i will try. but sometimes i reached the 300 mbps with a warm devices.
vero in the fridge?
1G - all between 25-300 mbps
100 mbps - 100mbps
back to 1G - all between 25-300 mbps
:-p no one with a Vero in bed ? :)- ;-p
worst result so far:
root@vero:/home/osmc# more /sys/class/thermal/thermal_zone0/temp
70000
root@vero:/home/osmc# iperf3 -c 10.10.10.112
Connecting to host 10.10.10.112, port 5201
[ 4] local 10.10.10.77 port 55256 connected to 10.10.10.112 port 5201
[ 4] 0.00-1.00 sec 1.61 MBytes 13.5 Mbits/sec 71 2.83 KBytes
[ 4] 1.00-2.00 sec 1.17 MBytes 9.83 Mbits/sec 60 2.83 KBytes
[ 4] 2.00-3.00 sec 1.44 MBytes 12.1 Mbits/sec 69 2.83 KBytes
[ 4] 3.00-4.00 sec 1.69 MBytes 14.2 Mbits/sec 79 2.83 KBytes
[ 4] 4.00-5.00 sec 1.82 MBytes 15.3 Mbits/sec 75 2.83 KBytes
[ 4] 5.00-6.00 sec 2.20 MBytes 18.5 Mbits/sec 91 2.83 KBytes
[ 4] 6.00-7.00 sec 2.74 MBytes 23.0 Mbits/sec 117 2.83 KBytes
[ 4] 7.00-8.00 sec 2.80 MBytes 23.5 Mbits/sec 105 2.83 KBytes
[ 4] 8.00-9.00 sec 1.29 MBytes 10.8 Mbits/sec 57 1.41 KBytes
[ 4] 9.00-10.00 sec 0.00 Bytes 0.00 bits/sec 1 1.41 KBytes
[ 4] 0.00-10.00 sec 16.8 MBytes 14.1 Mbits/sec 725 sender
[ 4] 0.00-10.00 sec 16.6 MBytes 14.0 Mbits/sec receiver
iperf Done.
ok, ok… you won
Too hot IMHO. Mine rarely goes over 55C …
70 is perfectly fine.
In May or so we stress tested heating the device up to 110C+ with iperf3 and kept the speed constant.
It sounds like clock drift. I’ll try reproduce
Same problem over here. 4K+ received today (#20007). When Ethernet is plugged in to a Netgear GS116, I get the following:
osmc@osmc:~$ iperf3 -c 10.0.0.8
Connecting to host 10.0.0.8, port 5201
[ 4] local 10.0.0.54 port 41624 connected to 10.0.0.8 port 5201
[ 4] 0.00-1.00 sec 1.33 MBytes 11.1 Mbits/sec 45 4.24 KBytes
[ 4] 1.00-2.00 sec 481 KBytes 3.94 Mbits/sec 29 4.24 KBytes
[ 4] 2.00-3.00 sec 314 KBytes 2.57 Mbits/sec 21 2.83 KBytes
[ 4] 3.00-4.00 sec 1.41 KBytes 11.6 Kbits/sec 4 1.41 KBytes
[ 4] 4.00-5.00 sec 246 KBytes 2.02 Mbits/sec 18 2.83 KBytes
[ 4] 5.00-6.00 sec 576 KBytes 4.71 Mbits/sec 28 2.83 KBytes
[ 4] 6.00-7.00 sec 389 KBytes 3.19 Mbits/sec 24 2.83 KBytes
[ 4] 7.00-8.00 sec 380 KBytes 3.11 Mbits/sec 18 1.41 KBytes
[ 4] 8.00-9.00 sec 488 KBytes 4.00 Mbits/sec 25 2.83 KBytes
[ 4] 9.00-10.00 sec 305 KBytes 2.50 Mbits/sec 18 4.24 KBytes
[ 4] 0.00-10.00 sec 4.43 MBytes 3.72 Mbits/sec 230 sender
[ 4] 0.00-10.00 sec 4.31 MBytes 3.62 Mbits/sec receiver
iperf Done.
osmc@osmc:~$ sudo ethtool -s eth0 speed 100 duplex full autoneg on
[ 4] local 10.0.0.54 port 41627 connected to 10.0.0.8 port 5201
[ 4] 0.00-1.00 sec 12.8 MBytes 108 Mbits/sec 0 294 KBytes
[ 4] 1.00-2.00 sec 12.3 MBytes 103 Mbits/sec 0 474 KBytes
[ 4] 2.00-3.00 sec 12.0 MBytes 101 Mbits/sec 0 619 KBytes
[ 4] 3.00-4.00 sec 11.5 MBytes 96.8 Mbits/sec 0 725 KBytes
[ 4] 4.00-5.00 sec 11.2 MBytes 94.2 Mbits/sec 0 829 KBytes
[ 4] 5.00-6.00 sec 11.4 MBytes 95.8 Mbits/sec 0 935 KBytes
[ 4] 6.00-7.00 sec 11.0 MBytes 92.0 Mbits/sec 0 1018 KBytes
[ 4] 7.00-8.00 sec 11.2 MBytes 94.3 Mbits/sec 0 1.07 MBytes
[ 4] 8.00-9.00 sec 11.3 MBytes 95.1 Mbits/sec 0 1.14 MBytes
[ 4] 9.00-10.00 sec 11.2 MBytes 94.1 Mbits/sec 0 1.22 MBytes
[ 4] 0.00-10.00 sec 116 MBytes 97.4 Mbits/sec 0 sender
[ 4] 0.00-10.00 sec 112 MBytes 94.2 Mbits/sec receiver
iperf Done.
