Is OSMC using DNSMASQ? I’ve been working through some issues with Tomato router software which relies on the latest version quite heavily, and been seeing a lot of buggy-ness with it. Just wanted to highlight it here incase you wanted to create a special DNSMASQ test case.
No – OSMC doesn’t use any dns proxying at all by default
Right on, I’ve been jumping between so many systems lately I wasn’t sure, but wanted to call it out since it’s been a week long nightmare with Tomato.
17.8-070, 12 May 2017: Based off OSMC commit (079694e) and newclock5 (02a87fc1d)
OSMC:
Added pvr.mythtv back in
New addon: vfs.rar
XBMC:
[windows] add x64 (PR:12065, 6 commits, 14 files changed)
[filesystem] ZipManager: skip path traversal (PR:12023, 1 commit, 4 files changed)
[Android] Update AndroidKey.cpp (PR:12000, 1 commit, 1 file changed)
webserver improvements (PR:12072, 9 commits, 18 files changed)
newclock5:
New commits in this build:
avoid unneccesary work (3da202f1)
GUIControl: revert for poster view issue (02a87fc1)
Includes latest addons: inputstream.adaptive (7bde41f9), inputstream.rtmp (1052cd37), peripheral.joystick (07aa1fe8), pvr.argustv (8f898149), pvr.demo (978f4289), pvr.dvblink (b7d887c1), pvr.dvbviewer (d099cfad), pvr.filmon (0f1d34d4), pvr.hdhomerun (ab911693), pvr.hts (3911c7fe), pvr.iptvsimple (f83990a4), pvr.mediaportal.tvserver (367b1284), pvr.mythtv (9aeb5e9d, +3), pvr.nextpvr (e6ece9fa), pvr.njoy (296f558f), pvr.octonet (2a63777b, +2), pvr.pctv (eab5f856), pvr.stalker (62b7908d), pvr.vbox (60017353), pvr.vdr.vnsi (b7c3f3b0), pvr.vuplus (78df0306), pvr.wmc (27a88ca2), vfs.rar (26800ebe)
Hi gmc. Is it possible to get game.libretro.scummvm working? If yes - how? Sorry about this maybe noobish question… Thank u.
I’ll try another build and include it and see if it compiles. Last time I checked ( a few weeks ago) it failed to compile.
Thanks - this would be awesome. Waiting for playing maniac mansion and simon the soccerer …
Just so you know, after updating to latest, I get a loop Sad face
Have you tried stopping Kodi, renaming .kodi to .kodi.old and restarting again?
If you still have issues please post debug logs.
Went back to 17.8-069 (as 17.8-070 was not available (??)) and it’s all fine.
Will it help you if I go back to 17.8-071 or it doesn’t really matter?
Probably best to wait for a new build and see if you still have issues. Its been a few days since the last build as I’m having issues with inputstream. Hopefully this will be fixed soon.
17.8-071, 14 May 2017: Based off OSMC commit (09c4cdeb) and newclock5 (320475)
Build Highlights:
New MusicDB schema v64
[Music] Handle duplicate MusicBrainzTrackID within the same album
Build Details:
XBMC:
[Music] Handle duplicate MusicBrainzTrackID within the same album (PR:12079, 1 commit, 2 files changed)
[depends] libcec: don’t query git information (PR:12081, 1 commit, 2 files changed)
[cleanup] remove unused fields, variables and enum (PR:12073, 5 commits, 11 files changed)
Joysticks: Fix iMON conflicts by allowing users to enable/disable interfaces (PR:11944, 2 commits, 14 files changed)
Sorting using artist sort name tags (#11738) (ac10c3d3)
[cosmetics] Copyright year update, xbmc.org to kodi.tv (#11976) (46a04aff)
peripheral.joystick:
Fix iMON conflicts by allowing settings to enable/disable interfaces (PR:98, 4 commits, 34 files changed)
Includes latest addons: inputstream.adaptive (7bde41f9), inputstream.rtmp (1052cd37), peripheral.joystick (fc8a0b3d, +4), pvr.argustv (8f898149), pvr.demo (978f4289), pvr.dvblink (b7d887c1), pvr.dvbviewer (d099cfad), pvr.filmon (0f1d34d4), pvr.hdhomerun (ab911693), pvr.hts (3911c7fe), pvr.iptvsimple (f83990a4), pvr.mediaportal.tvserver (367b1284), pvr.mythtv (9aeb5e9d, +3), pvr.nextpvr (e6ece9fa), pvr.njoy (296f558f), pvr.octonet (2a63777b, +2), pvr.pctv (eab5f856), pvr.stalker (62b7908d), pvr.vbox (60017353), pvr.vdr.vnsi (b7c3f3b0), pvr.vuplus (78df0306), pvr.wmc (27a88ca2), vfs.rar (26800ebe)
