Update stop at 92% “armv7-bluez-osmc armhf”
If you disable Bluetooth via config.txt this could cause unexpected results as we try and load the Bluetooth fimware on boot.
problem solved by deleting the lines in config.txt
Is there a specific reason why you added it originally?
I uninstalled a lot of things including the BT, thats all.
I’m not sure there’s much benefit in that – just don’t use these features if you don’t want to.
Yes !