Let me know if there is anything I can do to help.
So if your device is cooler it performs better too? That is odd.
That remindes me the raspberry PI WiFi Dongles I have. When they overheat - I loose throughput. Lots of it …
The thing is we had this issue in May where heat caused the TX to completely tank. This was caused by calibration issues with the PHY. Since then after some changes, we weren’t able to reproduce this.
There are a couple of devices I’m seeing:
- Completely borked TX: showing about 1-2Mbps
- TX that seems to be better, but still not quite right.
Still investigating, but in the interim we are swapping with known good units.
We’ll work it out.
@sam_nazarko What is your ETA on having an RMA system for getting a warranty replacement device free of charge without incurring any costs for the customer? In an email you said “a while”.
@sam_nazarko just to let you know that I have now received the new device, and the performance is looking much healthier!
Connecting to host 10.0.1.2, port 5201
[ 4] local 10.0.1.59 port 50623 connected to 10.0.1.2 port 5201
[ 4] 0.00-1.01 sec 113 MBytes 938 Mbits/sec 0 2.31 MBytes
[ 4] 1.01-2.00 sec 111 MBytes 938 Mbits/sec 0 2.10 MBytes
[ 4] 2.00-3.00 sec 112 MBytes 939 Mbits/sec 0 2.29 MBytes
[ 4] 3.00-4.00 sec 112 MBytes 938 Mbits/sec 0 2.45 MBytes
[ 4] 4.00-5.00 sec 112 MBytes 938 Mbits/sec 0 2.57 MBytes
[ 4] 5.00-6.00 sec 112 MBytes 938 Mbits/sec 1 1.91 MBytes
[ 4] 6.00-7.00 sec 112 MBytes 938 Mbits/sec 0 2.00 MBytes
[ 4] 7.00-8.00 sec 112 MBytes 938 Mbits/sec 0 2.07 MBytes
[ 4] 8.00-9.00 sec 112 MBytes 938 Mbits/sec 0 2.13 MBytes
[ 4] 9.00-10.00 sec 112 MBytes 938 Mbits/sec 0 2.16 MBytes
[ 4] 0.00-10.00 sec 1.09 GBytes 938 Mbits/sec 1 sender
[ 4] 0.00-10.00 sec 1.09 GBytes 937 Mbits/sec receiver
iperf Done.
osmc@osmc:/mnt/media$ iperf3 -R -c 10.0.1.2
Reverse mode, remote host 10.0.1.2 is sending
[ 4] local 10.0.1.59 port 50625 connected to 10.0.1.2 port 5201
[ 4] 0.00-1.00 sec 109 MBytes 916 Mbits/sec
[ 4] 1.00-2.00 sec 112 MBytes 936 Mbits/sec
[ 4] 2.00-3.00 sec 112 MBytes 941 Mbits/sec
[ 4] 3.00-4.00 sec 112 MBytes 942 Mbits/sec
[ 4] 4.00-5.00 sec 112 MBytes 942 Mbits/sec
[ 4] 5.00-6.00 sec 112 MBytes 942 Mbits/sec
[ 4] 6.00-7.00 sec 112 MBytes 942 Mbits/sec
[ 4] 7.00-8.00 sec 112 MBytes 942 Mbits/sec
[ 4] 8.00-9.00 sec 112 MBytes 941 Mbits/sec
[ 4] 9.00-10.00 sec 112 MBytes 941 Mbits/sec
[ 4] 0.00-10.00 sec 1.09 GBytes 940 Mbits/sec 0 sender
[ 4] 0.00-10.00 sec 1.09 GBytes 939 Mbits/sec receiver
I think I explained this to you via email yesterday; apologies if this wasn’t the case.
We have to apply for a business response license in every country; which takes a while. This will also allow us to provide simpler returns for customers in the future if they change their mind and would like to return their product.
I don’t have a firm date yet. But we have replaced all units received back to us so far. I will ping you when this is ready on the original ticket. It won’t be long.
Thanks for confirming. I’m glad you now have a device that’s working as expected. @Nightcustard was also kind enough to confirm that his replacement device is now working as expected.
We’ve stopped the possibility of dodgy devices shipping now; so this should be wrapped up shortly.
No you just replied that it will take a while. I hope it won’t take an unreasonable time.
No – it shouldn’t take too long. I am still waiting for the response license in Finland to go through.
I just want to add a comment here. I dont have these problems but still only gets around 400-600 even with a new CAT6a cable.
However since its another problem and also it runs everything I need atm I will lurk in this thread and maybe test a release now and then.
I havent even received my 4K+ and ive been lurking here for days!
In both directions? just curious.
Mayybe its a little faster the other way, but not alot. Not near 900+