17.8-072, 24 May 2017: Based off OSMC commit (df859cdf5) and newclock5 (7d2dc0a)
OSMC
Temporarily removed libretro game addons due to breakage
Temporarily removed pvr.mythtv, pvr.octonet, pvr.dvbviewer, pvr.iptvsimple pvr.mediaportal.tvserver due to breakage
Temporarily removed inputstream.adaptive due to breakage
XBMC:
Update README.raspberrypi (PR:12146, 1 commit, 1 file changed)
[addons] remove the ‘void ADDON_Stop()’ call (PR:12143, 7 commits, 30 files changed)
[gui] refactor GUIIncludes class (PR:12129, 1 commit, 3 files changed)
Fix libdvdcss-2 hooking which was broken after a8a3a0db60171328fb962b… (PR:12149, 1 commit, 1 file changed)
SMBFile: Clean Up (PR:12145, 2 commits, 1 file changed)
Update kodi.txt.in - add libbluray2 (PR:12142, 1 commit, 1 file changed)
[game] change to new addon to kodi callback way (PR:12133, 1 commit, 14 files changed)
[cmake] fix addon depends check if headers are in separate folders (PR:12132, 1 commit, 1 file changed)
VideoPlayer: some codecs have no extradata (PR:12139, 1 commit, 1 file changed)
[python] fix ListItem being forced to be a video item after 27dc9a69 (PR:12137, 1 commit, 2 files changed)
platinum: Fix upnp:lastPlaybackPosition parsing (PR:12119, 2 commits, 2 files changed)
VideoPlayer: vaapi - temp disabled runtime check (80e67ba7)
A new AudioEngine sink for sndio (PR:11962, 1 commit, 7 files changed)
Fix for devinput driver in newer version of lirc (PR:10993, 1 commit, 1 file changed)
[xbmc][cmake][win32] Use PCH as intended to speed up build (PR:12138, 1 commit, 11 files changed)
silence stat errors in texture cache job (PR:12123, 1 commit, 1 file changed)
CVideoDatabase: fix setting named seasons when updating tvshow details (PR:12099, 1 commit, 2 files changed)
[inputstream] change to new addon to kodi callback way (PR:12126, 1 commit, 12 files changed)
[cleanup] silence compiler warnings (PR:12094, 7 commits, 11 files changed)
[cmake] move ifdef conditions to cmake (PR:12131, 1 commit, 20 files changed)
[buildsteps][windows] postfix setup filename with architecture (PR:12118, 1 commit, 2 files changed)
[cmake] bump required vaapi version to 0.39 (libva 1.7.3) (PR:12107, 1 commit, 1 file changed)
[gui][refactor] rework custom window’s visible condition and modality handling (PR:12096, 1 commit, 7 files changed)
[gui] refactor methods involved in loading windows (PR:12121, 2 commits, 5 files changed)
[adsp] change to new addon to kodi callback way (PR:12124, 1 commit, 11 files changed)
[peripheral] change to new addon to kodi callback way (PR:12117, 1 commit, 12 files changed)
[addons] Remove not needed parts (PR:12109, 3 commits, 32 files changed)
[pvr] rename addon callbacks to a “C” name (PR:12115, 1 commit, 2 files changed)
[cmake][addons] change binary addon includes cmake install way (PR:12114, 2 commits, 13 files changed)
[pvr] change to new addon to kodi callback way (PR:12116, 1 commit, 13 files changed)
[Music]Fix Cue sheet regression and improve handling (PR:12082, 2 commits, 13 files changed)
Update on kodi to addon interface (PR:109, 1 commit, 2 files changed)
pvr.argustv:
Update on kodi to addon interface (PR:70, 1 commit, 3 files changed)
pvr.demo:
Update on kodi to addon interface (PR:48, 1 commit, 2 files changed)
pvr.dvblink:
Update on kodi to addon interface (PR:90, 1 commit, 3 files changed)
pvr.filmon:
Update on kodi to addon interface (PR:73, 1 commit, 3 files changed)
pvr.hdhomerun:
Update on kodi to addon interface (PR:47, 1 commit, 3 files changed)
pvr.hts:
Update on kodi to addon interface (PR:305, 1 commit, 3 files changed)
pvr.mediaportal.tvserver:
Update on kodi to addon interface (PR:68, 1 commit, 3 files changed)
pvr.njoy:
Update on kodi to addon interface (PR:41, 1 commit, 3 files changed)
pvr.pctv:
