Sounds like a iptvsimple bug. Is your problem the same as this? Its for Windows but might also apply here:
You are a legend!
Yeah i think that temp fix worked. I tried to repeat the bug, but this time it didnt revert back to 1.
Using the OSMC DVB Stick with TVHE, 50FPS (BBC1,ITV,etc) channels are being detected as 25FPS, hence the ‘Adjust display refresh rate’ option means that the display is switched to 25 and not 50 Hz.
As a workaround, if i set the output to 50FPS, and remove 1080P@50Hz from the whitelist, these channels obviously playback fine.
I think this issue appeared once before, but it was quickly fixed so i dont think i even reported it.
Happy to provide logs later on if that would help.
17.8-298, 8 Aug 2018: Based off OSMC commit (aba32674b5) and newclock5 (d06c2f58)
XBMC:
- posix: smb - set chunk size to 64k, fixes ECONNABORT (PR:14272, 1 commit, 1 file changed)
- added: mappable action for toggling video streams (PR:14259, 1 commit, 5 files changed)
- [Music]Fix export album folder naming and overwrite of single file output (PR:14257, 1 commit, 1 file changed)
- VideoPlayer/Amlogic: fix for VC1 seek (PR:14262, 1 commit, 1 file changed)
- VideoPlayer/Amlogic: bugfix for InstanceGuard locked (PR:14269, 1 commit, 1 file changed)
- update splash to v18.0 beta (PR:14275, 1 commit, 1 file changed)
- Coverity fixes (PR:14273, 1 commit, 4 files changed)
newclock5:
Commits no longer in build:
- filesystem: test: Reduce chunksize to 64K (daf472dd)
Includes latest addons: inputstream.adaptive (faf22f1), inputstream.rtmp (bf5351e), peripheral.joystick (207d433, +3), peripheral.xarcade (07be227, +7), pvr.argustv (37a3a76), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer(75e2447), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (306fac5), pvr.iptvsimple (55637c8), pvr.mediaportal.tvserver (6439be6), pvr.mythtv (c4d8899), pvr.nextpvr (6f0515b), pvr.njoy (30aae48), pvr.octonet (1e44819), pvr.pctv(32d4b66), pvr.stalker (bfb875e, +2), pvr.teleboy (0460536), pvr.vbox (12e1304), pvr.vdr.vnsi (bb4fb30, +2), pvr.vuplus (75179a3), pvr.wmc (ec652db), pvr.zattoo (12134c8), vfs.libarchive (1bc1517), vfs.sftp, pvr.sledovanitv.cz addon
im running 17.8-297 and im not getting any upgrade available mate?
Give it some time for the mirrors to sync. Try in 30 mins.
17.8-298 fixes the issue i was having with incorrect fps being detected.
Cheers.
Great stuff
17.8-299, 9 Aug 2018: Based off OSMC commit (eb4014f6) and newclock5 (16ca85b4)
XBMC:
- cleanup resolutions, drop resoltion info < RES_WINDOW (PR:14264, 1 commit, 7 files changed)
- [VideoDatabase] Improved speed of CVideoDatabase::GetEpisodeId: Only (PR:14267, 1 commit, 2 files changed)
- Add default member initialization to code guide lines (PR:14274, 1 commit, 2 files changed)
- VideoPlayer: do not reset interlaced (PR:14276, 1 commit, 1 file changed)
- [windows] windowing: fix resetting calibration settings. (PR:14279, 1 commit, 2 files changed)
- [addons] Update XSD schemas (PR:14237, 20 commits, 14 files changed)
- VideoPlayer: WinRenderer - add smooth motion (PR:14278, 1 commit, 2 files changed)
- Fix two skin-related crashes (PR:13151, 2 commits, 2 files changed)
- [docs] Documentation fixes for built-in functions (PR:14265, 1 commit, 5 files changed)
inputstream.adaptive:
- [MPD] Fix live streams with missing timeshiftbuffer length (93efb20)
- Version bump 2.2.25 (6bf7802)
pvr.mythtv:
- SeekRecordedStream: handle special flag SEEK_POSSIBLE (3bc66ce)
- fix seeking ahead: PVR API needs zero when seeking beyond the end (e980f24)
- bump version 5.8.2 (4e9d782)
- update readme (e61f47c)
newclock5:
New commits in this build:
- VideoPlayer: blurays - do not read chunked in open_stream path (08b2c68b)
17.8-300, 10 Aug 2018: Based off OSMC commit (e5627e9f2) and newclock5 (16ca85b4)
XBMC:
- X11: updates (PR:14280, 2 commits, 10 files changed)
- VideoPlayer: blurays - do not read chunked in open_stream path (PR:14277, 1 commit, 5 files changed)
17.8-301, 11 Aug 2018: Based off OSMC commit (2970da28) and newclock5 (16ca85b4)
XBMC:
- Fix CApplicationPlayer::GetPercentage() to use new method CDataCacheCore::GetPercentage (PR:14287, 1 commit, 3 files changed)
- Fix stream playlists as directory (PR:14284, 2 commits, 1 file changed)
vfs.libarchive:
- [depends] download bzip2 from kodi mirrors (PR:20, 1 commit, 1 file changed)
- [debian] add missing dependency on libssl-dev (PR:16, 1 commit, 1 file changed)
17.8-302, 13 Aug 2018: Based off OSMC commit (28edea1eb) and newclock5 (2b6422)
OSMC Skin:
- Version 17.9.3-8
- Fix highlighting of next-up notification (2d530cd)
XBMC:
- Fix GUI sounds not updating when changed (PR:14285, 1 commit, 3 files changed)
- Retroplayer: black screen fix for ARGB1555 and some other small changes (PR:14281, 4 commits, 5 files changed)
- [docs] Add missing Player infolabels/boolean conditions (PR:14261, 2 commits, 1 file changed)
- [Docs] Unescaped comma in Player.PlaySpeed (PR:14289, 1 commit, 1 file changed)
- [bluray] Change log messages after the fs callbacks refactoring. (PR:14288, 3 commits, 5 files changed)
- [gui] Cosmetic improvements and fixes (PR:14290, 3 commits, 3 files changed)
- OpenGL: fix gui fonts for GL version 2.1 (PR:14293, 1 commit, 1 file changed)
- Revert "Retroplayer: RenderBufferPoolOpenGLES: use internal format GL (PR:14292, 1 commit, 1 file changed)
pvr.hts:
- Demuxer fixes (PR:371, 2 commits, 4 files changed)
newclock5:
17.8-303, 17 Aug 2018: Based off OSMC commit (01d18da9) and newclock5 (2b6422)
XBMC:
- Fix for (external)player from playercorefactory.xml gets the default (PR:14291, 1 commit, 1 file changed)
- addondb: avoid constraint violation (PR:14137, 1 commit, 1 file changed)
- VideoPlayer: LinuxRendererGL fixes (PR:14295, 3 commits, 5 files changed)
- [TS] collect codec extra data for hevc (036f014)
- [DASH] throttle segment wait / fix adaptationset search for updates without id / group (430c440)
17.8-304, 17 Aug 2018: Based off OSMC commit (50067215) and newclock5 (36dc7be)
XBMC:
- [json-rpc] Fix playback of pvr channels and pvr recordings - trac#17984. (PR:14301, 1 commit, 2 files changed)
- fixed: add missing dependency for retroplayer messages (PR:14297, 1 commit, 1 file changed)
- RetroPlayer: Merge savestate metadata into .sav file (PR:14209, 6 commits, 71 files changed)
- VideoPlayer: fix video rotation (PR:14298, 2 commits, 3 files changed)
- changed: auto-enable disabled add-ons which are dependencies of another (PR:14296, 1 commit, 1 file changed)
pvr.mediaportal.tvserver:
- Various updates for v18 (PR:90, 15 commits, 53 files changed)
newclock5:
- ffmpeg: hevc: Update to latest ben optimisations (79c8d745)
- fixup: ilog bit mask (b9af3e0c)
- ffmpeg: hevc: latest optimisations from Ben (2b6422b0)
17.8-305, 19 Aug 2018: Based off OSMC commit (2eb65ad) and newclock5 (36dc7be)
XBMC:
- VideoPlayer / AE: pass downmix info to AE (PR:14312, 1 commit, 20 files changed)
- Remove CAnnouncementManager::GetInstance() (PR:14303, 1 commit, 42 files changed)
- v18.0 beta2 bump (PR:14314, 1 commit, 1 file changed)
- AE: fix audio after 4a8ab6af230b58162f28f5277516a8d53498a647 (PR:14317, 1 commit, 1 file changed)
- [docs/README.*] Fix typo in .bashrc export (PR:14310, 2 commits, 6 files changed)
- VideoPlayer: fix player states regarding time (PR:14318, 1 commit, 4 files changed)
peripheral.xarcade:
