I’ve updated via My OSMC and I’m now on 3.14.29-68-osmc.
Plugging my DVB-S USB-device into the Vero4k results in these journalctl lines:
Mär 17 12:38:04 fernseher kernel: usb 1-1: new high-speed USB device number 2 using xhci-hcd
Mär 17 12:38:04 fernseher kernel: usb 1-1: New USB device found, idVendor=0ccd, idProduct=0105
Mär 17 12:38:04 fernseher kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mär 17 12:38:04 fernseher kernel: usb 1-1: Product: TERRATEC USB Tuner
Mär 17 12:38:04 fernseher kernel: usb 1-1: Manufacturer: Tevii
Mär 17 12:38:04 fernseher kernel: usb 1-1: SerialNumber: 000000031
dmesg | grep dvb prints nothing,lsusb says Bus 001 Device 002: ID 0ccd:0105 TerraTec Electronic GmbH, but tvheadend doesn’t see any adapter.
Rebooting doesn’t help. At least no kernel crash anymore
But these errors might be helpful (or are totally unrelated )?
Mär 17 12:38:04 fernseher systemd-modules-load[176]: Failed to find module 'amlvideodri'
Mär 17 12:38:04 fernseher systemd-modules-load[176]: Failed to find module 'meson-ir'
I’ve now pushed some fixes for the video playback and remote fixes. This does mean that some DVB improvements had to be reverted; but we will resume the testing for this again shortly.
In the interim, I’d recommend updating, as this will restore some DVB functionality
It appears that the latest update to Linux OSMCVero 3.14.29-69-osmc means that DVB-T service has returned with just the one adapter showing in Tvheadend:
Progress, of sorts…
Hi!
I try the first one.
dmesg | grep dvb shows:
[ 3.006054] usb 1-1: Product: dvbt2
[ 3.006059] usb 1-1: Manufacturer: astrometadvbt2
[ 4.291193] usb 1-1: dvb_usb_v2: found a ‘Astrometa DVB-T2’ in warm state
[ 4.371804] usb 1-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 4.486502] input: MCE IR Keyboard/Mouse (dvb_usb_rtl28xxu) as /devices/virtual/input/input7
[ 4.486809] rc rc1: lirc_dev: driver ir-lirc-codec (dvb_usb_rtl28xxu) registered at minor = 1
[ 4.486824] usb 1-1: dvb_usb_v2: schedule remote query interval to 400 msecs
[ 4.497650] usb 1-1: dvb_usb_v2: ‘Astrometa DVB-T2’ successfully initialized and connected
[ 4.497772] usbcore: registered new interface driver dvb_usb_rtl28xxu
Sorry, the mn88473 I2C isn’t recognized.
That’s correct.
We had some problems with the update over the weekend so had to revert some things. We will update this thread over the next couple of days.
Any realistic estimation when the OSMC-stick will be fully working with Vero 4K?
Yesterday I (again) tried it with latest Ubuntu installation, which works out of the box after manually copying the firmware file to the setup. Thus, I would expect it can’t be that difficult to get it also running with the legacy kernel.
