I literally just built the installer from Git on my Mac to start debugging when I came across this…
I’m on a mac with an SD slot running Sierra - If you want me to run tests & build here please drop me a message or a reply or something along those lines, otherwise - Good luck
That’s helpful. I’ll wait for @srmo to produce a test build. If we can’t work it out, it may help to have someone test it on Sierra directly.
Stay tuned.
srmo
8 September 2016 19:26
23
On it
Edit: Sierra will be released soon!
srmo
8 September 2016 19:27
24
Did you successfully built the installer and gained any insight?
srmo
9 September 2016 00:21
25
Hi folks. Here’s the experimental build. Please be aware that I had not the chance to test it on any other machine than my own. Please run it, see what happens and provide us with the info and logfile
http://download.osmc.tv/dev/srm/osx-test/osmc-installer.dmg
skymoo
9 September 2016 04:07
26
Just ran on my Sierra VM and again it failed to detect the SD Card, the log is here .
@srmo
Ejectable flag has been changed. Try this. Should keep working on OS X new, and old.
Try this:
diff --git a/installer/host/qt_host_installer/io_osx.cpp b/installer/host/qt_host_installer/io_osx.cpp
index 56de438..9cdf94d 100644
--- a/installer/host/qt_host_installer/io_osx.cpp
+++ b/installer/host/qt_host_installer/io_osx.cpp
@@ -207,6 +207,8 @@ namespace io
QString ejectable = QString(line.split(":").at(1).simplified());
if (0 == QString("Yes").compare(ejectable, Qt::CaseInsensitive))
isEjectable = true;
+ if (0 == QString("Removable").compare(ejectable, Qt::CaseInsensitive))
+ isEjectable == true;
utils::writeLog("Determined " + ejectable + " as ejactableProperty for " + diskPath);
else if (line.simplified().startsWith("Protocol:"))
(diff is vanilla, doesn’t cover changes a few hours ago). Pretty sure current evaluation of RO is fine, and doesn’t need my suggestion made in Slack.
We need to clean this up in V2.
srmo
9 September 2016 21:27
28
Hi, this here is a test version with a potential fix.
Please test this. If you have a pre-Sierra version available, it would be much appreciated if you can give this version a whirl on pre-Sierra too, to find potential regressions.
http://download.osmc.tv/dev/srm/osx-test/osmc-installer-2.dmg
Looking forward to your feedback.
If you encounter any problem, please provide the installer’s log-file.
skymoo
9 September 2016 22:22
29
Success on Sierra!
OSMC also boots off the created SD card without issue
I can provide the installer log if you’re interested?
It also seems to work great on El Capitan, haven’t booted off that one yet… If there are issues I’ll post.
Updated installer with support for Sierra is now pushed live and available on our website.
Thanks for your testing and feedback. I’ll mark this thread as solved and close. Please start a new thread if any new issues crop up.
