16.8-018, 29 Jan 2016: Based off OSMC commit 2758244 and newclock5 commit 6962f5de
newclock5:
Commits no longer in build:
AE: rework stream status bc92393a
VideoPlayer: fix incorrectly accessed members in SetPlaySpeed 2493c8ce
VideoPlayer: fix race introduced by double caching av infos a9785c82
VideoPlayer: fix setting caching at end of stream 4315018e
16.8-019, 31 Jan 2016: Based off OSMC commit 25635e6 and newclock5 commit e03574bb7
Issues
Due to recent changes in the skin xml files some of the dialog buttons no longer work in Amber/OSMC etc skin. For the meantime please Confluence skin which has been updated to reflect the new xml files.
Update libcec library
For this build you will need to install libcec version 3.0.1-14
New commits in this build:
AE: fix update of buffered time d33187e1
AE: fix number of provided buffers for PT 6e00bf97
AE fix endless loop after stream rework 906f29b2
AE: update resample ratio in GetStreamInfo 8207feea
AE: provide only limited buffers to input stream e03574bb
Hello GMC, I run the “wget http://download.osmc.tv/dev/gmc/rbp2-libcec-osmc.deb2 -O /tmp/rbp2-libcec-osmc.deb && sudo dpkg -i /tmp/rbp2-libcec-osmc.deb && sudo systemctl start mediacenter” and is installed correctly (I not get error) , but check the version remains the 3.1.0-1 . At the moment I 'm at work , for this reason that I attach a screenshot screen , I’ll be sending it when you can.
Thank you for you help.
16.8-020, 1 Feb 2016: Based off OSMC commit 25635e6
and newclock5 commit 8aa778c35
newclock5:
[VideoPlayer] ssif remux 6b2cc158
fixup! [VideoPlayer] Support filename mangling for MVC files v2 82583006
fixup! [VideoPlayer] ssif remux 874cb627
ActiveAE: Enable display lost callbacks for EGL a13832b2
hack: Avoid videoplayer deadlock 8aa778c3
mmalrender: Reject unsupported render formats 5a237802
omxaudio: Avoid reporting a spurious cached value 1e06ae0a
[wip] ssif remux 9ba2dd14
[ssif] re-factoring. b2c32bef
fixup! [ssif] re-factoring. 85de51f7
OMXAudio: Make use of m_bGotFrame to skip decoding when full 58091c39
OMXAudio: Handle GetData before adding the next buffer so we can be sure it fits 73206c91
OMXAudio: Handle changes in decoded audio size correctly fd4dce27
paplayer: fix passthough after rework of codecs and AE a81f0e83
VideoPlayer: fix incorrectly determined audio sync error 24863071
AE: fix update of buffered time [d33187e1] (AE: fix update of buffered time (after refactoring) · popcornmix/xbmc@d33187e · GitHub)
Revert “ActiveAE: Enable display lost callbacks for EGL” 19e22cfa
VideoPlayer: Avoid deadlock with m_StateSelection c48d21e5
VideoPlayer: Handle lost display with pause/resume ede0de7f
Revert “VideoPlayer: Handle lost display with pause/resume” 0f75e179
AE: fix number of provided buffers to input stream, Commit:86301d8 already fixed GetCacheTime and added resample buffers a second time e9f17179
Updated commits in this build:
[VideoPlayer] ssif remux (6b2cc158 => ce5d853e
