Testing the new pvr teleboy addon, had some strange behaviour when losing the wired connection on Leia 18.
It was offline for a few hours after replugging the wire the Teleboy PVR addon still had no information. Even rebooting did not help. After disable/enable the addon the sad face was displayed. Then I repluged the wire tried to start the addon, and the sad face came again. Then i delete epg data und re-entered the login infos, sad face again but after that the plugin started to work again. There is some segment fault on crash.
systemctl output:
Dec 15 10:48:50 osmc systemd[1]: Time has been changed
Dec 15 10:48:50 osmc systemd[1]: apt-daily-upgrade.timer: Adding 27min 40.239099s random time.
Dec 15 10:48:50 osmc systemd[1]: apt-daily.timer: Adding 23min 52.055165s random time.
Dec 15 10:48:50 osmc ntpd[524]: receive: Unexpected origin timestamp 0xddde1901.284226a4 does not match aorg 0000000000.00000000 from server@120.25.115.19 xmt 0xddde1902.105256d9
Dec 15 10:48:50 osmc ntpd[524]: receive: Unexpected origin timestamp 0xddde1901.2544a1ae does not match aorg 0000000000.00000000 from server@92.223.73.5 xmt 0xddde1902.101a07e4
Dec 15 10:51:14 osmc sudo[388]: pam_unix(sudo:session): session closed for user osmc
Dec 15 10:51:14 osmc mediacenter[320]: /usr/bin/mediacenter: line 142: 388 Segmentation fault sudo -u osmc $KODI --standalone -fs --lircdev /var/run/lirc/lircd
Dec 15 10:51:14 osmc mediacenter[320]: Kodi exited with return code 139 after 0 hours, 2 minutes and 53 seconds
Dec 15 10:51:15 osmc kernel: Console: switching to colour frame buffer device 240x67
Dec 15 10:51:25 osmc mediacenter[320]: Starting Kodi…
Dec 15 10:51:25 osmc sudo[1159]: root : TTY=unknown ; PWD=/ ; USER=osmc ; COMMAND=/usr/lib/kodi/kodi.bin --standalone -fs --lircdev /var/run/lirc/lircd
Dec 15 10:51:25 osmc sudo[1159]: pam_unix(sudo:session): session opened for user osmc by (uid=0)
Dec 15 10:51:26 osmc kernel: Console: switching to colour dummy device 80x30
Dec 15 10:51:26 osmc mediacenter[320]: inactive
I did a IP lookup and the NTP Servers are in korea and china, that gave an odd timestamp. My timezone is same as amsterdam, so why osmc trying this ones. I think local one would be faster.
muchas gracias!
Rpi3@4.9.29-11-osmc
