I sort of sensed it could be related to DNS, but don’t know nearly enuf to even ask the right questions
Here are the results of the commands you suggested:
ping -c2 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
--- 8.8.8.8 ping statistics ---
2 packets transmitted, 0 packets received, 100% packet loss
(NOTE: did not hit cntrl-C to end the ping)
cat /etc/resolv.conf
# Generated by Connection Manager
nameserver <xxx.xxx.xxx.x>
(Note: the nameserver ipaddr returned is my router ipaddr. Is that correct? nameserver=DNS? My Win 10 sys, which works fine, uses DNS servers (2 of 'em) that are provided by my ISP, Comcast :frowning:
host -v google.com
Trying "google.com"
;; connection timed out; no servers could be reached
Oh well, if was a good theory… 100% packet loss to an IP address isn’t good. Using the router for DNS is fine, as long as you’re not using openvpn.
If at all possible, please don’t doctor the output from commands. In this case it’s pointless since the router address is already in the log file but by doing so you might obscure some useful piece of information.
So back to the drawing board. Le’s see what we get from these commands:
Have been working with my other systems and have noticed a significant network improvement on my subnet. Seems things are back as they should be.
(171030.0)
My turn for a “D’oh!”…kind of. I was just about to provide results of your most recent suggested commands and I realized there was something I hadn’t checked. It should have been obvious because I’ve run into it before, but it’s been quite a while.
The RPI 3 has a static ipaddrs (as do some of my systems that need to be in a “certain” place). In a recent power outage, a DishNetwork DVR (which can only be DHCP’d), must have finished rebooting before the RPI 3 and grabbed its ipaddr, thus creating a collision issue for the RPI
Once I changed the RPI 3 ipaddr, things started working again. I’ve only performed very preliminary testing, but it looks good.
I think we can call this solved.
Thx much for your and everyone’s help. Sorry to have wasted unnecessary time because of my dying brain cells
That’s a good reminder that, if you use both DHCP and static IP addresses (as I do) you should always allocate the fixed addresses outside the range the DHCP allocates.
Derek
Yes - it is a router feature, if the router is where the DHCP allocation takes place.
Some people have other arrangements, so I cannot be too specific about it.
I did have one router, about a year back, which was tricky to set this up (found the easiest way was to edit a text config file) - but ended up by ditching it as there were too many other problems.
Derek
Thx. I’ve been able to set up the router for different wi-fi nets, 1 for normal and 1 for guests. What I’m using is an ASUS RT-N10P with a Tomato OS which, I hope, makes it fairly flexible. Let’s see how badly I can mess things up some more I also set the router up so it limited the range of valid ipaddrs on the subnet, but will have to sort thru about how to set up a wall between DHCP and static.
Maybe it’s not so much that I’m networked challenged but rather network timid
Well based on this picture it is fairly simple. In this picture the DHCP server just gives out addresses between 192.168.1.100 - 192.168.1.200 so you could use 192.168.1.2 - 192.168.1.99 for your static IPs. https://learntomato.com/wp-content/uploads/router-setup-ip-dhcp.jpg