Update on kodi to addon interface (PR:50, 1 commit, 3 files changed)
pvr.stalker:
Update on kodi to addon interface (PR:97, 1 commit, 3 files changed)
pvr.vbox:
Update on kodi to addon interface (PR:196, 1 commit, 3 files changed)
pvr.vuplus:
Update on kodi to addon interface (PR:65, 1 commit, 3 files changed)
pvr.wmc:
Update on kodi to addon interface (PR:56, 1 commit, 3 files changed)
newclock5:
ffmpeg: hevc: fixup x86 (7600a75f)
fixup: MMALFFmpeg: Add Sand/YUVUV128 support (7d2dc0a1)
Commits no longer in build:
fixup: Avoid hiding splash (7ea11cd8)
DVDDemuxFFmpeg: max_packet_size - use GetBlockSize directly (f1c3fc95)
ffmpeg: hevc: Update to latest version (a3895076)
RBP: Add api to query gpu frame geometry (ecf8cf66)
MMALFFmpeg: Add Sand/YUVUV128 support (8fa5bdf7)
ffmpeg: hevc: fixup non-neon (ffcfc8db)
Includes latest addons: inputstream.rtmp (d93d32d4, +2), peripheral.joystick (1b19a511, +9), pvr.argustv (b281e04f, +5), pvr.demo (ffee02b8, +5), pvr.dvblink (6d42eae1, +5), pvr.dvbviewer (3f05af60, +5), pvr.filmon (300c595e, +5), pvr.hdhomerun (9073b99b, +5), pvr.hts (7f998e0f, +5), pvr.iptvsimple (dbf6011e, +5), pvr.mediaportal.tvserver (07d73f3a, +5), pvr.mythtv (f2da22ca, +7), pvr.nextpvr (239dbef3, +5), pvr.njoy (4785afd2, +5), pvr.octonet (ff41fc9a, +5), pvr.pctv (f61e2541, +5), pvr.stalker (151e3d3f, +6), pvr.vbox (df9efea4, +5), pvr.vdr.vnsi (40dc17d0, +4), pvr.vuplus (83a729ea, +5), pvr.wmc (93cebfc7, +5), vfs.rar (4ce78b0f, +1)
17.8-073, 28 May 2017: Based off OSMC commit (59d6728) and newclock5 (df6281d)
OSMC
Added back libretro game addons
Added back inputstream.adaptive
XBMC:
[depends] Bump samba-gplv3 to version 4.1.23 (PR:12147, 1 commit, 6 files changed)
newclock5:
fixup! MMALFFmpeg: Add Sand/YUVUV128 support (3d4cfcfc)
ffmpeg: hevc: fixup pi1 (df6281d6)
Includes latest addons: inputstream.adaptive (52eb1de3), inputstream.rtmp (d93d32d4), peripheral.joystick (1b19a511), pvr.argustv (b281e04f), pvr.demo (ffee02b8), pvr.dvblink (6d42eae1), pvr.dvbviewer (3f05af60), pvr.filmon (300c595e), pvr.hdhomerun (9073b99b), pvr.hts (7f998e0f), pvr.iptvsimple (dbf6011e), pvr.mediaportal.tvserver (07d73f3a), pvr.mythtv (f2da22ca), pvr.nextpvr (239dbef3), pvr.njoy (4785afd2), pvr.octonet (3494c4c4, +6), pvr.pctv (f61e2541), pvr.stalker (151e3d3f), pvr.vbox (df9efea4), pvr.vdr.vnsi (40dc17d0), pvr.vuplus (83a729ea), pvr.wmc (93cebfc7), vfs.rar (4ce78b0f)
hi gmc. did you managed get scummvm working? Can’t try till tomorrow… br
No luck yet. Getting a compile error:
/tmp/ccPNfcMN.s: Assembler messages:
/tmp/ccPNfcMN.s:936: Error: branch out of range
Makefile.common:491: recipe for target 'engines/gob/mult.o' failed
make[6]: *** [engines/gob/mult.o] Error 1
damned. thanks for trying…
Guessing now that krypton is all but done you and Sam will be joining forces on Leia
Will keep at it and see if we can get it going. Might also be a issue upstream
17.8-074, 29 May 2017: Based off OSMC commit (77f31a6fb7) and newclock5 (2d8449f)
OSMC
Added back pvr.mythtv, pvr.octonet, pvr.dvbviewer, pvr.iptvsimple pvr.mediaportal.tvserver
Build Highlights:
cmake changes
Build Details:
XBMC:
[cmake] improve addon related version handling (PR:12172, 2 commits, 3 files changed)
[cmake] platform changes (PR:12134, 1 commit, 27 files changed)
Includes latest addons: inputstream.adaptive (f1f5539d, +3), inputstream.rtmp (d93d32d4), peripheral.joystick (f49fa337, +5), pvr.argustv (b281e04f), pvr.demo (ffee02b8), pvr.dvblink (6d42eae1), pvr.dvbviewer (3f05af60), pvr.filmon (300c595e), pvr.hdhomerun (9073b99b), pvr.hts (7f998e0f), pvr.iptvsimple (dbf6011e), pvr.mediaportal.tvserver (07d73f3a), pvr.mythtv (f2da22ca), pvr.nextpvr (239dbef3), pvr.njoy (4785afd2), pvr.octonet (9bbd7cf3, +9), pvr.pctv (f61e2541), pvr.stalker (151e3d3f), pvr.vbox (df9efea4), pvr.vdr.vnsi (40dc17d0), pvr.vuplus (83a729ea), pvr.wmc (93cebfc7), vfs.rar (4ce78b0f)
