So @ashtonaut you have a final working version ?
I get notifications when packages are updated, yes. I’m pretty sure I also have notifications working on major OS updates, but I probably need to wait until the August update to confirm this 100%.
Can you post a complete how to please ? I use pushover too
Sure, when I get a chance. All the info and code is in this thread already, but I can probably roll the essentials into a Pushover how to.
I will most likely wait until the August update to confirm a few things.
OK so all this code is ok ?
push.sh
#!/bin/bash
# Uses the Pushover API to send the first command line parameter as a push notification
curl -s \
--form-string "token=YOURAPPTOKEN" \
--form-string "message=$1" \
--form-string "user=YOURUSERTOKEN" \
https://api.pushover.net/1/messages.json > /dev/null
updatecheck.sh
#!/bin/bash
# Check if OSMC has just been updated
OLDVER=$(cat /home/osmc/versionid.txt)
NEWVER=$(cat /etc/os-release | grep VERSION_ID | awk -F\" '{print $(NF-1)}')
echo "Checking if OSMC has been updated..."
if [ "$OLDVER" != "$NEWVER" ]; then
echo "OSMC has been updated, pushing notification..."
/home/osmc/push.sh "OSMC has been updated to $NEWVER"
echo $NEWVER > /home/osmc/versionid.txt
exit 0
fi
echo "No update detected"
updatecheck.service
[Unit]
Description=Run the updatecheck script once on startup after networking is up
After=network-online.target
[Service]
Type=oneshot
ExecStart=/home/osmc/updatecheck.sh | systemd-cat -t updatecheck
[Install]
WantedBy=multi-user.target
But where do you save the service ?
Service file goes in /etc/systemd/system/
Then run sudo systemctl enable updatecheck to enable and it should check each reboot.
I’m still not sure whether it’s better to run it this way, or from a hook within mediacentre.service.
Ok so I’m waiting for your news.
I wrote a HowTo post so that everything is in one place:
I’ll update the HowTo with another example if/when I can confirm the best way to notify on OSMC version updates.
I’ve updated the how-to post with instructions for pushing updates on OSMC version updates.
