[TESTING] Kodi 18 (Leia) builds for Raspberry Pi
I installed the ‘Pandora slim’ from the gominoa repo today, and that one is working fine.
It gets the next 4 songs and when it reaches the last one, then it gets 4 more.
Same settings as the pandoki one. Give it a try :slight_smile:
Testing the latest and it froze and using grab-logs -A command I get this back “Logs available at https://paste.osmc.tv/”
Means your logs are too large to send to paste.osmc.tv
Well it takes about 2 hours to make it freeze how else to grab the log ?
How big is the log?
Under /home/osmc/.kodi/temp
Alright got to crash opening the game https://paste.osmc.tv/yakipepija
Its on a Raspberry pi if you want it i will need the commands for putty
This crashed while changing TV channels
The logs are spammed full of these errors:
15:40:59.049 T:1710224096   ERROR: AddOnLog: Joystick Support: ScanEvents: failed to read joystick "U-COMM USB Controller" on /dev/input/js0 - 19 (No such device)
That is a MATRICOM G-PAD EX wireless remote
17.8-242, 5 June 2018: Based off OSMC commit (c5d503baa) and newclock5 (3aaf80)
OSMC:
  • Temp remove game.libretro.bsnes-mercury-accuracy, scummvm due to build errors (c5d503)
  • Add patch to get libretro working (164dc40)
XBMC:
  • Fix games running at partial speed (PR:13961, 1 commit, 1 file changed)
  • [PVR] PVRGUIInfo: Fix clock format handling for PVR.Timeshift(Start|End|Play)Time and PVR.EpgEventFinishTime. (PR:13966, 1 commit, 3 files changed)
  • [guiinfo] Fix: ‘Skin.String(string1, string2)’ did not work if string2 was empty. (PR:13970, 1 commit, 3 files changed)
  • don’t depend on m_alreadyStarted when doing GetInfo() vis addon inquiry (PR:13940, 1 commit, 1 file changed)
  • add video settings for HDR tone mapping (PR:13968, 4 commits, 14 files changed)
  • RetroPlayer: Fixes and improvements (PR:13967, 5 commits, 40 files changed)
  • Tone Mapping: Workaround real life (PR:13973, 2 commits, 2 files changed)
  • Games: Compiler warning and typo fixes (PR:13962, 5 commits, 24 files changed)
  • VideoPlayer: vdpau - fix deepcopy of VideoPictue (PR:13964, 1 commit, 1 file changed)
  • VideoPlayer: update renderer after a resolution change (PR:13971, 1 commit, 1 file changed)
  • [videoplayer][pvr] Fix crash when copying language codes. (PR:13960, 1 commit, 2 files changed)
  • fix issues related to DialogBusy (PR:13954, 6 commits, 18 files changed)
  • [guiinfo] Fix LISTITEM_RATING parameter handling. (PR:13963, 1 commit, 1 file changed)
  • add GUIDialogNoCancel - work around (PR:13958, 1 commit, 6 files changed)
pvr.zattoo:
  • Improve handling of recordings (73891b1)
inputstream.adaptive:
  • [DASH] Don’t update initial base_time / decrease base_time to reflect PTO’s (babcca4)
Ok recreated Kodi freeze from going from live tv to Movie Library
Raspberry pi-3 version 17.8-241
https://paste.osmc.tv/itavacixeh
osmc@osmc:~$ df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 369M 0 369M 0% /dev
tmpfs 374M 9.7M 364M 3% /run
/dev/mmcblk0p2 29G 11G 18G 38% /
tmpfs 374M 0 374M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 374M 0 374M 0% /sys/fs/cgroup
/dev/mmcblk0p1 240M 23M 217M 10% /boot
tmpfs 75M 0 75M 0% /run/user/1000
able to recreate it faster this time Going from Live TV to Movie Library
Kodi Froze https://paste.osmc.tv/geqiwuvasu
Ok updated to 8-242 and the Kodi freeze continues. Question after a hard reboot I get a new IP address is this normal ?
https://paste.osmc.tv/ucaxegoyah
Depends on your routers DHCP lease. It might have expired at the time of the reboot.
Thanks !
17.8-243, 8 June 2018: Based off OSMC commit (5d559cd) and newclock5 (3aaf80)
OSMC:
  • Temp remove game.libretro.mame, steamcontroller due to build issues
XBMC:
  • windowing/gbm: set fullscreen flag and other small fixes (PR:13977, 4 commits, 8 files changed)
  • [guiinfo] Fix after 2cef6e4 - skin.string label broken (PR:13981, 1 commit, 3 files changed)
  • [tools] win32: build ffmpeg with openssl instead of schannel (PR:13979, 1 commit, 1 file changed)
  • Dont skip behind Now on live streams (1962cfd)
  • log / fail on kNoKey DRM Error (6a1a765)
  • [HLS] Fix url base path retrieval (02b3197)
  • Version bump 2.2.21 (765cf22)
Includes latest addons: inputstream.adaptive (765cf22, +4), inputstream.rtmp (b8e3f39), peripheral.joystick (80224e1), pvr.argustv (2bce465), pvr.demo (20d81d8), pvr.dvblink (a87258b), pvr.dvbviewer (884b732), pvr.filmon (470ca1c), pvr.hdhomerun (4639740), pvr.hts (4f7196d), pvr.iptvsimple (e220777), pvr.mediaportal.tvserver (c4e32b0), pvr.mythtv (9d15025), pvr.nextpvr (78a80de), pvr.njoy (5a2c2d3), pvr.octonet (54680a3), pvr.pctv (17c1897), pvr.stalker (0700069), pvr.teleboy (3e9e537), pvr.vbox (48ffcba), pvr.vdr.vnsi (a2880c7), pvr.vuplus (6c94eec), pvr.wmc (a7ec576), pvr.zattoo (73891b1, +1), vfs.libarchive (84a4876)
Could this build introduce syncing issues? I have some since upgrade from latest 17.6 June release [HOW-TO ALL PLATFORMS]Can I use Netflix on OSMC?(post 4) - #180 by tiroy
17.8-244, 11 June 2018: Based off OSMC commit (76116c1db) and newclock5 (5fa5e50)
XBMC:
  • Games window: Fix error playing standalone cores (PR:13989, 1 commit, 1 file changed)
  • Games: Fix standalone games creating savestate files in app dir (PR:13990, 1 commit, 2 files changed)
  • Various copy operator optimizations (and several small cleanups) (PR:14005, 8 commits, 7 files changed)
  • [PVR] Addon API 5.10.0: New API function GetStreamReadChunkSize. (PR:14002, 1 commit, 9 files changed)
  • Do not use CURL::proxy for localhost (PR:13995, 1 commit, 1 file changed)
  • [c-pluff] kill another implicit function declaration warning (PR:13998, 1 commit, 2 files changed)
  • kodi-send: Add option to send a key press event (PR:13804, 4 commits, 1 file changed)
  • CHelper_libXBMC_addon: Avoid buffer overflow in Log (PR:13984, 1 commit, 1 file changed)
  • Log redacted URL in case of CURL failure (PR:13997, 1 commit, 1 file changed)
  • [PVR] Addon API documentation cleanup (PR:14000, 3 commits, 6 files changed)
  • [videoplayer] DVDDemux::GetStreamType(): Add more codecs and channel (PR:13965, 2 commits, 3 files changed)
  • Small GBM code cleanups (PR:13985, 6 commits, 7 files changed)
  • [JSON]Music library “lastupdated” property (PR:13969, 2 commits, 6 files changed)
  • RetroPlayer: Add stream abstraction (PR:13976, 4 commits, 45 files changed)
  • Add cryptoSession when comparing hints (DVDStreamInfo) (PR:13982, 0 commits, 0 files changed)
  • Add CGUIViewStateFromItems::AutoPlay feature for Videos (PR:13980, 0 commits, 0 files changed)
  • utils/Geometry: add “constexpr” (PR:13918, 1 commit, 1 file changed)
  • More include cleanups (PR:13950, 5 commits, 16 files changed)
  • eventclients paths (PR:13957, 4 commits, 12 files changed)
  • RetroPlayer: Fix memory leak on Windows (PR:13999, 1 commit, 1 file changed)
  • Rename GL_INTERFACE to KODIGL_INTERFACE (PR:13700, 3 commits, 8 files changed)
