Ok just checked that log file. So do I read it correctly both your network as well as your parents is using 192.168.0.0/24? If that is the case you would need to do NAT as routing would not work.
Also in the sources.xml I only see smb:\\PLEX you would need to use IP Addresses otherwise you also would need to ensure proper DNS across the two networks (or use the TAP approach).
Currently all these devices are on the same network and subnetwork.
For testing I am creating a hotspot on my phone and tethering my laptop and then establishing the OVPN connection to the Pi.
Well that is what you need to do, having two subnets for test. Might even can use a second router if you have.
kesh6970:
I don’t know what the IP range will be at my new place, but I can configure this to my liking so that’s not a huge concern
Well then for the testing let’s assume the 192.168.0.1-100 to be your future server side LAN. And your Laptop hotspot reprensets your parents LAN (you would need to swap when you move out.
I have tried editing the sources.xml and I’m still unable to access my SMB share (even by remapping the network drive) - I receive a Windows error that 192.168.0.53 is unreachable
Ok, now that I understand the setup of the testing scenario let’s look at the details.
When connected to the Hotspot and the openvpn tunnel established can you provide from the Pi and from the Openvpn server ip addr ip ro
Just to confirm, I have 1 Pi running. The Pi is the OpenVPN Server. I have a connection established currently between the Pi Server and a hotspotted laptop.
Pi Server Outputs:
ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,DYNAMIC,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:86:93:58 brd ff:ff:ff:ff:ff:ff
4: wlan0: <BROADCAST,MULTICAST,DYNAMIC,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether d0:37:45:80:06:54 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.45/24 brd 192.168.0.255 scope global wlan0
5: tun0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 100
link/none
inet 10.8.0.1 peer 10.8.0.2/32 scope global tun0
inet6 fe80::6cc3:6886:b7a4:352c/64 scope link flags 800
ip ro:
default via 192.168.0.1 dev wlan0
10.8.0.0/24 via 10.8.0.2 dev tun0
10.8.0.2 dev tun0 proto kernel scope link src 10.8.0.1
192.168.0.0/24 dev wlan0 proto kernel scope link src 192.168.0.45
192.168.0.1 dev wlan0 scope link
Ok, thanks for clarification. So what are you then testing? Reaching what from where?
What is the output of route PRINT on your Laptop?
Also in this testing scenario for the server config you would need to use: push "route 192.168.0.0 255.255.255.0 vpn_gateway" route 172.20.10.0 255.255.255.0
My testing setup is a laptop connected to a wifi hotspot created by a mobile phone (currently the entire architecture is in 1 room but the use-case is assuming 10K miles between the laptop and the Pi).
Also a note, the laptop is used for testing purposes, long-term I intend the OpenVPN client application to be installed on my main PC (also a Window 10 device).
Routing looks nearly good, you would need to change the route 172.20.10.0 255.255.255.0 in server config
Than basic routing should work.
And you would need to tell me what you want to try from which device to which device.
Because you would then need to add routes to the remote network on those devices
172.20.10.0/24 via 10.8.0.2 dev tun0
Looks all good.
So from where to where do you want to test now?
Server - Laptop should work right away
Server: ping 172.20.10.9
Laptop: ping 192.168.0.45
For other devices you would need to add route
172.20.10.0/24 via 192.168.0.45 on each of the ones that should reach the remote network.
I’m getting used to navigating the network remotely over the VPN connection now, think this may work as a solution for now. I’ve got OSMC updates turned off as this distro is the last that supports my WiFi adapter.