- [addon.xml.in] Update URL to wiki (0ccd676)
- [README.md] Add link to wiki article (91567dd)
pvr.teleboy:
- Fix locking (PR:12, 1 commit, 1 file changed)
- Update changelog and version (0f3ccfd)
inputstream.adaptive (430c440), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv(1459cea), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer (c3ceb0b), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (0f06313), pvr.iptvsimple(55637c8), pvr.mediaportal.tvserver (ca4f4db), pvr.mythtv (e61f47c), pvr.nextpvr (6f0515b), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (32d4b66), pvr.stalker (f84483c), pvr.teleboy (0f3ccfd, +2), pvr.vbox (c115a14), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (75179a3), pvr.wmc (b5fe5a1), pvr.zattoo (12134c8), vfs.libarchive (fdc7441), vfs.sftp (9905037), pvr.sledovanitv.cz
17.8-306, 20 Aug 2018: Based off OSMC commit (5ce37b157) and newclock5 (20eb49)
XBMC:
- [jenkins] fix rebuild detection (PR:14323, 1 commit, 1 file changed)
- VideoPlayer: do not create resume bookmarks for content that cannot b (PR:14322, 1 commit, 1 file changed)
- VideoPlayer: VDPAU: disable all but 4:2:0 (PR:14324, 1 commit, 1 file changed)
- added: manual orientation setting for videos (PR:14311, 1 commit, 7 files changed)
- GUIWindowVideoNav.cpp: Fix comparison bug (PR:14321, 1 commit, 1 file changed)
- Update to v3.5.5 (PR:91, 3 commits, 7 files changed)
- Fix cmake parsing error at AddonHelpers.cmake line 126 due to a missing space (e8b0a9c)
newclock5:
- [VideoPlayer] Disable reading extension stream from input stream if decoder doesn’t support it. (bf6ff006)
- [VideoPlayer] SSIF: fix for corner case when mvc stream is switched before the last packet is read from previous stream. (76c27a9f)
- Update DVDInputStreamBluray.cpp (404dfab4)
- DemuxMVC: fixup after SeekTime API change (cde9b310)
- VideoPlayer: Change codec->codecpar (9e5b40ff)
Inacludes latest addons: inputstream.adaptive (430c440), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv(1459cea), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer (c3ceb0b), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (0f06313), pvr.iptvsimple(55637c8), pvr.mediaportal.tvserver (ca4f4db), pvr.mythtv (e61f47c), pvr.nextpvr (6f0515b), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (32d4b66), pvr.stalker (f84483c), pvr.teleboy (0f3ccfd, +2), pvr.vbox (c115a14), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (75179a3), pvr.wmc (b5fe5a1), pvr.zattoo (12134c8), vfs.libarchive (fdc7441), vfs.sftp (9905037), pvr.sledovanitv.cz
Hi I’m a recent convert from LibreELEC so just getting my head around OSMC.
Been testing The Kodi 18 nightlies (as per instructions on this thread) but for some unknown reason when I go to upgrade to the latest build I cant get any further than 17.8-304. No matter what i try I cant get 305 or 306 as it says no such file. It was fine upto 17.8-304 but then suddenly stopped working.
error message from terminal SSH access:
osmc@osmc:~$ sudo apt-get install rbp2-mediacenter-osmc=17.8-306
Reading package lists… Done
Building dependency tree
E: Version ‘17.8-306’ for ‘rbp2-mediacenter-osmc’ was not found
osmc@osmc:~$
Am I doing something obvious or is there a fault on your server.
Thanks for your time and help in advance.
Did you run sudo apt-get update?
Did you tried sudo apt-get dist-upgrade ?
Thanks to provide full logs
Yes I did. Just upgrades to 304 as newest version. No 304 or 306.
Might try going back to stable release (kodi 17.6) and trying to upgrade to 306 from there as a solution???
Wonder if it’s the bump to beta 2 that’s causing it???
There’s no beta1 yet, let alone beta2.
@gmc: did you push to aptly?
