Reading package lists… Done
Building dependency tree… Done
armv7-transmission-app-osmc is already the newest version (3.0.0-2).
0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
it is running. And the ip.of.rasp.pi:9091 opens the transmission webinterface.
But that’s the problem
sudo apt-get -y remove transmission-daemon
Reading package lists... Done
Building dependency tree... Done
Package 'transmission-daemon' is not installed, so not removed
Hi, thank you. Now it seems to be up and running again… Thank you all for your help !!
I would have another question related to transmission.
I used to conditionally allow Transmission to run, as long as my VPN is running. If the VPN goes down, so does Transmission.
This was setup by inserting some command into /lib/systemd/system/transmission-daemon.service but now that I have installed it from OSMC, this file is empty.
But you shouldn’t actaully modify this file directly as changes could be over written by an update to transmission. The easy way is to create a copy and modify the new file, copy the file to:
