[TESTING] Kodi 18 (Leia) builds for Raspberry Pi
I will try after the football game :slight_smile:
I deleted userdata folder and activated alladdons again. Now everything is working again, so no error in the 250!!
Thanks for the help
Ok tried the 249 it fixed the bootloop boogy ! Just updated to 250 after watching live TV on HDhomerun for about 15 minutes it froze when hitting the back key to change channels https://paste.osmc.tv/jiheyemumo
17.8-251, 17 June 2018: Based off OSMC commit (14ca1dac) and newclock5 (2a225662)
XBMC:
  • [vdpau] Fix black screen after pvr channel switch. (PR:14060, 1 commit, 4 files changed)
  • Resolution: Fixup GetResolutionFromString (PR:14059, 1 commit, 1 file changed)
  • [video] Cleanup and optimize CDVDFileInfo::ExtractThumb. (PR:14061, 1 commit, 3 files changed)
  • VideoPlayer: only clear hints of streams on prepare (PR:14057, 1 commit, 1 file changed)
  • PAPlayer: fix advancing playlist on error (PR:14055, 1 commit, 2 files changed)
  • GUIMediaWindow: prevent from updates while updating (PR:14039, 1 commit, 3 files changed)
  • Fix playback of playlists (PR:14054, 2 commits, 2 files changed)
  • don’t pass cryto to ffmpeg when transcoding (PR:14063, 1 commit, 1 file changed)
Includes latest addons: inputstream.adaptive (5756133, +6), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (bcd8289), pvr.dvblink (1732e4b), pvr.dvbviewer (d6f1629, +21), pvr.filmon(ba261c9), pvr.hdhomerun (379c62c), pvr.hts (f569808), pvr.iptvsimple (663040c), pvr.mediaportal.tvserver (01af5a0), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30743c6), pvr.octonet (1e44819), pvr.pctv (d0c7241), pvr.stalker(00f3fc4), pvr.teleboy (dfa68b0), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (e72598d, +2), vfs.libarchive (84a4876)
I just installed the latest test build (17.8.251) on a test-pi3 like explained in the first post.
pvr-tvheadend works, but i can’t install any games addon. (Nothing available to install, except for controller profiles and rom collection browser). I am primarily interested in the scummvm addon.
Sorry if i am missing the obvious. (Do i need to install a repository? Which one? I did this install a few weeks ago, and i don’t remember something like this.)
You need to go into addons and enable the relevant addon.
Thank you!
Stupid me. When will i understand that menu structure? Entering Addons is not the same as the submenues when i just navigate to addons. It’s not the first time i struggled with that. (using Kodi for years, but not much addons. )
Sorry for the stupid question. And thanks again.
Settings->Addons browser->My addons->Game-addons->Emulators
Enable the ones you might wanna use, but there are a few that sadface right now.
17.8-252, 18 June 2018: Based off OSMC commit (103072e1) and newclock5 (2a225662)
XBMC:
  • [python] browse dialog - list network and/or local paths (PR:11420, 1 commit, 2 files changed)
  • LinuxRendererGLES: remove early exit from Flush (PR:14064, 1 commit, 1 file changed)
  • Some ActorProtocol cleanup (PR:14047, 9 commits, 2 files changed)
  • VideoPlayer: LinuxRendererGL - remove early exit from Flush (PR:14069, 1 commit, 1 file changed)
  • Revert ā€œaddons/AddonEvents: remove virtual destructorā€ (PR:14073, 2 commits, 1 file changed)
  • [Estuary] Added missing setting at SkinSettings.xml (PR:14067, 1 commit, 1 file changed)
Includes latest addons: inputstream.adaptive (5756133, +6), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (bcd8289), pvr.dvblink (1732e4b), pvr.dvbviewer (d6f1629, +21), pvr.filmon (ba261c9), pvr.hdhomerun (379c62c), pvr.hts (f569808), pvr.iptvsimple (663040c), pvr.mediaportal.tvserver (01af5a0), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30743c6), pvr.octonet (1e44819), pvr.pctv (d0c7241), pvr.stalker (00f3fc4), pvr.teleboy (dfa68b0), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (e72598d, +2), vfs.libarchive (84a4876)
I would be happy if i am able to start a single one, i receive the sad face on all of them. Although i am just interested in ScummVM, i would love to see a single emulator UI, just to be sure i am not missing something in general.
All of them mark the dependency game.libretro as ā€œunavailableā€.
17.8-251
Watching TV and now get Boot Loop Boogy ! https://paste.osmc.tv/fenofoboro
Just installed 17.8-252
over top still have bootloop going back couple of versions
Ok went back to 17.8-240 everything is working again :slight_smile:
These are the logs from starting and sadfacing ScummVM:
https://paste.osmc.tv/zozucogagi
There is no emulator UI, Kodi is the UI.
Add a source under Games, to your rom folder. Then navigate to your desired rom and just click enter. I got a sadface when trying to start scummvm without a rom calling it. But when I do it with a scummvm file it just won’t start. Probably user error.
The ones I got started is:
mGba, quickness, Sega master/Genesis.
Thanks again.
