I have been to busy lately to keep testing all the time but I just tried the newest build and I still have bad playback. Plus I assumed just constant saying that it didn’t work yet would not be helpful when you have the sample to test on your own.
But any hope it can be figured out sometime soon? It does seem like playback performance should be a fair high priority.
All I’m asking for is some peace of mind that it is being worked on, I have had issues including other places before where I thought something was being done and then after a month I find out it was just forgotten. For the checking of different builds nothing changes so I wanted to make sure it was not forgotten again. It is not like I’m constantly bringing it up I have waited a month since the last time.
16.8-080, 13 May 2016: Based off OSMC commit 49be9df and newclock5 (656a69da)
Build Highlights
newclock5
New commits in this build:
mmalcodec: Also wake up decoder when a new input buffer is available (656a69da)
Commits no longer in build:
[omx] Report decoded image name (c8daea72)
VideoPlayer: Different accurate value for omxplayer_mode has no effect (162c2efb)
mmalrenderer: Avoid creating presenting thread when it is not required (7a3a0d41)
mmalcodec: Set initial aligned height explicitly to avoid multiple reconfigures in renderer (a02702f0)
omxplayer: Reset the EOS state on a flush (36aac474)
rbp: Fix possible leak in rendercapture interface (87ccd49a)
omximage: Fix resolution in logging message (80f86190)
AdvancedSettings.xml is updated in the new krypton for the network section. I believe its not there within the default advancedsettings on these krypton builds.it would be nice if you can move the network section into the new cache tag.
<cache>
<memorysize>0</memorysize> <!-- number of bytes used for buffering streams in memory
When set to 0 the cache will be written to disk instead of RAM -->
<buffermode>0</buffermode> <!-- Choose what to buffer:
0) Buffer all internet filesystems (like "2" but additionally also ftp, webdav, etc.) (default)
1) Buffer all filesystems (including local)
2) Only buffer true internet filesystems (streams) (http, etc.)
3) No buffer -->
<readfactor>4.0</readfactor> <!-- this factor determines the max readrate in terms of readbufferfactor * avg bitrate of a video file.
This can help on bad connections to keep the cache filled. It will also greatly speed up buffering. Default value 4.0. -->
</cache>
Thanks - will look into this. I see there are a few other changes as well.
In the upcoming Kodi v17, the following tags are removed from network and placed under a new cache tag. Also, cachemembuffersize is renamed to memorysize and readbufferfactor is renamed to readfactor.
mmalcodec: temp: Add an extra input buffer to reduce chance of stutter after seek (54a30996)
mmalrender: Allow renderer to be reconfigered from GetPool (cd093962)
16.8-082, 16 May 2016: Based off OSMC commit 1a9335b and newclock5 (2288ed4c)
Build Highlights
newclock5
mmalrender: Allow renderer to be reconfigured from GetPool (7e5e875b)
RenderSystem: Load correct identity (3a635607)
mmal: Make some of the more verbose logging a build time option (2288ed4c)
It’s been a while since I last updated, but apt-get update is failing with the following message: W: Failed to fetch http://download.osmc.tv/dev/gmc/./Packages 404 Not Found
