Sorry, this is my first time on here. I’m trying to get a fire stick remote to work on my raspberry PI three but I don’t know where the udev and evmap files are. Also I apologize but I’m new to raspberry pi as well so a detailed explanation is best
Thanks in advance
Well, reading this thread would indicate that all you need to do is to pair the remote with the Pi. You shouldn’t need to worry about the udev or evmap files as all of that appears to have been included for almost 2 years.
Lol, I tried that first. I made the raspberry discoverable first then held down the home button for 10seconds(I also tried the center button)
Ok, so your problem is that you can’t seem to get the FS remote paired? If that is the case, logs would be helpful.
Thanks, I will try again and upload my logs if the problem persists
Try holding home button for up to 30 secs.
