Not sure if I should start a new topic for this, but then I’ve been flamed in the past for doing so, so…
I have set up openvpn on a RPI 3/OSMC system. It seems that openvpn works to a point (using the free vpn services to start).
Here’s where I’ve gotten to – when I execute:
openvpn --remote <ipaddr of the vpn server> --dev tun1 --ifconfig 10.9.8.1 10.9.8.2
I get as a result:
Wed Mar 22 10:13:50 2017 OpenVPN 2.3.4 arm-unknown-linux-gnueabihf [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Nov 19 2015
Wed Mar 22 10:13:50 2017 library versions: OpenSSL 1.0.1t 3 May 2016, LZO 2.08
Wed Mar 22 10:13:50 2017 ******* WARNING *******: all encryption and authentication features disabled – all data will be tunnelled as cleartext
Wed Mar 22 10:13:50 2017 TUN/TAP device tun1 opened
Wed Mar 22 10:13:50 2017 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Wed Mar 22 10:13:50 2017 /sbin/ip link set dev tun1 up mtu 1500
Wed Mar 22 10:13:50 2017 /sbin/ip addr add dev tun1 local 10.9.8.1 peer 10.9.8.2
Wed Mar 22 10:13:50 2017 UDPv4 link local (bound): [undef]
Wed Mar 22 10:13:50 2017 UDPv4 link remote: [AF_INET]176.126.237.207:1194
…and the output stops, as if it’s waiting (which may be the right result).
Then if I execute ifconfig -a I get:
(eth0 and lo info…snip…)
tun1 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 inet addr:10.9.8.1 P-t-P:10.9.8.2 Mask:255.255.255.255 UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:100 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
So the command line version seems to work. However, if I try to run
sudo openvpn /etc/openvpn/.vpn_config/FreeVPN.me-TCP443.ovpn
I get this msg (among other warnings):
…snip…
ERROR: Cannot ioctl TUNSETIFF tun1: Operation not permitted (errno=1)
Exiting due to fatal error
and running ifconfig -a shows me my eth0 and lo info, but the tun1 info is nowhere to be found.
This feels like a permissions issue, but could be something more subtle.
Thx for any help on this…
