I believe it will still work – but it’s not yet in the app store.
Thank you for answer. Is there an estimate when it could be?
Thanks for your work!
We probably won’t add it to be honest, as there hasn’t been any real demand for it. You can follow the instructions in the first post however.
This is really a shame, I tried to follow the first post, but there was an access problem, I was getting ERR_CONNECTION_REFUSED.
I’ll try again later with a clean installation, thank you
@sam_nazarko can you help me with this?
osmc@osmc [09:48:41] [~]
-> % sudo -s
osmc# export DEBIAN_FRONTEND=noninteractive
osmc# apt-get update
Ign:1 http://ftp.debian.org/debian stretch InRelease
Hit:3 http://security.debian.org stretch/updates InRelease
Hit:4 http://ftp.debian.org/debian stretch-updates InRelease
Hit:5 http://ftp.debian.org/debian stretch Release
Hit:2 http://ftp.fau.de/osmc/osmc/apt stretch InRelease
Reading package lists... Done
osmc# apt-get install lamp-app-osmc
Building dependency tree
E: Unable to locate package lamp-app-osmc
I am using standard OSMC verion with the latest updates
BTW - I need only PHP, so if this package is no working anymore, how can I install php itself? PHP 5 will be enough
sudo apt-get install php
OK, i have installed php 7. with:
osmc@osmc [10:53:14 AM] [~]
-> % sudo -i
root@osmc:~# apt-get install php
root@osmc:~# php -v
PHP 7.0.27-0+deb9u1 (cli) (built: Jan 5 2018 13:51:52) ( NTS )
Copyright (c) 1997-2017 The PHP Group
Zend Engine v3.0.0, Copyright (c) 1998-2017 Zend Technologies
with Zend OPcache v7.0.27-0+deb9u1, Copyright (c) 1999-2017, by Zend Technologies
Hi Sam,
I know this post was from 3 years ago so it’s likely that it’s no longer applicable but what happened to the lamp-app-osmc package. Did something replace it?
I didn’t get much attention.
IIRC, it’s still there. It was just a basic meta-package.
Oh okay. Well, like qweluke, I get:
root@vero:/# apt-get install lamp-app-osmc
Has the install method changed?
Another thing to think about: you might want to switch MySQL for MariaDB. Since it’s a 1-1 switch, there should be few (if any) headaches, and MariaDB optimization is better. Particularly given that most HTPC systems aren’t built to be servers, optimization is important!
Maria should automatically be chosen now
Awesome! My build I wasn’t aware there was a LAMP stack already provided so I built it myself. Oh well.
