Hi Anthrax, do you have a video or picture of this awesome setup? I would love to see the 160 Led together with the Nanoleafs.
Also (being a newbie) how can you run different instances. Or better could you make as short guide/input how to run a main hyperion instance and another instance for the Nanoleaf?
I suggest you go with the new hyperion.ng by using @hissingshark s awesome installer. Once installed it’s configured via an easy web interface that should get you up and running with multiple instances/device in a heartbeat. An official hyperion.ng release might also be around the corner…
Thank you for the Video. Real something special…OR BETTER AWESOME…I have many question but for now I will save the video for inspiration…and start to study
Hyperion is not working anymore - i need some advice and suggestion how to debug
Summary:
The Hyperion setup was working until an OSMC upgrade this June. The setup was Vero4K+, 107 Led WS2801, ArduinoR3, Adalight sketch and Hyperion.ng compiled according to the guidelines from Anthrax.
I have been abroad for a while and had no time to try to fix the issue until this weekend.
My HW setup has not changed so far. For the SW I did a clean install of OSMC October 2019 (uname -r 3.14.29-156-osmc) and used the installer of hissingshark (Install from binary) and imported my old config file.
The install seem to be OK but …my setup does not work any more and after several controls and checks do not know how to proceed.
Observation
on Reboot of OSMC I can see all led turn on with a white color which change to blue for 2 seconds. This happens again on restart. The same effect can be seen when I change the USB cable from port white to port black on Vero4K+.
cannot get any effects to work
tried also the config file of nbraunstein with my Led setup. Not solving my issue.
Of course it can be my HW but not sure what can be broken…Arduino? With my tester I have continuity on GND, and controlled all cables which seems to be fine.
What I do not understand is the short flash of light on all led on reboot
Can it be the Aduino? should it be reprogrammed? Which sketch is recommend?
i am using this adalight.ino adjusted to my WS2801
below verbose log file on reboot:
[hyperiond EFFECTFILES] (INFO) 36 effects loaded from directory :/effects/
[hyperiond EFFECTFILES] (INFO) 19 effect schemas loaded from directory :/effects/schema/
[hyperiond EFFECTFILES] (INFO) 0 effects loaded from directory /home/osmc/.hyperion/custom-effects
[hyperiond SettingsManager] (INFO) Selected configuration file: /home/osmc/.hyperion/config/hyperion_main.json
[hyperiond SettingsManager] (DEBUG) (SettingsManager.cpp:73:SettingsManager()) Settings database initialized
[hyperiond BLACKBORDER] (DEBUG) (BlackBorderProcessor.cpp:65:handleSettingsUpdate()) Set mode to: default
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:67:componentStateChanged()) Blackborder detector: enabled
[hyperiond FLATBUFCONNECTION] (INFO) Connecting to Hyperion: 127.0.0.1:19447
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:67:componentStateChanged()) LED device: enabled
[hyperiond LEDDEVICE] (DEBUG) (LedDeviceAdalight.cpp:53:init()) Adalight header for 107 leds: Ada 0x00 0x6a 0x3f
[hyperiond LEDDEVICE] (INFO) LedDevice ‘adalight’ configured.
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:67:componentStateChanged()) Smoothing: enabled
[hyperiond EFFECTENGINE] (INFO) run effect Atomic swirl on channel 0
[hyperiond HYPERION] (DEBUG) (PriorityMuxer.cpp:153:registerInput()) Register new input ‘System/EFFECT’ with priority 0 as inactive
[hyperiond HYPERION] (INFO) Inital foreground effect ‘Atomic swirl’ started
[hyperiond EFFECTENGINE] (INFO) run effect Warm mood blobs on channel 254
[hyperiond HYPERION] (DEBUG) (PriorityMuxer.cpp:153:registerInput()) Register new input ‘System/EFFECT’ with priority 254 as inactive
[hyperiond HYPERION] (INFO) Inital background effect ‘Warm mood blobs’ started
[hyperiond HYPERION] (DEBUG) (PriorityMuxer.cpp:153:registerInput()) Register new input ‘System/GRABBER’ with priority 250 as inactive
[hyperiond ComponentRegister] (DEBUG) (ComponentRegister.cpp:67:componentStateChanged()) Framegrabber: enabled
[hyperiond BOBLIGHT] (DEBUG) (BoblightServer.cpp:24:BoblightServer()) Instance created
[hyperiond DAEMON] (INFO) Hyperion initialized
[hyperiond DAEMON] (INFO) set screen capture device to ‘amlogic’
[hyperiond AMLOGICGRABBER] (DEBUG) (Grabber.cpp:33:setVideoMode()) Set videomode to 0
[hyperiond FRAMEBUFFERGRABBER] (DEBUG) (Grabber.cpp:33:setVideoMode()) Set videomode to 0
[hyperiond FRAMEBUFFERGRABBER] (INFO) Display opened with resolution: 1920x1080@32bit
[hyperiond AMLOGICGRABBER] (DEBUG) (AmlogicGrabber.cpp:31:AmlogicGrabber()) constructed(160 x 160), grabber device: /dev/amvideocap0