I played a bit with some libreelec/retroarch stuff before i switched to osmc. This gave me the simple scummvm frontend to select or add a game, so i thought this would be the same here.
Used a scummvm file and a locally copied game (usually on a nfs share), but this didn’t help either.
Might be that scummvm isn’t really working, like many other emulators. Trying DosBox today to see if i can get some games running.
edit: Tried dosbox but sadfaceing, might be user error since it needs a dosbox.conf which i just copied from my windows box, can’t find an linux example of dosbox.conf
17.8-253, 19 June 2018: Based off OSMC commit (a69c89267) and newclock5 (2a225662)
XBMC:
  • [RetroPlayer] Add basic resolution changing (PR:14053, 2 commits, 3 files changed)
  • [RetroPlayer] Adjust game loop (PR:14051, 1 commit, 2 files changed)
  • [RetroPlayer] Set AML GPU to ignore alpha channel (PR:14050, 1 commit, 6 files changed)
  • [RetroPlayer] Flush/sync audio (PR:14052, 1 commit, 1 file changed)
  • [linux][gbm] add RendererDRMPRIMEGLES (PR:14026, 3 commits, 12 files changed)
  • added: ListItem.setProperties wrapper for python list items (PR:13952, 1 commit, 2 files changed)
  • json-rpc: fix playing URLs with options (PR:14068, 2 commits, 3 files changed)
inputstream.adaptive:
  • [DASH] ensure startPTS gets not < 0 during initialization (d89b547)
Includes latest addons: inputstream.adaptive (d89b547, +7), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (bcd8289), pvr.dvblink (1732e4b), pvr.dvbviewer (d6f1629, +21), pvr.filmon (ba261c9), pvr.hdhomerun (379c62c), pvr.hts (f569808), pvr.iptvsimple (663040c), pvr.mediaportal.tvserver (01af5a0), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30743c6), pvr.octonet (1e44819), pvr.pctv (d0c7241), pvr.stalker (00f3fc4), pvr.teleboy (dfa68b0), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (e72598d, +2), vfs.libarchive (84a4876)
Ok jumped to 8-253 No boot loop boogy :slight_smile: But watching HDhomerun live TV changing channels it locked up. https://paste.osmc.tv/ravofejixo
Guys I’m getting some errors when starting up and shutting down, its a problem with ā€˜usbmount@dev-sdx’ services failing to start.
I’m guessing this is relating to the automounting of usb drives.
I boot OSMC from a USB drive, for which I’ve entered the UUID in /boot/cmdline.txt.
I also mount two large storage drives via /etc/fstab, which i share via nfs.
Not sure if this is the correct way to mount and use these drives so please advise the correct way if not, I’ve had no problems using these methods in the past so I’m not sure if something new has been implemented in the nightlies as I’ve never seen these errors before now.
I should point out that everything boots up fine, and both storage drives are correctly mounted where they should be, but I’m slightly concerned as I’ve never seen these red errors before when booting and shutting down.
https://paste.osmc.tv/vakumibuto
Any ideas?
17.8-254, 22 June 2018: Based off OSMC commit (35ea64ddc) and newclock5 (3070e1)
OSMC:
  • Temp removal of pvr.mediaportal.tvserver, pvr.demo, pvr.iptvsimple due to build issues
XBMC:
  • RendererDRMPRIME: use ServiceBroker to get WinSystem (PR:14062, 2 commits, 3 files changed)
  • Fix unsafe usage of last invoker thread (PR:14087, 1 commit, 1 file changed)
  • changed: remove internal sftp support (PR:12005, 1 commit, 39 files changed)
  • [pvr] PVR Addon API 5.10.1: Add PVR_STREAM_PROPERTY_ISREALTIMESTREAM. (PR:14086, 1 ommit, 3 files changed)
  • AE: add a switch to signal that streaming will continue (PR:14085, 1 commit, 8 files changed)
  • OMXAudio: Fixup after FreeStream change (PR:14088, 1 commit, 1 file changed)
  • Fix event server keypress input processing so correct CKey creator called (#14084) (29a455e)
pvr.demo:
  • PVR API 5.10.1 (PR:63, 1 commit, 2 files changed)
pvr.filmon:
  • PVR API 5.10.1 (PR:84, 1 commit, 3 files changed)
pvr.hdhomerun:
  • PVR API 5.10.1 (PR:79, 1 commit, 3 files changed)
pvr.njoy:
  • PVR API 5.10.1 (PR:48, 1 commit, 3 files changed)
pvr.pctv:
  • PVR API 5.10.1 (PR:60, 1 commit, 3 files changed)
pvr.stalker:
  • PVR API 5.10.1 (PR:114, 1 commit, 3 files changed)
pvr.teleboy:
  • PVR API 5.10.1 (PR:11, 1 commit, 3 files changed)
pvr.zattoo:
  • PVR API 5.10.1 (PR:22, 1 commit, 3 files changed)
Includes latest addons: inputstream.adaptive (d89b547), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.dvblink (1732e4b), pvr.dvbviewer (d6f1629), pvr.filmon (b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (84981bb, +1), vfs.libarchive (84a4876)
