yes
If there’s an issue with the 4K +; then the retry count makes sense in the TX direction; but I’m surprised to see it in the RX direction.
We have been testing these devices since end of September – which is why I’d asked if you’d bought the device from us. I’m happy to swap it over but if you could check on a different network environment I would recommend doing so.
I have tested it on two different routers, I can also try a PC laptop but I am not sure if that will bring us any more information. Unfortunately I do not have access to a gigabit router.
I managed to get access to a gigabit router and the result of a quick test is as follows. Copied from NAS SSH session:
Server listening on 5201
Accepted connection from 192.168.1.22, port 41533
[ 5] local 192.168.1.20 port 5201 connected to 192.168.1.22 port 41534
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 60.9 MBytes 511 Mbits/sec 0 67.9 KBytes
[ 5] 1.00-2.00 sec 96.6 MBytes 809 Mbits/sec 0 103 KBytes
[ 5] 2.00-3.00 sec 111 MBytes 931 Mbits/sec 0 133 KBytes
[ 5] 3.00-4.00 sec 111 MBytes 928 Mbits/sec 0 161 KBytes
[ 5] 4.00-5.00 sec 111 MBytes 928 Mbits/sec 0 182 KBytes
[ 5] 5.00-6.00 sec 112 MBytes 938 Mbits/sec 0 201 KBytes
[ 5] 6.00-7.00 sec 110 MBytes 926 Mbits/sec 0 223 KBytes
[ 5] 7.00-8.00 sec 112 MBytes 937 Mbits/sec 0 315 KBytes
[ 5] 8.00-9.00 sec 111 MBytes 928 Mbits/sec 0 320 KBytes
[ 5] 9.00-10.00 sec 111 MBytes 936 Mbits/sec 0 320 KBytes
[ 5] 0.00-10.00 sec 1.02 GBytes 877 Mbits/sec 0 sender
Accepted connection from 192.168.1.22, port 41535
[ 5] local 192.168.1.20 port 5201 connected to 192.168.1.22 port 41536
[ 5] 0.00-1.00 sec 62.3 MBytes 522 Mbits/sec
[ 5] 1.00-2.00 sec 65.1 MBytes 546 Mbits/sec
[ 5] 2.00-3.00 sec 64.9 MBytes 545 Mbits/sec
[ 5] 3.00-4.00 sec 66.1 MBytes 554 Mbits/sec
[ 5] 4.00-5.00 sec 63.6 MBytes 534 Mbits/sec
[ 5] 5.00-6.00 sec 66.2 MBytes 556 Mbits/sec
[ 5] 6.00-7.00 sec 64.4 MBytes 540 Mbits/sec
[ 5] 7.00-8.00 sec 65.6 MBytes 551 Mbits/sec
[ 5] 8.00-9.00 sec 64.7 MBytes 543 Mbits/sec
[ 5] 9.00-10.00 sec 65.3 MBytes 547 Mbits/sec
[ 5] 0.00-10.00 sec 648 MBytes 544 Mbits/sec receiver
What does that confirm?
Look at your results from all the other tests? What does that tell you? Looks to me like that you are getting good results with the latest test!
But instead if iperf tests, has your problem cleared up with the new router? That’s the real proof.
I know these are good results but that’s not my hardware. Really what I wanted to achieve was to get it to work on my 100Mb network, the test on 1Gb network was to help establish which is the problematic device. Ideally I would prefer not to buy another router only for this purpose, if possible.
