[TESTING] Kodi 18 (Leia) builds for Raspberry Pi
17.8-111, 6 Oct 2017: Based off OSMC commit (9572781261) and newclock5 (9fbbd7)
XBMC:
fixed: we need to decrease init level before tearing down services (PR:12880, 1 commit, 1 file changed)
pvr.hts:
Misc fixes. (PR:333, 2 commits, 11 files changed)
newclock5:
New commits in this build:
OMXImage: Avoid clamping resolution of photos to display size (9fbbd7b3)
Includes latest addons: inputstream.adaptive (dde3921), inputstream.rtmp (26260c9), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (619b55e, +2), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (8965048), pvr.nextpvr (03933e9), pvr.njoy (cc1cb56), pvr.octonet (e9b4c05), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (94bb643), pvr.vbox (ff01396), pvr.vdr.vnsi (f3f80d5), pvr.vuplus (5e154bc), pvr.wmc (7e2cb4b), pvr.zattoo (73009cd)
17.8-112, 8 Oct 2017: Based off OSMC commit (ab469445) and newclock5 (fdfe75d)
XBMC:
add additional binary support to BUILD_DIR support in addon helper (PR:12881, 1 commit, 1 file changed)
AESinkPULSE: Allow pulseaudio 11 new option remixing-use-all-sink-channels=no (PR:12874, 1 commit, 1 file changed)
Fix black screen on Snes9x emulators when ROM is missing (PR:12882, 1 commit, 2 files changed)
pvr.teleboy:
Add HTML body to debug in case login fails (df0aa7d)
Fix login for free accounts (1cf8e96)
I have an issue with this update mate, when I install it and reboot I have no text on any menus, none, anywhere…I can’t post a debug log as Im unable to turn on debugging in this state.
Heres a normal log, not sure if its any help:
ive rolled back to 17.8-111 and the text is as expected.
Cheers.
Thanks. Looks like a know issue. Should be fixed in the next build.
This fixes the missing fonts/labels on RPi2
Ok cool, I’ll wait this one out.
17.8-113, 9 Oct 2017: Based off OSMC commit (ba6ef12cb) and newclock5 (fdfe75d)
OSMC:
Temp remove game.libretro.beetle-psx
XBMC:
Controller dialog: Resize layouts (PR:12884, 2 commits, 3 files changed)
GLES: fix accidentally changed code for fonts (PR:12890, 1 commit, 1 file changed)
AESinkAudioTrack: Verify ENCODING_IEC61937 before using it (PR:12862, 3 commits, 2 files changed)
pvr.hts:
Fix windows build (missing ssize_t type definition) after #334 (PR:335, 1 commit, 3 files changed)
Fix windows build (missing ssize_t type definition), take 2. (PR:336, 1 commit, 2 files changed)
Fix windows build (missing channel_type_t definition). (PR:337, 1 commit, 1 file changed)
Includes latest addons: inputstream.adaptive (dde3921), inputstream.rtmp (26260c9), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (9765663, +1), pvr.filmon (7a9af25, +1), pvr.hdhomerun (ddfe2cb, +1), pvr.hts (0530971, +15), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (fa1069d, +1), pvr.mythtv (8965048), pvr.nextpvr (5b7caa2, +1), pvr.njoy (cc1cb56), pvr.octonet (e9b4c05), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (1cf8e96, +2), pvr.vbox (56052da, +1), pvr.vdr.vnsi (f3f80d5), pvr.vuplus (c53478d, +1), pvr.wmc (02edba6, +1), pvr.zattoo (73009cd)
I am running the latest build, but all my front are still gone??
Running on a PI3, hope there is a easy way to fix this :slight_smile:
Just checked the previous build and for some reason the fix was not included. It will be in the next buid
Sorry, I am new here and I don’t know if I can post a bug here. By the way… I installed lastest build for RPi3 today and I discovered that Plex Addon is not working. It is eternally in a looping with the 3 points of the initial screen.
Give it a day or so (nightlies break).
Otherwise a debug log will help, as will contacting the Plex add-on dev.
