tried loggin in as user osmc. Response was
Sorry, user osmc is not allowed to execute ‘/bin/journalctl -f’ as osmc on osmc.
Therefore I wrote sudo journalctl -f also that is the session from the Windows build in ssh client. So you mean when you run sudo journalctl -f in the ssh session und you then try to connect from Putty no new log entry is generated?
i was using a Windows10 cmd console to run “sudo -u osmc”.
Putty is tried later to see if anything changed.
Hi, what do I do next?
Hi, what can I do next?
What can I do next?
What @fzinken told you 4 days ago:
You can learn to be a bit patient.
Since this issue only seems to affect PuTTY I’d maybe try uninstalling thay, clearing out the registry for the old settings and reinstalling