[hyperiond DAEMON] (INFO) AMLOGIC grabber created
[hyperiond JSONSERVER] (DEBUG) (JsonServer.cpp:23:JsonServer()) Created instance
[hyperiond JSONSERVER] (INFO) Started on port 19444
[hyperiond LEDDEVICE] (INFO) Opening UART: /dev/ttyACM0
[hyperiond LEDDEVICE] (DEBUG) (ProviderRs232.cpp:182:tryOpen()) Setting baud rate to 115200
[hyperiond LEDDEVICE] (DEBUG) (ProviderRs232.cpp:198:tryOpen()) Device blocked for 1500 ms
[hyperiond FLATBUFSERVER] (INFO) Started on port 19400
[hyperiond AMLOGICGRABBER] (INFO) FB mode
[hyperiond HYPERION] (DEBUG) (PriorityMuxer.cpp:231:setInputImage()) Priority 250 is now active
[hyperiond HYPERION] (DEBUG) (PriorityMuxer.cpp:330:setCurrentTime()) Set visible priority to 0
[hyperiond PROTOSERVER] (INFO) Started on port 19445
[hyperiond WEBSERVER] (DEBUG) (WebServer.cpp:96:handleSettingsUpdate()) Set document root to: :/webconfig
[hyperiond WEBSERVER] (INFO) Started on port 8090 name ‘Hyperion Webserver’
[hyperiond HYPERION] (DEBUG) (PriorityMuxer.cpp:231:setInputImage()) Priority 0 is now active
[hyperiond HYPERION] (DEBUG) (PriorityMuxer.cpp:192:setInput()) Priority 254 is now active
[hyperiond LEDDEVICE] (DEBUG) (ProviderRs232.cpp:216:writeBytes()) 26 frames dropped
[hyperiond LEDDEVICE] (DEBUG) (LedDeviceAdalight.cpp:80:receivedData()) >>received 2 bytes data
[hyperiond WEBSOCKET] (DEBUG) (WebSocketClient.cpp:32:WebSocketClient()) New connection from ::ffff:192.168.1.67
[hyperiond WEBSOCKET] (DEBUG) (JsonAPI.cpp:916:handleLoggingCommand()) log streaming activated for client ::ffff:192.168.1.67
I’m away, so not tried the update myself yet (got my Vero4K with me, but not my lights ). Will do upon my return.
In the meantime it might be that the version of Hyperion you’ve built is different since what you were using in June. It’s always possible that old config files won’t work if the devs change something significantly. Have a try at configuring manually/fresh through the web GUI.
mean while i tried to change setting level to “Expert” and get this error in my Log file [hyperiond HYPERION] (ERROR) setInputImage() used without registerInput() for priority '250', probably the priority reached timeout
and this
[hyperiond AMLOGICGRABBER] (ERROR) Read of device failed: 61 - No data available
Ah, the June update broke it for everyone because it included the fixes I’d submitted for the long-standing A/V sync bug. But you needed a newer version of Hyperion.ng to go with the fixes. Guess you missed the post as the time.
Installing the pre-built binaries from my installer should work with current OSMC. Starting afresh with the configuration is a good idea. And that means NO config file at all. There is no “default file” you should be copying into anywhere, if you meant that literally. Start from scratch in the webGUI.
Hyperion.ng had made some breaking changes on how it stores its settings. What used to be loose json files are now a dedicated settings database.
But fear not - the videos I made were made with the latest and greatest osmc october update and thel latest hyperion.ng master branch (actually LordGreys bleeding edge fork dueto the nanoleaf fixes).
I’d suggest rebuild from source using hissingsharks installer (I hope this will get you to latest master and not an old commit anymore by default) and just reconfigure your devices… the new webgui makes this a breeze.
Yes, this is what I was referring to about not using config files at all. Times have indeed changed.
I’ve just updated the binaries on the installer to the latest version that I’ve been testing, so not bleeding edge, but something I can vouch for.
For anything newer you can always build from source and use a newer commit number as usual.
i tried to get hyperion-ng running on my vero 4k+ but it won´t work. Maybe someone can help me.
I have hyperion installed on a Rpi Zero W and it works without any problems. On my old Android Box I hat the kodi hyperion addon and the ambilight ws also working.
Now I try to install hyperion-ng on my vero 4k+. I installed with hoissingsharks installer but the hyperion service exits with failure. Also I am not able to access the webserver mentioned in the post installation steps (myip:8090). I think there is something missing, any help would be appreciated.
Ok, well regardless of what sort of lighting setup you’ve got, even none at all, it should still run. So first thing is how are you running/starting Hyperion.ng?
Also I think the addon you mentioned is for the old Hyperion rather than ng, so none of that!
Thanks for your reply!
I try to start Hyperion with the command sudo systemctl start hyperion.service
I think there are som files / folders missing at the installation ?
