hi Sam!
is this available under jessie-devel or we should wait for this there as well?
hi Sam!
It should be under jessie-devel. Please let me know if it fixes your issue
hi Sam!
Unfortunately it didnāt solve it. Itās still exactly the same.
Can you explain what isnāt solved? The highlighting issue or the freezing issue?
Please also paste a log so I can see if your device updated properly as well
The highlight issue. As i go downwards the selection remains active on the previous channels, but only till i donāt reach the last visible one. Once i reach that the multi-selection disappears and only 1 selection is visible (correctly).
Can you please upload a log so I can verify your system has indeed updated to the version weād expect?
Iāll then let you know when this is resolved
You use allways DVBLink ?
Take a look to
http://forum.dvblogic.com/viewtopic.php?f=66&t=31968&start=45
Probably nothing to do with Vero4.
Michael
If you are checking the video you would see it is not related to anything else but OSMCās skin.
Why not simply try another skin?
Just FYI it is ok on other systems, not on the Vero.
Simply tell us your PVR Add-Onā¦
DVBLink
Try to understand, you have 3 levels, when you use your mediacenter KODI
I canāt help you, because I use DVB Link on my Nas, but I donāt use the PVR Add-on for live channels (I switch to French TNT to see live Channels).
I know that Kodi team workās for release Krypton 17.2 (take a look to the Github), and also that the DVBLogic team try to update their Add-ON.
When you think really that itās a OSMC problem, you must explain more better why.
Michael
hi Michael!
I think it is an OSMC problem, because i installed Kodi (17.1, the same version that OSMC is using as well currently), installed the exact same PVR addon (exact same version and subversion) and everything is ok.
Now if i go to my Vero and check the same i have that highlight issue, thatās why iām more then sure it is related to this.
I believe the highlight bug isnāt unique to OSMC (Kodi issue), but we hope to have this resolved shortly.
Re. DVB-Link crash: again, I am not sure if is related to Vero 4K, but Iāll check with some other users and see if they also get this issue. Your device looks to be up to date which is good.
Sam, i didnāt see it anywhere else but on OSMC.
Are you running the same version of Kodi on those devices?
yes, 17.1