17.8-114, 12 Oct 2017: Based off OSMC commit (40e04c4c2) and newclock5 (5b92e68)
XBMC:
[depends] bump libgpg-error to 1.27 (PR:12902, 1 commit, 1 file changed)
language file - update window names (PR:12878, 1 commit, 8 files changed)
fix MusicPlaylistEditor (PR:12879, 1 commit, 2 files changed)
Add infos about toolset parameter to cmake docs (PR:12904, 1 commit, 1 file changed)
Fix seek on left with some SNES controllers (PR:12889, 2 commits, 3 files changed)
peripheral.joystick:
Another round of buttonmaps (PR:125, 5 commits, 13 files changed)
pvr.zattoo:
Search for logos in system addons path (29f7925)
Fix windows build (0c759d8)
Search for eit_categories.txt in system addon path (afeb49f)
newclock5:
ffmpeg: hevc: update to latest version (5b92e68c)
Includes latest addons: inputstream.adaptive (dde3921), inputstream.rtmp (26260c9), peripheral.joystick (a5cc154, +5), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (9765663, +1), pvr.filmon (7a9af25, +1), pvr.hdhomerun (ddfe2cb, +1), pvr.hts (0530971, +15), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (fa1069d, +1), pvr.mythtv (8965048), pvr.nextpvr (5b7caa2, +1), pvr.njoy (cc1cb56), pvr.octonet (e9b4c05), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (1cf8e96, +2), pvr.vbox (56052da, +1), pvr.vdr.vnsi (f3f80d5), pvr.vuplus (c53478d, +1), pvr.wmc (02edba6, +1), pvr.zattoo (afeb49f, +5)
Do you know if this one includes the fix for the missing fonts buddy?
Yes, this build includes the fix.
17.8-115, 13 Oct 2017: Based off OSMC commit (8f87ae672) and newclock5 (a7ee598)
XBMC:
Joysticks: Fix accelerometers preventing screensaver (PR:12892, 2 commits, 5 files changed)
Several compiler warnings and code improvements (PR:12883, 10 commits, 17 files changed)
drm rework and atomic prep (PR:12911, 7 commits, 12 files changed)
VideoPlayer: keyframes (PR:12912, 3 commits, 9 files changed)
Estuary: Add game add-ons widget to homescreen games tab (PR:12909, 1 commit, 1 file changed)
[PVR] Handle addon enabled|disabled via CAddonMgr events. (PR:12905, 1 commit, 8 files changed)
[PVR] Make EPG database threadsafe. (PR:12906, 1 commit, 7 files changed)
RetroPlayer: Fix black screen on OpenGL (PR:12907, 3 commits, 7 files changed)
Revert “VideoPlayer: keyframes” (PR:12916, 1 commit, 9 files changed)
fixed: fix multitrack support for audio decoders (PR:12870, 3 commits, 7 files changed)
VideoPlayer: render gui layer on first frame (PR:12915, 1 commit, 2 files changed)
estouchy - remove HP icc profile (PR:12914, 1 commit, 1 file changed)
Update game client selection dialog (shown before game) (PR:12908, 3 commits, 6 files changed)
pvr.zattoo:
Add missing categories (e941bae)
newclock5:
Commits no longer in build:
[demuxer] Avoid memcpy on every demuxer packet (41c760ec)
Includes latest addons: inputstream.adaptive (dde3921), inputstream.rtmp (26260c9), peripheral.joystick (a5cc154, +5), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (9765663, +1), pvr.filmon (7a9af25, +1), pvr.hdhomerun (ddfe2cb, +1), pvr.hts (0530971, +15), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (fa1069d, +1), pvr.mythtv (8965048), pvr.nextpvr (5b7caa2, +1), pvr.njoy (cc1cb56), pvr.octonet (e9b4c05), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (1cf8e96, +2), pvr.vbox (56052da, +1), pvr.vdr.vnsi (f3f80d5), pvr.vuplus (c53478d, +1), pvr.wmc (02edba6, +1), pvr.zattoo (e941bae, +6)
I did experience that I can not connect to KODI via yatze or Kore android remote app.
Web access is working
VNC connect is working
Is this a know problem?
Thanks T
Works for me, did you configure all settings correctly?
think so, before upgrading it was working.
zeroconf is open
port 8080 is open
what could I check as well?
Let me update, maybe I am not on latest version
Allow remote controll from other systems?
I allow control from other devices
  • can connect via putty, cia vnc, via web chorus, but not yatze, kore.
    dlna is also open
