Thanks - I’ve added in to the next build
@toast - Very odd. I’ll do some more testing.
Something has gone wonky. Just about about every addon is now enabled
Will dig through the build to see where this cropped up.
You need to pick my patch I posted earlier. It will fix the all addons enabled issue
Ah ok. Thanks. Running a build now.
17.8-022, 1 Feb 2017: Based off OSMC commit (f6a8999f9) and newclock5 (f0628b0)
OSMC:
Remove broken game.moonlight
XBMC:
cmake: fix handling of X11 (PR:11611, 1 commit, 4 files changed)
Controller cleanup (PR:11621, 3 commits, 7 files changed)
Fix analog sticks (PR:11616, 3 commits, 17 files changed)
[PVR] Fix trac17246 - another approach (PR:11615, 4 commits, 5 files changed)
Have the JSON handler sent a custom CEvent to the slideshow class (PR:11613, 1 commit, 1 file changed)
peripheral.joystick:
Improvements to button mapping (PR:84, 2 commits, 7 files changed)
pvr.mythtv:
4.3.1 (PR:62, 4 commits, 12 files changed)
update README (c68b7ab5)
add new setting ‘livetv_recordings’ (93124590)
get/set setting ‘livetv_recordings’ (dc0198f9)
show/hide livetv recordings (7ff47571)
add translations en,fr for setting 30067 (269f64f2)
Just updated to the latest version…No joy its in the boot loop cycle and can not SSH to get log
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Feb 11 18:41:18 2017 from t-office-pc.local
osmc@osmc:~$ grab-logs -A
Unable to write temporary log to /var/tmp/uploadlog.txt
Failed
Either sd card is full or corrupt. What’s the output from
sudo journalctl | paste-log
dmesg | paste-log
Here it is:
Last login: Sat Feb 11 18:42:58 2017 from t-office-pc.local
osmc@osmc:~$ sudo journalctl | paste-log
cat: write error: No space left on device
http://paste.osmc.io/zebeneyoye
osmc@osmc:~$ dmesg | paste-log
http://paste.osmc.io/epumoruvav
osmc@osmc:~$
I have the same size SD cards on other pi’s 16 gig
df -h
The clue is in the error ![]()
Best browse around the directories. Something is taking up all your space.
LOL 2700 movies with 260 TV shows with all episodes But all my SD cards are the ScanDisk 16 gigs
Last login: Sat Feb 11 18:39:49 2017 from t-office-pc.local
osmc@osmc:~$ df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 362M 0 362M 0% /dev
tmpfs 367M 5.0M 362M 2% /run
/dev/mmcblk0p2 15G 14G 0 100% /
tmpfs 367M 0 367M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 367M 0 367M 0% /sys/fs/cgroup
tmpfs 74M 0 74M 0% /run/user/1000
osmc@osmc:~$
pretty full
17.8-024, 11 Feb 2017: Based off OSMC commit (f2be8f12) and newclock5 (5d6c8ab)
OSMC:
Fix truncated patch for BTPlayer enablement (8875397)
Fix profile switching (70f0e01fab2)
Re-add patch that only saves settings if modified (5259e5bf0)
XBMC:
Remove AEDefines_override.h (PR:11636, 1 commit, 1 file changed)
support for image decoder add-ons (PR:11086, 4 commits, 35 files changed)
[xbmc][improvement][docs] Add missing documentation to appmessenger and IMessageTarget (PR:11531, 1 commit, 3 files changed)
[skins] show video indicator in slideshow window (PR:11525, 1 commit, 2 files changed)
[Estuary] fixes (PR:11482, 1 commit, 11 files changed)
newclock5:
New commits in this build:
Application: Add decay before python door closes (7066e497)
Application: Allow python door to open for up to 80ms (5d6c8abf)
Does the new skin allow custom shortcuts for Retropie ?
I just installed using this method http://www.instructables.com/id/DIY-Raspberry-Pi-3-Media-Center-OSMC-With-RetroPie/
It should as it also uses skin shortcuts.
You can also use the launcher addon.
17.8-025, 12 Feb 2017: Based off OSMC commit (d85ea819aa) and newclock5 (5d6c8ab)
OSMC:
RSS: use CDN for feed (5044ec2121)
Add game.libretro.dinothaw (d6d5ca36374)
XBMC:
[controller dialog] Ignore delayed axes (PR:11641, 1 commit, 6 files changed)
explicitly pass rrefs for move semantics (PR:11650, 1 commit, 2 files changed)
Don’t trim trailing space from joystick name (PR:85, 1 commit, 3 files changed)
pvr.hts:
Revert “[htsp v26] implement server based playcount and playposition” (PR:285, 1 commit, 6 files changed)
17.8-026, 13 Feb 2017: Based off OSMC commit (d85ea819aa) and newclock5 (5d6c8ab)
XBMC:
Improve keyboard handling during button mapping (PR:11645, 3 commits, 109 files changed)
17.8-027, 14 Feb 2017: Based off OSMC commit (03cdc5e20752) and newclock5 (0ffe036f9)
XBMC:
Improve performance for python addons using xbmcgui.ListItem (PR:11651, 2 commits, 2 files changed)
VideoPlayer: fix edl skipping (PR:11646, 3 commits, 7 files changed)
[interfaces] legacy: fix format error when building with -Werror=form… (PR:11656, 1 commit, 1 file changed)
newclock5:
mmm (b08cd0cf)
mm (90165774)
Revert “mm” (33332086)
Revert “mmm” (0e64fd71)
OMXPlayer: Fixup after DVDMessage changes (0ffe036f)
Commits no longer in build:
17.8-028, 15 Feb 2017: Based off OSMC commit (03cdc5e20752) and newclock5 (112172e3)
XBMC:
OMXPlayer: Fixup after DVDMessage changes (PR:11666, 1 commit, 2 files changed)
Amltiming fr3 (PR:11667, 6 commits, 13 files changed)
Add dialog for delayed axis detection (PR:11623, 2 commits, 13 files changed)
newclock5:
mmm (b08cd0cf)
mm (90165774)
Patches worked for me, no breakage
