatā€™s not too bad at all.
@sam_nazarko
Iā€™ve noticed that ethernet transfer rate is greater with OSMC than with OE.
I use NTFS formatted 2 TB HDD.
OE is 9-10MB/s
OSMC is 10-11,5MB/s.
To some it might not be much but I recognize better drivers and better optimization when I see one.
Iā€™m ready for the next one, just let me know when itā€™s done.
Thank you for your awesome work!
Voja
Amazing improvement :smile:
Scanning my series library
Rpi2 went from 3m 48s to 2m 3s
Vero from 5m 18s to 2m 45s
Keep up the good work.
Before you get too excited about the performance increase, it has a cost. If the system crashes, looses power etc itā€™s a high chance that the library will be corrupted beyond repair.
The author of sqlite explicitly advice against this at section 3.2 here How To Corrupt An SQLite Database File
Does OE have this same problem?
Iā€™ll test this scenario out, Iā€™ll start scanning and then after some time cut the power.
So weā€™ll know if something happens.
Keep in mind that this is very likely to corrupt the database even without the suggested patch.
Maybe.
But I donā€™t see (perhaps Iā€™m missing something) how userspace can guarantee successful transactions anyway. If the power goes, the power goes, and ultimately, the write goes through the kernel anyway. Making the writeback synchronous doesnā€™t guarantee it is successful. If we have unstable PSU or a bad SD card, corruption will occur anyway. SQLite is serverless, so we are dependent on the userland application. If that crashes during a synchronous writeback, we are no better off than an asynchronous one?
Perhaps the in memory journal is more risky, but again, Iā€™m not convinced, and thatā€™s why we have staging to test these things, so weā€™ll have plenty of time to test this either way.
Iā€™ll try and explain.
When an app writes to disk the file system will ack the write as soon as itā€™s in the buffer, once this is done the file system can decide when and how it will write the data. This might not be in the order they happened but in the order thatā€™s most efficient for the disk layout. This can lead to writes happening in the wrong order which isnā€™t an issue for most file types but can break databases.
When issuing a synch Io with write through the file system will only ack the write once itā€™s on disk, this gets rid of the reorder issue and it minimizes the time the data is vulnerable for crashes. All databases does this no matter of size or architecture.
Thereā€™s still the issue that disks may play tricks as well and this is out of our hands.
Disabling write through can be a valid use case for unimportant data where you can afford to lose it, I would argue that users libraries are quite important data for them.
If you go on with this anyway I would suggest you make it a setting so users can easily disable it when issues appear and you wonā€™t have to get another build out right away
Hi how can i test net speed via wifi and ethernet? also has anyone tried the rtl9183EU ?
I have a new build ready.
This will hopefully enable memory mapped IO, which is enabled in OpenELEC already (and explains the initial speed difference) without requiring us to recompile libsqlite. Iā€™d appreciate if @vdb86 and @thansen_dk can test again with the same libraries as before, as this will let us know if itā€™s working as expected.
You should look for these lines in /home/osmc/.kodi/temp/kodi.log
02:42:44 T:139969386363072    INFO: sqlite-osmc: memory is not mapped yet
02:42:44 T:139969386363072    INFO: sqlite-osmc: memory mapped IO is enabled
