This seems to be the problem:
2020-02-22 14:37:22.557 T:3612291808 ERROR: CVideoPlayerVideo::OpenStream - Invalid framerate 10000000, using forced 25fps and just trust timestamps
I think you should be able to set a fallback framerate under PVR Settings. This should solve you problem.
For some reason the recording has an invalid framerate.
Hi Sam,
I tried enabling the fallback framerate and am still getting the same issues. Kodi log is here and the show I tried watching after enabling the setting was “Good Girls” at timestamp 23:24:15. You will also see me trying to open a live tv channel at 2020-02-23 23:22:59.279 that opens and just buffers until I close it.
http://paste.osmc.tv/tiqerecoqa
It’s still throwing the “ffmpeg[EC02B2E0]: [wtv] Could not find codec parameters for stream 2 (Video: mpeg2video, none(tv), 704x480): unspecified pixel format” error too. Any other ideas?
Change hardware acceleration to HD and up for MPEG2
Hi Sam, tried that and no change in behavior. Here is the log, tried watching “project runway”. It opened after 20 seconds and just sits buffering, getting through about 2 seconds of show per minute. Here is the log.
Paste.osmc.tv/arigejuluz
Thanks for your help!
Hopefully the issue is now addressed.
- Login via the command line
- Edit the file
/etc/apt/sources.list
- Add the following line:
- Run the following commands to update:
- Your system should have have received the update.
I also recommend you edit /etc/apt/sources.list
again and remove the line that you added after updating. This will return you to the normal update channel.
