Sparkles on Screen, No Wi-Fi Option, Doesn't Reboot, Can't Detect USB Drive
You can send the device back if you keep having the sparkles.
I would see if some pressure lightly on the cable changes the appearance of the sparkles
It does. But when I let go, sparkles return.
This usually indicates that the cable isn’t making a good connection with the device
I would suggest trying with another cable
already tried 3. the other veros work well with the 3 hdmi cables.
Best get that back to us and we can take a look then
Thanks, Sam