  • [addons] implement path attribute (PR:13991, 1 commit, 2 files changed)
  • Refine Video::Autoplay options (PR:13992, 1 commit, 12 files changed)
  • GUIDialogSubtitles: close SUBTITLE_OSD_SETTINGS after a subtitle download (PR:13975, 1 commit, 4 files changed)
  • Clear EDL when opening a new FileItem (PR:13996, 1 commit, 1 file changed)
peripheral.joystick:
  • Add NDO SW Pro Controller and 8bitdo NES30 Arcade (PR:145, 1 commit, 2 files changed)
pvr.argustv:
  • PVR API 5.10.0 (PR:80, 1 commit, 3 files changed)
pvr.demo:
  • PVR API 5.10.0 (PR:62, 1 commit, 2 files changed)
pvr.dvblink:
  • PVR API 5.10.0 (PR:103, 1 commit, 3 files changed)
pvr.dvbviewer:
  • PVR API 5.10.0 (PR:73, 1 commit, 3 files changed)
pvr.filmon:
  • PVR API 5.10.0 (PR:83, 1 commit, 3 files changed)
pvr.hdhomerun:
  • PVR API 5.10.0 (PR:78, 1 commit, 3 files changed)
pvr.hts:
  • PVR Addon API 5.10.0: Implement stream read chunk size as addon setting. (PR:366, 1 commit, 7 files changed)
pvr.iptvsimple:
  • PVR API 5.10.0 (PR:186, 1 commit, 3 files changed)
pvr.mediaportal.tvserver:
  • PVR API 5.10.0 (PR:87, 1 commit, 3 files changed)
pvr.mythtv:
  • PVR API 5.10.0 (PR:100, 1 commit, 3 files changed)
pvr.nextpvr:
  • PVR API 5.10.0 (PR:74, 1 commit, 3 files changed)
pvr.njoy:
  • PVR API 5.10.0 (PR:47, 1 commit, 3 files changed)
pvr.octonet:
  • PVR API 5.10.0 (1e44819)
pvr.pctv:
  • PVR API 5.10.0 (PR:59, 1 commit, 3 files changed)
pvr.stalker:
  • PVR API 5.10.0 (PR:113, 1 commit, 3 files changed)
pvr.teleboy:
  • PVR API 5.10.0 (PR:10, 1 commit, 3 files changed)
pvr.vbox:
*] PVR API 5.10.0 (PR:209, 1 commit, 3 files changed)
pvr.vdr.vnsi:
  • add chunk size for recordings (PR:16, 3 commits, 6 files changed)
pvr.vuplus:
pvr.wmc:
  • PVR API 5.10.0 (PR:62, 1 commit, 4 files changed)
pvr.zattoo:
  • PVR API 5.10.0 (PR:19, 1 commit, 3 files changed)
  • Login v2 (PR:20, 4 commits, 4 files changed)
  • New settings version (prevent log spam / hidden setting value for widevine_api (a401504)
newclock5:
New commits in this build:
  • MMALCodec: Initialise iRepeatPicture (e482c2a3)
  • Revert “DVDVideoCodec: Initialise VideoPicture fields to zero (simpler)” (5fa5e500)
Includes latest addons: inputstream.adaptive (a401504, +5), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745, +1), pvr.argustv (37a3a76, +1), pvr.demo (bcd8289, +1), pvr.dvblink (1732e4b, +1), pvr.dvbviewer (986b1ba, +1), pvr.filmon (ba261c9, +1), pvr.hdhomerun (379c62c, +1), pvr.hts (f569808, +1), pvr.iptvsimple (663040c, +1), pvr.mediaportal.tvserver (01af5a0, +1), pvr.mythtv (c18ca9e, +1), pvr.nextpvr (fad3ca9, +1), pvr.njoy (30743c6, +1), pvr.octonet(1e44819, +1), pvr.pctv (d0c7241, +1), pvr.stalker (00f3fc4, +1), pvr.teleboy (dfa68b0, +1), pvr.vbox (d2e61a9, +1), pvr.vdr.vnsi (18c7474, +3), pvr.vuplus (bcfd34d, +1), pvr.wmc (ce4b47a, +1), pvr.zattoo (4fa0f72, +6), vfs.libarchive (84a4876)
@gmc Hi mate, a recent PR:
fixed an issue that has been plaguing me for a while, has this fix made it into the this latest build yet?
Edit: Ignore that, i can see it has…I’ll give it a whirl.
Is the ‘adjust refresh rate’ option broken for anyone else?
I love that option.
@gb160 if you mean
Settings \ Player
Playback
– Sync playback to display: ON
then yes, I confirm. Audio, video and subtitles get out of sync within a minute if it’s set to ON.
